Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Projects - Hobbies and Additional Topics > Projects - Hobbies - DIY > Home Improvement
Notices
Home Improvement Working on a project around the house, condo, or apartment? Questions about a home improvment project? This is the place!
House plans that allow walkout basement tall enough for car lift???
Reply
Thread Tools
Old 01-13-2010, 08:25 PM   #1
bronco2guy
Built not bought.
Columbia, MO
bronco2guy's Avatar
91 Ford Explorer
Vehicle Specs
(Original Poster)
In a couple years we're thinking about building new house on parents farm, trying to avoid building house and shop, by building 2story house on foundation/basement with walk out backside, but the catch is on 1 end or the other i want to have a car lift in basement, so Im thinking ceiling height will have to be around 13ft? Has any seen anything like this or have any pics?
Thanks for your input.
bronco2guy is offline   Reply With Quote
Old 01-13-2010, 08:28 PM   #2
explorerguy89
Marlton, NJ
1999 xls and 2000 xlt
Vehicle Specs
i havent seen but sounds pretty freakin sweet =p so i say gopher it
__________________
"v8powerbaby[04:48pm] : explorerguy i will make love to you for helping me fix that"
99' ex. xls been through hell and back
Quote:
Originally Posted by benji
I LOVE PINK FUZZY HATS!!
Quote:
Originally Posted by Tim Shaw
great.....bought the wrong deodorant. now i smell like watermelon bubblegum.....
explorerguy89 is offline   Reply With Quote
Old 01-13-2010, 08:36 PM   #3
BrooklynBay
Aerostar Forum Moderator
Brooklyn, NY
BrooklynBay's Avatar
88 89 93 95 96 Aerostars
Vehicle Specs
You will need to make a driveway with a 45* incline, and sufficient water drainage. Underground heating of that slope with Pex tubing would be a good idea for the winter months where snow could accumulate, and cause a hazardous condition. I know people with this kind of driveway. They had to replace their garage door several times because their vehicle slipped down the slope.
BrooklynBay is online now   Reply With Quote
Old 01-13-2010, 08:40 PM   #4
bronco2guy
Built not bought.
Columbia, MO
bronco2guy's Avatar
91 Ford Explorer
Vehicle Specs
(Original Poster)
Hmm, wouldnt be sloped much??
I will try and find house examples, but may end up desinging it completely myself
Old 01-13-2010, 08:53 PM   #5
gmanpaint
Torsion Bar Free
since 2010
gmanpaint's Avatar
94 XLT-95 FX4
Vehicle Specs
I have worked in many a home with a 14' walkout basement with an attached garage. Main garage is directly above it. Corrugated Steel panel lined over steel truss, with full concrete pad above for main garage floor.
Very doable.
__________________
The Black Hole
Pugly
gmanpaint is offline   Reply With Quote
Old 01-13-2010, 09:20 PM   #6
my pos mounty
Land of Corruption
06 F-350
Vehicle Specs
Guess you could do something like a tri-level. The highest level being where your lift would be. That way you wouldnt have to have the heavy slope on the lot.
__________________
1999 Mountaineer, RIP
my pos mounty is offline   Reply With Quote
Old 01-14-2010, 05:30 AM   #7
unclemeat
Richmond, VA
unclemeat's Avatar
91 sport
Vehicle Specs
13-feet basement walls will be expensive. You have two choices, shorter reinforced concrete wall and framed wall for the additional height, or a tall massive reinforced concrete wall.
Attached garage will require minimum 1-hour fire rated walls (double sheetrock) with fire stop insulation. I used to think that attached garages were a good idea, but fire and ventelation have changed my mind. Insurance is higher for attached garage.
I would also consider constructing the basement floor with a sump instead of a lift.
A detached garage has some advantage. I like to do a spread footing with masonry foundation and slab on grade. The masonry wall height can be adjusted to allow 8-feet frame stud walls with a 13-feet total height wall. This may also work for atttached garage, but depending on the homesite 8-feet walls may not work.
I would also build your garage with an overhead steel I-beam for engine lift/removal.
unclemeat is offline   Reply With Quote
Old 01-14-2010, 08:48 AM   #8
BrooklynBay
Brooklyn, NY
Vehicle Specs
Wonderboard/cement board is fire resistant if you want to use this instead of sheetrock.
Old 01-14-2010, 07:42 PM   #9
bronco2guy
Built not bought.
Columbia, MO
bronco2guy's Avatar
91 Ford Explorer
Vehicle Specs
(Original Poster)
Measured brothers 2 post car lift today. Measures at 11 and 1/2 foot tall. so 12ft walls will be needed1st off, i will try and get some pics, several have mentioned slope this will not be a problem, where we want to put it. I will try and find detailed pics, from the front side will like like any other 2 story house with level yard and wrap around porch, not to concerned about having to double sheet rock or anything, we will do most of the labor.
Today walked around for couple hrs in 3million dollar house and got some ideas
Old 01-14-2010, 07:46 PM   #10
bronco2guy
Built not bought.
Columbia, MO
bronco2guy's Avatar
91 Ford Explorer
Vehicle Specs
(Original Poster)
The lift as connected center steel beam, that has thing that can slide back and forth and be used as engine hoist so no need for steel beam overhead in garage portion.
Meausred my current ceiling in my garage is 8ft 8in
with almost 8ft garage doors
this basement would have a 10x10 garage door on the bay with car lift
expense wise, some is more for being taller foundation and timber, but 1 insurance bill instead of 2, 1 outdoor wood furnace heats intire house and can run tubing in floor for heated floor
Old 01-15-2010, 05:21 AM   #11
unclemeat
Richmond, VA
unclemeat's Avatar
91 sport
Vehicle Specs
I did a 9-foot wall reinforced poured in place wall over the summer. It was pretty substainial. It was expensive to build. If you keep you wall 8-feet or less it can be built with solid grouted reinforced cinderblocks.
Old 01-15-2010, 07:50 AM   #12
gmanpaint
Torsion Bar Free
since 2010
gmanpaint's Avatar
94 XLT-95 FX4
Vehicle Specs
Wood burning furnace? For a new home? Why would you want that set up?
I am also trying to understand why the want for a basement shop in your home.
Whats wrong with a detached shop? No concrete walls to build. Keeping volatile chemicals separate from home makes me sleep better.
__________________
The Black Hole
Pugly
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
