| Stock 1991 - 1994 Explorers For questions related to the base Ford Explorer. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. No modification questions. |
Thread Tools |
#1 |
Wannabe Elite Explorer
Raisin city calif.
1993 xlt 4x4
Okay here is the deal I got a chance to buy a nice set of new rotors and pads. There for a 92-94 Ranger 4x4. I have a 93 Explorer and need rotors
bad as mine are warped (dang AZ rotors any way there junk! ) . Will they fit as in direct bolt on? Both Rotors and pads that is. Also I do have ABS and the 3.73 gears just in case it's needed info.If they will great as he needs some cash and I need to buy cheap so if it works were both going to be happy . Let me know ASAP if ya have the info. Thanks
#2 |
Unregistered
They should work as long as the Ranger has a Dana 35 axle. Gears don't matter, and neither should the ABS.
#3 |
New York, Wading River (that's on Long Island)
'91 Eddie Bauer
They offered two sizes on that year Ranger. A 11.25" Outer Diameter (axle code 84) and a 10.86 " diameter. The 11.25 are thicker too. I think the 11.25 Rotors are for rare Rangers.
The explorer has the 10.86 diameter Rotors only. The Ranger Rotors do not have the ABS Inner Sensor. So the part numbers are different then the Explorer but they will probably fit. The Pads are the same. __________________ Hoffm_t@tdipower.com 1975 CJ5 with fiberglass body and 350/345Hp chevy power:bought it in '79 1985 chevy stepside pickup, 300K on the clock: Original Owner 1989 Volvo 240 300K on the clock: Original Owner the 1991 X is my newbie with 331K on the clock: bought OCT.'03 with 183K http://home.lyse.net/brox/TonyPage4.html |
#4 |
Raisin city calif.
1993 xlt 4x4
Thanks. I have check a few sights and there is a mix on them the normal ones that is as some come up same part number for Explorer and Ranger as 4x4 with abs and others do not for the same rotors . But if they do not have the ABS I will just disable the front system or dose any one knows if that’s okay or do I have to disable the whole system?
#5 |
Unregistered
According to Hollander interchange, these will fit your '93:
With ABS: BRONCO II 90 4x4, from 10/89 (1-25/32" bearing) EXPLORER 91-92 4x4 MAZDA NAVAJO 91 (4x4) MAZDA NAVAJO 92 4x4 RANGER 90 4x4, from 10/89 (1-25/32" bearing) RANGER 91-92 4x4 Without ABS: EXPLORER 93 4x4, w/o ABS EXPLORER 94 4x4, exc. 4.10 ratio; w/o ABS The difference between the rotors is the ABS sensor ring. I'm sure there are more, but this is what Hollander lists. |
#6 |
Raisin city calif.
1993 xlt 4x4
Thank you that is just what I was tryiing to conferm! now to see if he still has them after I break my piggy bank .
You guys are the Bomb! |
| Thread Tools | |
