Ford Explorer Sport Trac Ford Ranger Mazda Navajo Mercury Mountaineer, Ford Aerostar Message Board®
Ford Explorer, Sport Trac, Mercury Mountaineer, Mazda Navajo, Ford Ranger, Ford Aerostar SUV Enthusiast Forums
Join the "Elite Explorers Today!"
Explorer4x4 Sportrucks 2011 Explorer Forums Elite Membership Product Reviews Explorer Photo Gallery
Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Repair - Troubleshooting - Modifications & Detailing Forums > 1991 - 1994 Explorer Ranger Navajo > Stock 1991 - 1994 Explorers
Notices
Stock 1991 - 1994 Explorers For questions related to the base Ford Explorer. No modification questions.
Reply
Thread Tools
Old 02-09-2010, 06:18 PM   #1
allenhudson91
Birmingham, Al
1993 4.0 XLT
Vehicle Specs
Dk Exp 1993 Explorer Engine control Computer
Can someone please tell me where the electrical engine control unit is located on a 1993 ford explorer 4.0? A picture or diagram would be nice.
allenhudson91 is offline   Reply With Quote
Sponsored Links (Less Ads)
Old 02-09-2010, 07:05 PM   #2
growler
fenton, mi
93 ranger extended cab 4x
Vehicle Specs
if its anything like a 93 ranger, the powertrain control module (PCM), is down on the driver side firewall under the cruise control vacuum canister, and the ignition control module is under the dash board behind the ashtray.
growler is offline   Reply With Quote
Old 02-09-2010, 07:18 PM   #3
thomasfortney
Dover, mn
97 xlt
Vehicle Specs
probably behind passenger side kick panel, It could possibly be in the engine compartment. Look for a large electrical plug coming out of the firewall on the passenger side It might be attached there or like i said behind the kick panel.
thomasfortney is offline   Reply With Quote
Old 02-09-2010, 08:37 PM   #4
TedJ
Fair Lawn, NJ
TedJ's Avatar
'94 Sport
Vehicle Specs
On the Explorer it's in the kick panel to the right of the passenger's feet, and nowhere else. Once you take the panel off it's the big shiny box right there....
TedJ is offline   Reply With Quote
Old 02-10-2010, 06:19 AM   #5
allenhudson91
Birmingham, Al
1993 4.0 XLT
Vehicle Specs
oh, okay. I didn't take that panel off.
Old 02-10-2010, 03:22 PM   #6
allenhudson91
Birmingham, Al
1993 4.0 XLT
Vehicle Specs
Does anybody know if the EEC can cause all my plugs to fuel foul on the passenger side of the engine? They foul within 10 minutes.
Old 02-10-2010, 03:57 PM   #7
Maniak
Moderator-Stock 91-94
Vail, Arizona
Maniak's Avatar
1992 XLT 4x4
Vehicle Specs
Bad wiring or an ECU can do that.
IIRC that is sort of what happened to DannyBoy. We put a new to him motor in his truck and it was filling a cylinder up with fuel. He swapped out the wiring and the computer and it stopped dumping fuel into the motor. It was dumping enough to hydrolock the motor.
~Mark
Maniak is offline   Reply With Quote
Old 02-10-2010, 04:29 PM   #8
Turdle
ARCHELON
Humboldt, Ks
Turdle's Avatar
93 XLT Convertible
Vehicle Specs
I think I found Danny's problem in the harness he sent me. I found chaffed wires going to the injectors-
93 is batch fire, and therefore the injector wiring is all tied together on each bank. Now, if the tan wire, just one of them, is chaffed, and contacts ground, this will "turn on" the entire bank of injectors. I found such chaffing in that harness he sent.
I didn't think it was important at the time, as I had another engine harness to choose from. And it was already fixed. Besides, when I try to explain stuff I tend to confuse the issue further.
OK,
On the alternator bracket you will see 2 large electrical connectors. these go to the "engine harness"
Trace them up to where the injector plugs branch out, up in the area of the water neck. It was in this area I found green patina on the exposed wiring, and a few bare wires touching each other.
Turdle is offline   Reply With Quote
Old 02-10-2010, 08:53 PM   #9
Turdle
ARCHELON
Humboldt, Ks
Turdle's Avatar
93 XLT Convertible
Vehicle Specs
Slight correction
Look in the loom where the Throttle position sensor, IAC valve and IAT sensor wires separate from the fuel injector wiring bundle. You might have to dig into the plastic conduit. I took a picture and will get it uploaded soon
Reply
Tags
1993, computer, ecu, engine, explorer
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
Copyright 2010 - 1996 Rick Horwitz Photography
Modifying the suspension on any vehicle will cause changes to it's handling characteristics.
