Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2002 - 2005 Explorer Mountaineer 3rd Generation > Stock 2002 - 2005 Explorers
Notices
Stock 2002 - 2005 Explorers Questions related to non-modified 2002 - 2005 Explorers and Mountaineers. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. Sport Trac and Sport use the 1995-2001 forum.
2002 Ford Explorer won't start.
Reply
Thread Tools
Old 02-04-2010, 07:04 PM   #1
brock2280
erie pa
2002 explorer
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Angry 2002 Ford Explorer won't start.
I have a 2002 ford explorer and it will crank but not start. I have replaced the battery, plugs, wires, fuel filter. The pump is kicking on and I have spark. Any suggestions out there? I have also checked the inertia switch, and when hooked up to the OBD I dont get any codes....Please Help
brock2280 is offline   Reply With Quote
( Join the Elite Explorers )
Old 02-04-2010, 07:43 PM   #2
cityworker
petaluma CA
00
Vehicle Specs
Quoted: 0 Post(s)
hello I don't know if this will help but when I had a simmilar problem it was the key not playing nicley with the computer
cityworker is offline   Reply With Quote
Old 02-04-2010, 07:47 PM   #3
BrooklynBay
Brooklyn, NY
BrooklynBay's Avatar
88 89 93 95 96 Aerostars
Vehicle Specs
Quoted: 417 Post(s)
Welcome to this forum! I've moved your thread into the stock 2002-2005 section. Your vehicle uses the OBD-II system. You said that the fuel pump is turning on. How much pressure is in your fuel rail?
BrooklynBay is offline   Reply With Quote
Old 02-04-2010, 08:45 PM   #4
thepotroast
Asheville, NC
3rd Gen EB 4x4 V8
Vehicle Specs
Quoted: 29 Post(s)
Check your fuel pressure. Just because you hear the fuel pump, doesn't mean it's pumping the correct pressure. I just had the same issue you're describing, had a bad fuel pump (no pressure....and yes I could hear it kick on when I turned my ignition on), and also a bad coolant temp sensor which affects the ECU on the vehicle in the amount of fuel/air it delivers.
You may also want to clean your MAF and IAC...easy to do both.
thepotroast is offline   Reply With Quote
Old 02-04-2010, 09:45 PM   #5
brock2280
erie pa
2002 explorer
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Thank you for all of your suggestions. I will test the fuel pressure and get back with you guys. (thepotroast) should i spray electrical cleaner on both ends of the MAF and IAC plugs? or is there another way i can do it. thanks again for replying so quickly great site first one i joined for this.
Old 02-06-2010, 12:08 PM   #6
Powell1963
Illinois
2002 Ford Explorer
Vehicle Specs
Quoted: 0 Post(s)
I have the same problem as brock2280, but the car starts sometimes. It always starts when it's with a mechanic. After it refused to start 2 weeks ago, we got it to the mechanic who kept it a week. It started everyday. I then went out-of-town (300 miles). Worked fine the whole way - stopped to get gas - it started right up. Spend the weekend driving different places. No problem until we were packed up ready to go. Refused to start. Turns over strongly, it just doesn't catch to actually start. We had to rent a car to get back home. My parents are taking the car to a mechanic there, but that mechanic is also saying that if the car starts everyday for him, there's nothing he can do. Is there anything besides the above that I should look for?
Powell1963 is offline   Reply With Quote
Old 02-06-2010, 12:11 PM   #7
Mirge
Tulsa, OK
'98 Eddie Bauer
Vehicle Specs
Quoted: 0 Post(s)
Quote:
Would be worthwhile to check/clean all electrical connections (battery terminal posts, cables, etc).
__________________
1998 Eddie Bauer 4x4
Mirge is offline   Reply With Quote
Old 02-06-2010, 01:18 PM   #8
brock2280
erie pa
2002 explorer
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
the Gauge is reading 150 on the fuel rail
Old 02-06-2010, 02:48 PM   #9
brock2280
erie pa
2002 explorer
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
sorry i meant 150 psi in all the cylinders. i have done everything possible to get this to run. I have fuel, spark, and it it mechanically sound. how do I check relays if they are bad? And could it have anything to do with the cam sensor? or any other sensor that would prevent it from starting.
Old 02-06-2010, 04:09 PM   #10
2000StreetRod
Greenville, SC
2000StreetRod's Avatar
00 Sport FI,03 Limited V8
Vehicle Specs
Quoted: 45 Post(s)
engine no start procedure
You may get some ideas from my Engine No Start Procedure even though it's written for my 2000 SOHC. Click on "My Helpful Threads" in my signature.
2000StreetRod is offline   Reply With Quote
Old 02-06-2010, 08:25 PM   #11
brock2280
erie pa
2002 explorer
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
ok now I have found that I have no compression in cylinders 4, 5, and 6. I heard this might be the timing chain, from what I have read in other threads this could be a very bad thing...What are you guys thinking? Please give me feedback I am ready to rip my hair out!!
Old 02-08-2010, 06:41 PM   #12
2000StreetRod
Greenville, SC
Vehicle Specs
Quoted: 45 Post(s)
Left cam rotation
I'm afraid that if you've lost compression on all of the left bank cylinders that you may indeed have timing chain failure. For an easy confirmation remove the oil filler cap, shine a light in and rotate the crank. If the cam doesn't move then either the upper left chain has failed or the lower front chain has failed. If you still have compression of the right bank, then you can eliminate the lower front chain as a possible failure.
Old 02-08-2010, 06:45 PM   #13
BigFellor
Shittsburgh, PA
2002 Explorer XLS
Vehicle Specs
Quoted: 13 Post(s)
Forgive my ignorance on this motor, but how does a timing chain have anything to do with no compression?
BigFellor is offline   Reply With Quote
Old 02-09-2010, 06:31 AM   #14
2000StreetRod
Greenville, SC
Vehicle Specs
Quoted: 45 Post(s)
Timing chain & compression
If the timing chain for one bank breaks then the camshaft for that bank cannot rotate. If the camshaft doesn't rotate then the valves don't open and close. In order for there to be compression the intake valve must open on the intake stroke and both the intake and exhaust valves must be closed on the compression stroke.
Old 03-24-2015, 02:07 AM   #15
Willick1
Long Beach, CA
2002 ford explorer xls
Vehicle Specs
Quoted: 0 Post(s)
is it automatic or manual transmission? if it's manual transmission try you and your friends pushing it and then popping the clutch.
Willick1 is offline   Reply With Quote
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
