#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1991 - 1994 Explorer Ranger Navajo 1st Generation > Stock 1991 - 1994 Explorers
Notices
Stock 1991 - 1994 Explorers For questions related to the base Ford Explorer. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. No modification questions.
1994 Explorer. How do I adjust the timing of the CPS?
Reply
Thread Tools
Old 12-30-2009, 06:29 PM   #1
stecam78
dushore, pa
1994 xlt
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
US 1994 Explorer. How do I adjust the timing of the CPS?
Hey all, anyone know the timing setting for a 94 x with 4.0. I was told it was 10 btc and tdc. Which one is it. I believe that is what is wrong with it. I rebuilt the motor some time ago now, and it immediately ran like it was running on four cyl. Any help is appreciated
stecam78 is offline   Reply With Quote
( Join the Elite Explorers )
Old 12-30-2009, 06:39 PM   #2
BrooklynBay
Brooklyn, NY
BrooklynBay's Avatar
88 89 93 95 96 Aerostars
Vehicle Specs
Quoted: 380 Post(s)
Welcome to this forum! I've renamed your thread, and moved it into the stock 91-94 section. Do you have a timing light, and a special tool to align the sensor?
BrooklynBay is online now   Reply With Quote
Old 12-30-2009, 07:11 PM   #3
92exp4x4
Covington, Kentucky
92 XL 2-door and others
Vehicle Specs
Quoted: 1 Post(s)
Search the forum there is a really good write up about adjusting the sensor in here somewhere.
-edit- try this one:
http://www.explorerforum.com/forums/...d.php?t=264672
__________________
My stable:
2 doors - '91 Eddie Bauer; '92 XL 5 spd; '92 Sport 2WD 5 spd
4 doors - '93 XLT; '94 XLT, 6" lift, 33's; '94 Eddie Bauer 5 spd; '94 Limited
Others - '22 Model T, '62 Fairlane 500, '93 F-Superduty 460 5 spd, '93 Aerostar 4.0 LWB, '95 Aerostar, '01 Mazda B2300 5 spd (wifey's) '15 F750 service truck (company owned)
92exp4x4 is offline   Reply With Quote
Old 01-03-2010, 08:26 AM   #4
motopsycho650
Denver, CO
1994 XLT
Vehicle Specs
Quoted: 0 Post(s)
You must install the sensor while the engine in at TDC on the compression stroke. Turn the crank pulley to the "0" mark while watching the valves on the #1 cylinder. The valve closest to the front of the engine is the exhaust valve, the second is the intake. You want to watch the intake valve open/close and stop the next time you see the "0" mark on the pulley. This is TDC for the compression stroke.
After installing the sensor, you have to turn the crank pulley to 26 degrees after top dead center. Do this by turning the crank exactly 34mm past the "0" mark. This is the correct engine timing needed to do the final sync on the cam position censor. If you did the final sync while still at the "0" mark, the CPS is not synced correctly.
That post that 92exp4x4 posted was to my thread while I was replacing the sensor. There is more info there...
__________________
'94 Explorer XLT - 4x4 - Automatic - 4 Door
There is a reason technicians call them "Exploders"
motopsycho650 is offline   Reply With Quote
Old 01-05-2010, 10:32 PM   #5
stecam78
dushore, pa
1994 xlt
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
well, i will try it as soon as I get a chance. I am currently in the process of installing a 3.0 back in my mazda b3000 and I am having some serious doubts as to if i have it timed right. Fingers crossed and i thanks all for the input. I will let you know how it comes out
Old 01-22-2010, 12:09 AM   #6
stecam78
dushore, pa
1994 xlt
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
ok, question for you. What is the easiest way to measure the 34mm past tdc. Also i am taking it that once the crank pully is set 26 degrees past tdc, to do the final synch you have to turn the sensor until the alignment tool fits and then tighten things down?? Also, is this the same procedure for a 94 explorer 4.0?
Old 01-22-2010, 12:11 AM   #7
stecam78
dushore, pa
1994 xlt
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
what i meant was is this the same procedure for a 1998 mazda 3.0 in a b3000?
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
