I was wondering if any body out there knew how to reset a alarm on 2002 ford ranger the anti theft light continues to blink at all times and my truck will not startneed help please.
might be moved to the wrong section?
Anyways, search on PATSII security. Sounds like the system lost is memory of the key.
not uncommon if you kill the battery.
If thats the case . . .stealership can fix it.
If the link doesn't work go to Advanced Search, Keyword "Pats" and Search Titles Only.
Sounds like you may have a problem with the key module, its often the culprit.
