Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer - Sport thru '03 - 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
Air Bag Code 42 nightmare
Reply
Thread Tools
Old 02-19-2010, 04:51 PM   #1
thumper477
Telford,Tn
1997 5.0 AWD XLT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
My airbag light has been bilnking a code 42 since I bought the ex 2 years ago.I finally got tired of the light being on (and the airbags not working in an accident)so I bought some used sensors on fleabay.Being that the code 42 pertains to the sensor on the left front I figured that would fix it.Well,changing the sensor is a PITA.You have to take out the grille and lights on that side as well as moving some splash shields.The bolts holding the sensor bracket were really stuck and required much force and liberal PB Blaster to come out.When I keyed it up with the "new" sensor installed I was pissed to find that the code 42 was still there.I cleared the code with my scanner but it came right back immediately.Crap.Now what?Maybe I got a bad used part?Well,I tested both my old and the "new" sensors as per the shop manual test and both tested good.OK,so I go back to my computer and print out the Ford pinpoint test for the code 42.I had to pull the right kick panel and unbolt the airbag computer from the cowl(another PITA!).After unplugging the connectors from the air bag module I was instructed to run resistance checks on the harness that connects the computer to the left sensor.It turned out that one of the wires was open in the wiring harness somewhere between the computer and the sensor connector.Not wanting to spend 3 days pulling harnesses out of my 200k mile truck to find the break in the wire I elected to run a new wire instead.It works fine now and I feel more comfortable knowing that the airbags will function now if I crash.Total time spent,3 hours.
thumper477 is offline   Reply With Quote
( Join the Elite Explorers )
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
