Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2002 - 2005 Explorer Mountaineer 3rd Generation > Stock 2002 - 2005 Explorers
Notices
Stock 2002 - 2005 Explorers Questions related to non-modified 2002 - 2005 Explorers and Mountaineers. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. Sport Trac and Sport use the 1995-2001 forum.
P0506 (IAC) and a collapsed vacuum elbow
Reply
Thread Tools
Old 01-25-2010, 07:50 AM   #1
sam&steph
Sunrise, FL
2003 Explorer Sport XLT
Vehicle Specs
(Original Poster)
Dk Exp P0506 (IAC) and a collapsed vacuum elbow
My '03 x sport (4.o sohc) started having rough starts after new battery was installed. Also noticed low rpm's and shuddering at idle. CEL P0506. Several threads here pointed to the IAC which I cleaned- With the plastic cover off, I noticed the 90 degree vacuum hose was collapsed as if the intake was suffocating. I know there are lots of threads about this but none addressed both issues. Would a bad PCV cause an airflow restriction? Im going to clean the MAF sensor next but the I feel something ielse is wrong. No apparent leaks or noises.
sam&steph is offline   Reply With Quote
Old 01-25-2010, 11:01 AM   #2
thepotroast
Asheville, NC
thepotroast's Avatar
3rd Gen EB 4x4 V8
Vehicle Specs
Quote:
Your PCV is located on the other side of the motor from your IAC. It's on the back of the intake manifold between the motor and the firewall on the drivers side. A bad PCV has little to do with idle issues. You could always replace the IAC, they are about $40 new online. Even with a freshly cleaned IAC, the actuator inside could still be failing...and with a collapsed hose as well, that sounds like your issue. I would just throw a new IAC on there, especially if your're throwing a code for it.
thepotroast is offline   Reply With Quote
Old 01-25-2010, 12:10 PM   #3
sam&steph
Sunrise, FL
Vehicle Specs
(Original Poster)
thanks for the advice potroast- I just replaced the soft hose with radiator hose (#80400, trimmed down a bit) and ordered the IAC.
Old 01-10-2011, 09:26 AM   #4
foxfire556
atlanta ga
2001 ranger 4x4
Vehicle Specs
dont mean to sound dumb but what is IAC?
foxfire556 is offline   Reply With Quote
Old 01-10-2011, 09:59 AM   #5
BigRondo
USMC 1371
Worcester, MA
BigRondo's Avatar
2002 XLT V6 4x4
Vehicle Specs
Quote:
Idle Air Control Valve.
__________________
Rondo - USMC, Combat Engineer, 1983-1996
Click here for a list of my write-ups!
Quote:
Originally Posted by FIND on 4-22-13
Don't mess with Boston. They will drop everything, hunt you down, and then go on like you never existed once they are done cleaning up the mess.
BigRondo is offline   Reply With Quote
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
