Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Explorer & Ranger Transmissions, Transfer Cases, & Differentials
Notices
Explorer & Ranger Transmissions, Transfer Cases, & Differentials Transmissions, Transfer Cases. A4LD, 4R70W, 4R44E, 4R55E, 5R44E, 5R55E, M5OD, BW 1354, Control Trac, GEM, AWD. Ford 8.8", Dana 35
98 4R70W no drive
Reply
Thread Tools
Old 01-22-2010, 10:28 PM   #1
iraceitall
Montana
98 EB
Vehicle Specs
(Original Poster)
Smile 98 4R70W no drive
I just bought a 98 EB, 5.0/4R70W, with a little trans problem. Vehicle has 202k, trans was rebuilt 30K ago. It will not take off in D (sometimes briefly, then it kicks out), but goes in R, 1, or 2. No codes for engine or trans, O/D light does not flash, but have ABS codes C1102 (accelerator sensor) and C1230 (rear speed sensor circuit fault) Fluid is clean and full.
I had it in the shop and tried powerbraking against D, it engaged, but then as I revved to 2000 rpm, it kicked out. I let off the gas, and it engaged again, hard.
Any ideas?
iraceitall is offline   Reply With Quote
Old 01-22-2010, 10:30 PM   #2
iraceitall
Montana
98 EB
Vehicle Specs
(Original Poster)
No fluid leaks, range switch is secure and wiring good, neutral start switch works properly, no bad fuses or wiring I could see either...
Old 01-26-2010, 05:43 PM   #3
V8BoatBuilder
Transplanted Bostonian
East Brunswick, NJ
V8BoatBuilder's Avatar
97 Mountaineer V8 4x4
Vehicle Specs
Could it be a linkage problem, where the trans selector is straddling N and D?
__________________
-Aaron
Off Road: 97' Mountaineer: V8, 4x4, 4.56s, 4" Superlift, SOA, TrXus 33x12.5 - Under The Knife
Work: 00' Ranger 4cyl 5spd, 02' Ford E250 5.4
On Road: 2006 VW Jetta TDI/6spd DSG. Fill it with diesel, please.
Octopus Yachts, LLC Engineered Marine Electrical Systems
V8BoatBuilder is offline   Reply With Quote
Old 03-06-2010, 05:27 PM   #4
iraceitall
Montana
98 EB
Vehicle Specs
(Original Poster)
UPDATE: fixed it!
After about 6 hours of online searching and phone calls, I decided to check the main pressure regulator valve in the valvebody, since the OE one is prone to wear. Sure enough it had a big worn spot. I ordered a new valve (Sonnax 76948-09) and gaskets, and it's working great!
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
