Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1991 - 1994 Explorer Ranger Navajo 1st Generation > Stock 1991 - 1994 Explorers
Notices
Stock 1991 - 1994 Explorers For questions related to the base Ford Explorer. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. No modification questions.
Engine wiring harness routing on a 1994 Explorer.
Reply
Thread Tools
Old 02-20-2010, 04:08 AM   #1
jimoswald
Monterey, California
1994 Explorer
Vehicle Specs
(Original Poster)
Anyone have photos of the 4.0 1994 explorer engine wiring harness routing and connector locations as you rebuild the engine? Like photos of the wiring with the lower intake manifold on, then the upper half on, etc.
jimoswald is offline   Reply With Quote
Old 02-20-2010, 08:01 PM   #2
BrooklynBay
Aerostar Forum Moderator
Brooklyn, NY
BrooklynBay's Avatar
88 89 93 95 96 Aerostars
Vehicle Specs
Welcome to this forum! I've moved your thread into the stock 91-94 section.
BrooklynBay is offline   Reply With Quote
Old 02-20-2010, 11:35 PM   #3
SuRrEaLNJ
hail to the king, baby!
out of my mind...
SuRrEaLNJ's Avatar
MUNK 07 Focus 97 XL1200C
Vehicle Specs
if your looking at hooking a motor that was pulled back up honestly the best thing to do is start at one end of the harness and just go from there. each wire is only so long, swing it in an arc from where it branches off and your bound to find its mate. most of the harness will kinda fall into place as you go along. its time consuming but it works
__________________
Quote:
Originally Posted by Spas View Post
You are all lunatics, and Jay is your king!
BEN REALLY REALLY LOVES PINK
SuRrEaLNJ loves Hannah Montana
SuRrEaLNJ is online now   Reply With Quote
Old 02-24-2010, 07:12 PM   #4
jimoswald
1994 Explorer
Vehicle Specs
(Original Poster)
Thanks. I got it! I had to take the intake manifold top off again to route the wires. The one I was missing turned out to connect below the water pump (the tach I think). I had it way over by the steering column. In doing so, I was able to find about 10 other things that were worth checking and tightening so I am about ready to fire it up after the head job. I have a leaking power steering unit - I picked up a pump at the junk yard but now I think the actual steering box is the culprit. That can't be easy to change. It started leaking a few months ago when I tightened the screw on the top (with the lock nut around it) to take us some slop in the steering - something I used to do on cars back in the 60s and 70s when they had excessive play. Could that have caused an internal leak? Anyway, I also stopped a few people in town who also have a 94 and found out where each of the vac lines come from and go to at the right rear of the engine. It should work fine - I'll let you know. Jim
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
