#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2006 - 2010 Explorer Mountaineer 4th Generation > Stock 2006 -2010 Explorers
Notices
Stock 2006 -2010 Explorers Stock 2006 -2010 Ford Explorer Forum. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
Where is the keyless entry module for the door code on a 2007 Explorer?
Reply
Thread Tools
Old 12-30-2009, 07:28 AM   #1
Seever
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Dk Exp Where is the keyless entry module for the door code on a 2007 Explorer?
Hey Everyone! how you doing all ? hope you guys are all fine and healthy ..
i'm new member here just registered probably i have to intorduce my self first!
I'm Seever from Kurdistan [ Iraqi Kurdistan/northern of iraq] 22 years old one of the big fans of FORD Cars ..
i was googling about somethings and infos that i needed for my FORD EXPLORER xlt 2007 so while the googling i found this awsome and amazing forum with loads of useful threads/topics really greatful articles from all of the members ..
since i'm new that means i don't have enough knowledge to know where to post my first quistion here !?
i need help with my FORD EXPLORER xlt 2007, i bought it from second hand not new so it come with no keyless cod [ the factory 5 digits code] but i'm so excited to take that code out from the [ computer module ] inside the car! porbably someone else asked same help but believe me guy i've tried and searched all over the forum to find it somewehre but all i got was for the other model ford exploreres! so here i wish you guys could help me out telling me where is the Computer module label that printed the facotry 5 digits for the keyless code!
any help from anyone is greatly apprecitaed ..
kind regards from Seever ...
here is the picture of my FORD EXPLORER xlt 2007 willing someone tell me where the computer module located!
P.S sorry for that my english isn't that well!
and dear moderators if you know that this forum isn't the right place to put this or i can't get help from here your highness can move it to its place that meant to be!
regards.
Seever is offline   Reply With Quote
( Join the Elite Explorers )
Old 12-30-2009, 10:54 AM   #2
BrooklynBay
Brooklyn, NY
BrooklynBay's Avatar
88 89 93 95 96 Aerostars
Vehicle Specs
Quoted: 380 Post(s)
Welcome to this forum! I've renamed your thread, and moved it into the stock 2006-2010 section.
BrooklynBay is offline   Reply With Quote
Old 12-30-2009, 12:08 PM   #3
tv4fish
Minnesota
2007 EB V8 & 2002 EB V6
Vehicle Specs
Quoted: 1 Post(s)
I think this is your answer :
•2002 thru 2007 is in the right panel behind the middle row window. It is below the seat belt mechanism. You have to pull out the top plastic panel off, then loosen the lower panel to be able to see the face of the computer module. The code is on a sticker on the face of the module
This also may help you:
Programming a personal entry code The factory set code cannot be reprogrammed but you can create your own 5�digit personal entry code. When pressing the controls on the keypad, press the middle of the controls to ensure a good activation.
Up to three personal entry codes may be programmed to the vehicle. To create your own personal entry code:
•1. Enter the factory set code.
•2. Within five seconds press the 1 � 2 on the keypad.
•3. Enter your personal 5-digit code. Each number must be entered within five seconds of each other.
•4. Press 1 � 2, 3 � 4 or 5 � 6 to indicate which of the three personal entry code positions you wish to use.
•5. The doors will again lock then unlock to confirm that your personal key code has been programmed to the module.
Tips:
•Do not set a code that uses five of the same number.
•Do not use five numbers in sequential order.
•The factory set code will work even if you have set your own personal code.
•If you program a code to a position that already contains a set code, the previously-set code will be erased
tv4fish is offline   Reply With Quote
Old 12-30-2009, 12:40 PM   #4
Seever
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
@ BrooklynBay
thank you for moving it from there to here ..
@tv4fish
i've checked there out but it isn't there! i didn't find anything!!
do i have to remove the lower panel completely!? cause i checked there out but i didn't see anything & i haven't removed lower panel completely .. will try it soon,
anyone has or know where can i get picture of the computer module's location?
Old 12-30-2009, 03:33 PM   #5
Seever
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
it's been almost 2 hours i'm looking for that module there but looks like that its somewhere else! cuase i've checked both of right and left door seatbelt mechanisms but it is not there!!!
anyone plz ?
Old 12-30-2009, 05:16 PM   #6
tv4fish
Minnesota
Vehicle Specs
Quoted: 1 Post(s)
OK --- These pix may help you locate it:
http://www.explorerforum.com/forums/....php?p=2221653
Go to the last set of pix - You HAVE to remove that lower plastic panel
Old 12-30-2009, 06:49 PM   #7
Seever
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
i've checked this out as well, but unfortunately mine ain't located as that 2004 in the pic you posted! i've removed the lower plastic panel completely but there isn't anything like that located here!
mine is 2007 i've checked both right and left doors as well! i can't find it ..
any other suggestions!?
Old 12-30-2009, 07:37 PM   #8
DavidEBSmith
Chicago, IL
'07 Mountaineer
Vehicle Specs
Quoted: 2 Post(s)
The service manual says that the code is on a label on the Smart Junction Box. The SJB is what the fuse panel is attached to, on the driver's side, by the emergency brake. Apparently it is on the back of the SJB - I've looked in there with an inspection mirror and I can see some numbers stamped on the back, but I just can't see them well enough to read them.
Fortunately I got a guy at a local dealer with a scan tool. . .
DavidEBSmith is offline   Reply With Quote
Old 12-31-2009, 01:25 AM   #9
bill32399
Oregon
07 ST XLT 4x4 V8
Vehicle Specs
Quoted: 0 Post(s)
Ok I am gonna take stab at it here and say it is under the armrest console attached to the floorboard of the rig. That is where I found mine but keep in mind I have a Sport-trac.
bill32399 is offline   Reply With Quote
Old 12-31-2009, 07:08 AM   #10
Seever
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Hey David yours sound different! but a picture would be a worth 1,000,000 words !? a pic of this SJB ...
Old 12-31-2009, 03:31 PM   #11
belvin20
Cornelius, North Carolina
belvin20's Avatar
1999 And 2006 V-8's
Vehicle Specs
Quoted: 1 Post(s)
On my 2006 EB, the code is on the box behind the passenger side air bag. You can see the box by looking up under the glove box, but you will not be able to see the code as it is blocked by the air bag. I had to remove the air bag to get my code, and what a job, if I it do over again, I would have paid the dealer to get the code for me. On the new body style Explorers the security box in behind the passenger air bag.
belvin20 is offline   Reply With Quote
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
