Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2002 - 2005 Explorer Mountaineer 3rd Generation > Stock 2002 - 2005 Explorers
Notices
Stock 2002 - 2005 Explorers Questions related to non-modified 2002 - 2005 Explorers and Mountaineers. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. Sport Trac and Sport use the 1995-2001 forum.
Advance Trac problem
Reply
Thread Tools
Old 12-30-2009, 06:05 PM   #1
WOODSLEY_HUNTER
St. Charles, MO
'02 Eddie Bauer Explorer
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
I have an '02 EB Explorer, V8. I purchased it new.The "CHECK AVDTRAC" message as well as the little car symbol came on a few times when it was under warranty but the dealership was unable to find the source of the problem. Over the years the problem has gotten worse. Now the warning comes on all the time. I believe that it is related to the brake system but I am not sure where to start looking. I came to this conclusion because the warning will display when stopped, in are out of Park, just by pressing the brake pedal down just a little. There are times though when it will come on while driving when I lift my foot off the brake pedal. The system seems to work ok. When slippery driving conditions due exist, and the warning hasn't come on, the little car icon will come on and then go away like it is supposed to when there is actual tire slippage. I have looked at 50 pages of posts as well as searched for Advance Trac posts but did not see any with these systems. Thanks in advance for any suggestions on this issue. This forum is a valuable source of information.
Chuck
WOODSLEY_HUNTER is offline   Reply With Quote
( Join the Elite Explorers )
Old 01-02-2010, 06:52 PM   #2
Minivek
Quebec, Canada
'03 Limited Ex silver
Vehicle Specs
Quoted: 0 Post(s)
when mine did that, it gradually got worse with time, eventually the abs would come on when braking around corners. I also had a bad wheel bearing, got the bearing fixed, and a new abs sensor on that wheel and it fixed everything.
Check your wheel abs sensors, they give wheel speed input for abs brakes but also for advance trac
__________________
Lifted and sold 94 sport.
New baby 2003 4.6 Silver Limited Explorer!!
Minivek is offline   Reply With Quote
Old 01-02-2010, 07:46 PM   #3
WOODSLEY_HUNTER
St. Charles, MO
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Would the abs sensors cause a warning when the car isn't moving? It does it when it is in PARK and you put your foot on the brake to move the selector into Drive.
Thanks
Old 01-25-2010, 11:17 AM   #4
tcore83
Iowa
2005 XLT Sport
Vehicle Specs
Quoted: 0 Post(s)
US
I have a similar issue in my 2005 EXT Sport w/ 4.0L, when I turn the key off, right before the message center goes blank, the display flashes "CHECK ADVANCE TRAC" and beeps. It doesnt always do this and I cannot seem to find any pattern that would cause it. e.g being on slippery roads or any other conditions that would could the Advance Trac to be used. I have talked to the dealer and they have no idea and the computer has been scanned and it does not have any error codes.
tcore83 is offline   Reply With Quote
Old 01-25-2010, 04:19 PM   #5
FordLover
Houston, Tx
'02 XLT
Vehicle Specs
Quoted: 2 Post(s)
wish I could help, but I can only say I've had it happen a few times as well, but only when I'm driving, and a restart always clears it. 2002 was the first year for advance trac, but it was a late option availablity, and I think it was only offered with the V8, so it's a rare feature. One thing to note is that the Advance trac came with brakeforce distribution, which helps boost braking power in a panic stop situation. I'm assuming there is a sensor on the brake pedal that works with BFD and the Advance trac, and there is a possibility it is causing your issues.
I had my brake master cylinder replaced a couple years ago under warranty because the brakes were spongy, and I've not experienced the warning since then.
__________________
'02 XLT V8 4x4 tow pkg - sometimes pulling our camper
'07 Infiniti G35 Sport Sedan 6 speed
'13 Ford Edge Limited (wifes)
GONE: '94 Sport, '91 XLT, '92 XL 2dr 4x4 33's lifted
FordLover is offline   Reply With Quote
Old 01-25-2010, 07:18 PM   #6
WOODSLEY_HUNTER
St. Charles, MO
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Thanks for the replies. I will check for a sensor there. I saw an earlier post that mentioned a brake power assist sensor somewhere inside the interrior. Are you familiar with that? It seems that the problem has some connection to the brake system since it will activate when sitting in park and pushing the brake pedal down. The adv trac works correctly when the wheels slip while driving.
Thanks again
Old 03-06-2010, 12:46 PM   #7
Lutz
2005 XLT
Vehicle Specs
Quoted: 0 Post(s)
Since these sensors are an active component can i check them using an ohm meter?? looks like that would be an easy process
Lutz is offline   Reply With Quote
Old 03-20-2010, 10:22 PM   #8
foresito
North CArolina
2005 XLT
Vehicle Specs
Quoted: 0 Post(s)
I have my Ford Explorer XLT 2005 83000mi and the Advance Trac Light is always on and the message in the console any help
foresito is offline   Reply With Quote
Old 03-24-2010, 03:33 PM   #9
jp450
Pepperell, MA
jp450's Avatar
'05 XLT V8
Vehicle Specs
Quoted: 6 Post(s)
Quote:
This problem has been addressed in a TSB that calls for replacing the instrument cluster with a revised one with new software. Mine does it too. I am not going to spend money on it as it is not really an issue to me right now.
__________________
2005 XLT V8
jp450 is offline   Reply With Quote
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
