Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Ford Explorer Sport Trac Forums > 2001-2005 Explorer Sport Trac
Notices
2001-2005 Explorer Sport Trac All questions related to the 2001-2005 Explorer Sport Trac model.
2003 Sport Trac Roof Water Leak
Reply
Thread Tools
Old 02-04-2010, 01:20 PM   #1
briandelaney
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
I have a 2003 Sport Trac with a Factory Sunroof. The Headliner is wet over the Left Rear Door (around the coat hook. Would anyone have any idea as to might be causing this leak and how to fix it?
briandelaney is offline   Reply With Quote
( Join the Elite Explorers )
Old 02-04-2010, 01:34 PM   #2
chezoom
plano texas
03' F-150 Super Crew
Vehicle Specs
Quoted: 0 Post(s)
check and make sure its closed all the way. check the weather stripping
__________________
2003 Ford F150 Super crew Lariat 2wd
chezoom is offline   Reply With Quote
Old 02-04-2010, 02:12 PM   #3
briandelaney
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Yes all that has been checked
Old 02-04-2010, 03:24 PM   #4
chezoom
plano texas
Vehicle Specs
Quoted: 0 Post(s)
has your truck been wrecked?
__________________
Old 02-04-2010, 03:29 PM   #5
briandelaney
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
No wrecks
Old 02-04-2010, 03:32 PM   #6
chezoom
plano texas
Vehicle Specs
Quoted: 0 Post(s)
when traveling down the road, do you here wind noise? with everything closed
__________________
Old 02-04-2010, 03:34 PM   #7
briandelaney
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
no windnoise
Old 02-04-2010, 03:40 PM   #8
chezoom
plano texas
Vehicle Specs
Quoted: 0 Post(s)
well im out of options. hopefully someone else will chime in
__________________
Old 02-04-2010, 03:43 PM   #9
briandelaney
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
OK thanks
Old 02-04-2010, 03:58 PM   #10
ncranchero
Co-moderator
Denver,NC
ncranchero's Avatar
'94 F150 4x4 SWB 4.9L
Vehicle Specs
Quoted: 28 Post(s)
It could be coming in around the roof rack mounting points and running to where you notice it being wet. You'll have to start with a helper and a garden hose, working from the lowest point ( weatherstrip area ) to the highest point ( roof rack ) and try to only wet one rack mounting point at a time until you strike water.
__________________
'14 Transit Connect 2.5L 16 Valve DOHC Duratec
'02 Escape XLT 3.0L 24 Valve DOHC Duratec 160k
'94 F150 4x4 4.9L/5-speed 160K miles,
How to post photos
ncranchero is offline   Reply With Quote
Old 02-04-2010, 04:07 PM   #11
briandelaney
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Thats sort of what I was thinking. Do I need to drop the headliner? how difficult is it to drop it and how do you drop it?
Old 02-04-2010, 04:14 PM   #12
ncranchero
Co-moderator
Denver,NC
ncranchero's Avatar
Vehicle Specs
Quoted: 28 Post(s)
It's pretty involved and requires removing all of the plastic panels that touch it. The worst ones would be the rear corner panels. Before I did that I would just unbolt the roof rack, apply silicone sealer liberally to the bolt holes and put it back on. Let it dry and do the water hose test or go through the car wash. I mean, it has to be coming from the roof rack or the weatherstripping. The 3rd brake light, the rear window and the trim piece between the roof rack and the back window just don't seem possible as leaking and running over the door.
__________________
How to post photos
Old 02-05-2010, 05:58 AM   #13
briandelaney
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Thats sort of what I was thinking. I know it is not the 3rd brake light because I fixed that one last summer. Are there any rear drains in the sunroof back there?
Old 02-05-2010, 06:05 AM   #14
ncranchero
Co-moderator
Denver,NC
ncranchero's Avatar
Vehicle Specs
Quoted: 28 Post(s)
Ah, I somehow missed the first statement ....... the sunroof one. There are drains on all four corners of the sunroof. I've never been into one of those so all I have is a illustration.
__________________
How to post photos
Old 02-05-2010, 06:44 AM   #15
briandelaney
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Thanks This definately helps, now I just have to wait for the weather to warm up
Old 09-08-2011, 02:17 AM   #16
reddvll
Ga
2005 Ford Sports Trac
Vehicle Specs
Quoted: 0 Post(s)
if u still have the illustration on the drain plug can u send them to gsmitty1@gmail.com
reddvll is offline   Reply With Quote
Old 09-08-2011, 11:50 AM   #17
brianwsnc
Winston Salem, NC
2004 Sport Trac Adrenlin
Vehicle Specs
Quoted: 0 Post(s)
I think mine is leaking in the same spot. I noticed some water on the back behind the rear seats on the plastic ledge...
what did you find
brianwsnc is offline   Reply With Quote
Old 09-08-2011, 02:02 PM   #18
bedwards
Alabama
05 Sport Trac
Vehicle Specs
Quoted: 0 Post(s)
Quote:
what did you find
Mine leaked there and traced it to the 3rd tail light.
be
bedwards is offline   Reply With Quote
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
