Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1991 - 1994 Explorer Ranger Navajo 1st Generation > Stock 1991 - 1994 Explorers
Notices
Stock 1991 - 1994 Explorers For questions related to the base Ford Explorer. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. No modification questions.
Heater problem
Reply
Thread Tools
Old 01-08-2010, 09:19 PM   #1
stubellos
stephens city virginia
1993 XLT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
US Heater problem
Hi I have a 1993 Explorer XLT and the cabin heater has been giving me some problems. The colder it gets outside the cooler the air is that blows from the interior vents. Above 40 degrees or so the problem is minor but since it has been in the 20's for the last few weeks it has been enough to try and figure out whats going on. If I leave the blower on the first notch the air is lukewarm at best, the higher I turn the blower the cooler the air gets. I checked the adjustment on the heater control cables behind the glove box, they were slightly off but correcting them made no difference. I checked the 2 water hoses running thru the firewall to the heater core, they are both warm so I assume they are not blocked and this is about the extent of what the Haynes manual suggested for troubleshooting the system. I was wondering if anyone else had a similar problem or any ideas what else I should check. Any help greatly appreciated
stubellos is offline   Reply With Quote
( Join the Elite Explorers )
Old 01-08-2010, 09:31 PM   #2
BrianDye
I'll have another...
Monroe, MI
BrianDye's Avatar
2006 XLT
Vehicle Specs
Quoted: 77 Post(s)
Ive literally had the SAME problems in the last 3 vehicles ive owned.
My new explorer (95) isnt AS bad, but I can really only have it on level 3, without the air feeling like room temp. Plus it takes its sweet time warming up, im gonna be following this thread to hopefully get a few pointers lol.
Could be:
-Thermostat
-Bad water pump
-Bad/Clogged coolant/radiator
Thats about all I know when it comes to heaters, and I keep meaning to check my coolant praying that that's the problem lol
__________________
06 Charcoal Beige XLT
Debadged in back, removed pin stripe, tinted fogs, LED conversion, black headlights w/Morimoto Mini retro, xB LED Halos, black bentley style grille, Tan cloth interior swapped w/black carpet, black leather/power/heated seats from a Limited
BrianDye is offline   Reply With Quote
Old 01-08-2010, 10:06 PM   #3
bisjoe
Sammamish, WA
Vehicle Specs
Quoted: 0 Post(s)
Quote:
When the engine is warmed up and all is functioning, those hoses should be HOT not warm. Most likely cause is the thermostat stuck open, and that's a fairly easy and cheap one to check and fix. It could also be a clogged heater core, enough gets through to make the outlet hose warm but not to heat the air in the box passing by it.
Also check that manual to see if that year has a heater control valve, even if the control seems to be working the valve could be stuck or open (not enough coolant flowing through).
__________________
2007 Ranger XLT 4x4.
bisjoe is offline   Reply With Quote
Old 01-09-2010, 04:52 AM   #4
94explorerEB
auburn, alabama
1994 xlt 4x4
Vehicle Specs
Quoted: 4 Post(s)
Sounds like the exact same problem I had. It turned out to be a bad thermostat it actually got hung up sideways. I'll never buy another one from autozone cause this happened twice two different thermostats. I picked one up from ford and havn't had another problem with it.
94explorerEB is offline   Reply With Quote
Old 01-09-2010, 10:46 AM   #5
BrianDye
Monroe, MI
BrianDye's Avatar
2006 XLT
Vehicle Specs
Quoted: 77 Post(s)
Hm...I never thought about a faulty tstat, how much did it run at the dealer?
__________________
Old 01-09-2010, 03:56 PM   #6
stubellos
1993 XLT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Hey thanks for the input. It is probably the thermostat I replaced it last winter with one from Auto Zone and it continued to do the same thing but after reading 94exlorerEB's post I will get another from the dealership and see if that fixes the problem. I was wondering about bisjoe's comment on the heater control valve. I can find no mention of it in the haynes manual but on Auto Zone's website they do sell it. Does anyone know whether there is such a part on this year ex and if so where it would be located? Also is there a blend door that I should look into or is that on later years only? Thanks again for the help.
Old 01-09-2010, 10:37 PM   #7
94explorerEB
auburn, alabama
1994 xlt 4x4
Vehicle Specs
Quoted: 4 Post(s)
Sorry I don't remember what it cost from the dealer its been about two years. It was a good bit more than the ones from autozone if I remember right.
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
