| EF Swag Store | 2013 Ford Explorer | Forums | Elite Membership | Chat Room | My Posts | Reviews | Explorer Photo Gallery |
| Explorer & Ranger Transmissions, Transfer Cases, & Differentials Transmissions, Transfer Cases. A4LD, 4R70W, 4R44E, 4R55E, 5R44E, 5R55E, M5OD, BW 1354, Control Trac, GEM, AWD. Ford 8.8", Dana 35 |
Thread Tools |
#1 |
Wannabe Elite Explorer
indianapolis, IN
95 x,88 ranger, and 98 x
I have a whining sound that sounds kinda like a drill but much louder coming from under my x. I only hear it when a release the throttle from speeds over 55 mph. It will stop if i touch the gas and start back up when i release. My x is a 98 sohc v6 4x4 control trac with 4a/4h/4l. Any ideas? Is it safe to drive?
#2 |
Melbourne, AUS
04 Limited
I've been looking for a little while to find some help with this topic but I'm almost at a 'Dead End'.
I drive a 2004 4.6l Limited and it has the SAME problem. In the last couple of days though it has started to progress to a "grind and THUMP, grind and THUMP, etc" up until I accelerate again, then it goes away. But when I let go of the throttle and coast, either on a downhill or coming to a stop, it starts back up again. I was told it could be a problem in the transfer case. That means $$$$. Someone else told me it could be the front universal joint. Can anyone help? |
#3 | ||
Village Idiot
Trenton, MI
98 ExSport, '00 F-150
Quote:
Quote:
edit: Just thinking, maybe it could be a similar t-case-related issue? I'm not familiar with the t-case on the early 3rd-gens... Sorry. __________________ -98 Explorer Sport, 4.0 SOHC, K&N drop-in, LEMON in progress! -'00 F-150, mucho mods "We need to allow Darwinism take it's course and let the idiots weed themselves out of existance." ~ Rick Horwitz We must believe in free will — we have no choice. ~ Isaac Bashevis Singer I'm not smart, just a resourceful idiot. ~ Me |
#4 |
Johnson City/Binghamton,NY
1998 XLT
I had the same problem, the transfer case needed to be replaced. Almost every time I'd let off the throttle and it would dip below 2k rpm's it would wind and whine until I tapped the gas.
#5 |
Melbourne, AUS
04 Limited
The noise is coming from the front of the truck. I can even feel it in the brake pedal AND of course it jerks the steering.
So gijoecam, you don't think it could be the front universal joint??? |
#6 |
Village Idiot
Trenton, MI
I wouldn't expect that. A u-joint isn't going to care whether you're on or off the gas. I would expect a bad u-joint to make that noise all the time (and it'll usually be more of a rumble than a buzzing...)
#7 |
Las Flores, CA
98 XLT 4X4 sohc
Second those thoughts. Ring and pinion or T-case.
__________________ Joe 98 XLT 4X4 sohc TT, Custom Deaver leafs, 31x10.5 BFG's Custom skid plates, recovery shackles Defender rack, Warn transformer mount and winch |
#8 |
Village Idiot
Trenton, MI
How would a ring and pinion make noise when the truck isn't moving?
#9 |
Hickory, NC
'98 XLT, '91 EB
That makes it a completly different problem than T-Case, gotta be something in the front drivetrain area (Hub, brakes, U Joints, axle).
__________________ '91 EB 4.0 OHV 4x4 31x10.5 Maxxis Bighorn's Uwharrie 2010 BrooklynBay's List of Useful Threads |
#10 | |
Hickory, NC
'98 XLT, '91 EB
#11 |
Las Flores, CA
98 XLT 4X4 sohc
It is moving. He said it does it while coasting, then goes away under throttle.
#12 |
indianapolis, IN
update
just an update the t-case whine off and on for months, got better after i changed the fluid! but finally kicked the bucket today
Was only able to get it home by driving in 4 low for 15 long miles at 15 to 20 mph just under 2000 rpms. Now for the the fun but dreaded trip to the junk yard, $100 used vs. 900 new unless there are any other suggestions
| Tags |
| bearings, drive train, transfer case |
| Thread Tools | |
