Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
Remote will not lock door
Reply
Thread Tools
Old 12-29-2009, 10:25 PM   #1
hwydave
Des Plaines, IL
2009 XLT, 1999 XL (RIP)
Vehicle Specs
(Original Poster)
Angry Remote will not lock door
Greetings,
My keyless remote for the 99 Explorer would not lock the door this evening. I pressed the lock button once and no respond from the Explorer, not even the usual “click/thump” sound; pressed the button the second time and I hear the usual horn sound goes off once. The remote would unlock the door, however. The keypad will not lock the door either; the keypad will unlock the door. I could lock and unlock the door from the switch/button inside or via manual operation. Any suggestion on where I should start look into solving this mystery? If this question has been asked in the past, please help point me to the right link. Thanks a bunch!!
hwydave is offline   Reply With Quote
Old 12-29-2009, 10:46 PM   #2
robertoa1a
Jacksonville, FL
96 5.0 xlt 2wd white/char
Vehicle Specs
With the up above sticky, on your year, you are still having the issue?
robertoa1a is offline   Reply With Quote
Old 12-30-2009, 08:25 AM   #3
budwich
Ottawa, Ont
96 XL
Vehicle Specs
IF there is no mechanical noise (ie. all is quiet), odds are you have a broken splice going from the RAP to the unlock / lock relays.... tons of posts... the splice is in the rear left passenger side cable raceway.
budwich is offline   Reply With Quote
Old 01-02-2010, 08:26 PM   #4
hwydave
Des Plaines, IL
Vehicle Specs
(Original Poster)
Thank you, Budwich, for the advice. I will look into the posts and update the result. I hope the problem is not the locking mechanism or something that require a visit to a dealer...
Old 01-02-2010, 08:52 PM   #5
Blee1099
Evil Asian
Elkridge, MD
Blee1099's Avatar
91
Vehicle Specs
Is it not locking all the doors or only a specific door? If its a specific door then chances are its the lock actuator being bad or something else in the door. Unlock all the doors and see if the remote will lock the rest of the doors.
Blee1099 is offline   Reply With Quote
Old 01-08-2010, 02:05 PM   #6
hwydave
Des Plaines, IL
Vehicle Specs
(Original Poster)
All doors will not lock
The doors will not automatically lock when the car move; it usually automatically lock the door when car move.
Old 01-08-2010, 03:33 PM   #7
budwich
Ottawa, Ont
96 XL
Vehicle Specs
Its not a mechanical issue then... and its the "common... ya broke my splice" issue.
Old 01-13-2010, 08:12 PM   #8
schell1860
Vehicle Specs
Quote:
I am having the same problem with my remote--where do I find some answers
schell1860 is offline   Reply With Quote
Old 01-13-2010, 08:48 PM   #9
Electrohacker
Clinton Twp, MI
'96 XLT V8 4WD
Vehicle Specs
Quote:
*facepalm*
right here!
__________________
it's funny that everyone's embarrassed to drive a station wagon, but drop a truck chassis under it and call it a SUV and suddenly everyone wants one...
my truck's build up (in progress)
Electrohacker is offline   Reply With Quote
Old 04-26-2010, 11:34 PM   #10
hwydave
Des Plaines, IL
Vehicle Specs
(Original Poster)
Thanks to all the suggestions, I fixed the problem tonight. The issue is, as Budwich suggested, the wire splice issue. Thanks to Bluestream1's post (http://www.explorerforum.com/forums/...d.php?t=179629) and photo, I found the wires that cause the lock to fail. The outside definitely looks fine but once I cutted the protected wrapping open, the joint was oxided to powder form. I am terrible at soldering and so I used the butt splice to joined the wire together, heat wrap the wires, and then tap the wrap for extra protection.
Thanks again, guys, for your help. You guys rock!!!
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
