codes ABS C1102 and C1230 | Ford Explorer Forums
colormadera
Guatemala
93 xlt
I would like to know what means the description of each one. Example: code C1102 says "Acceleration switch circuit failure" but... what it means? Where is it? What do I have to check on it? What do I have to do to fix it?
ABS Code C1102 C1230
Accelerator speed sensor, located on top of the read differential. 18.00 part, replaced it, light went out.
2000 Explorer XLT 4.0 Sohc
I have the same 2 codes, I replaced the rear sensor and abs light is still on...my next step would be to check the resistance??
