KA3NXN
It's HER truck
- October 28, 2008
- Arvoinia, VA
- 2002 Explorer XLT, 4.6L
- Callsign
- KA3NXN
First of all, the specs. It's a 98 with a 4.0L with the "X" engine code. SOHV. It's a 2 wheel drive automatic with 135K miles on it. I had just gotten on the interstate and was accelerating up to highway speed when the engine just cut off. I had electrical power, so I tried to restart it but it would not fire. I ended up having to get it towed home. When I got it home I checked for both spark and fuel and I was getting neither. The tank was almost full so gas was not an issue. I disconnected the fuel line before the fuel filter and cranked it a few times to see if it was pumping fuel and it wasn't. I also checked for spark and had no spark either. Then I also tried connecting my code scanner to the truck to see if it had generated any codes and this is where it got interesting. The code scanner kept giving an error that "unable to communicate with computer" or something to that effect. I could not get the scanner to talk to the truck. Even after resetting the computer by disconnecting the battery cable. At one point I left the battery disconnected overnight, the scanner still won’t connect to the computer. Am I looking at a possible bad onboard computer? Any suggestions at all guys would be appreciated.
Thank you
Jaime
:exporange
Thank you
Jaime
:exporange
