Go Back   Ford Explorer and Ranger Forums "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Under the Hood > Explorer, Ranger, A/C & Heater systems HVAC
Notices
Explorer, Ranger, A/C & Heater systems HVAC Ford Explorer, Ranger, Mountaineer, Bronco II, Air Conditioning and Heating Systems.
Heater Barely Heating and Temperature Gauge Going Up and Down
Reply
Thread Tools
Old 02-20-2010, 03:10 PM   #1
migar95gt
Georgia
1999 Eddie Bauer V8
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Not sure if this is a Heater problem or an engine cooling system problem, but I think there is a connection and I’ve been searching the forum for a while and can’t find an answer. My heater blows only warm air, not hot like it should. I can turn the temperature to cool and the A/C works just fine and blows very cold air. Turn it back to warm and still only blows warm, not Hot air like it used to.
So here’s my truck and the symptoms. I have a 96 Explorer with about 317000 miles. Last summer while at the beach I noticed the temperature gauge starting to move up and down. Normally it would sit around the “O” on “NORMAL”. It would slowly move from there up to between the “A” and “L” and then quickly drop back down to the “O”. It would stay there for a few minutes and then slowly move back up again. It would repeat this over and over, no matter how fast or slow I drove, and no matter if I was in traffic or not. I assumed it was a cooling system related problem, so when I got home, I flushed the system and changed the thermostat. Still the same thing. I took the radiator out and hosed it out good, put in another thermostat and changed the radiator hoses and serpentine belt. Still the same thing. I took the thermostat out completely. The temperature gauge stayed in the lower range all the time. No more moving up and down. So I left it like that until this past fall when it started getting chilly and we needed some heat. I put another new thermostat back in and the temp gauge started doing the same thing again. But now the heater doesn’t blow very hot air. He A/C works just fine. The blend door actuator sounds to be working OK, but I have not opened the enclosure up to check the door. I also noticed a few days ago that as the temperature gauge goes up, the air from the vents gets warmer, then as the gauge drops back down, the air becomes less warm. I have used only Stant thermostat and was careful to get the bleed-by hole positioned correctly.
Any thoughts?
Thanks,
Mike
migar95gt is offline   Reply With Quote
( Join the Elite Explorers )
Old 02-20-2010, 03:46 PM   #2
gmanpaint
Torsion Bar Free
since 2010
gmanpaint's Avatar
94 XLT-95 FX4
Vehicle Specs
Quoted: 302 Post(s)
Heater core on the way out. Not a fun job on a 2nd gen from what I'm told.
__________________
The Black Hole
Pugly
gmanpaint is offline   Reply With Quote
Old 02-20-2010, 05:44 PM   #3
snoranger
Jackson, NJ
snoranger's Avatar
94 limited on 35's
Vehicle Specs
Quoted: 68 Post(s)
Sounds like low flow from the waterpump. Has it ever been replaced or is it original?
__________________
94 limited: 4.0l, 5spd swap, 6" skyjacker lift, 35x14.5 thornturds, 4.56s. 5.0 swap started (94 cobra 5.0, zf 5spd, np205)
95 xlt: stockish (SOHC swap, 30,000miles and I blew up the 3rd 4r55e...now collecting parts for a Cummins swap.)
Cummins 4BT swap thread
Ranger bed trailer build
snoranger is offline   Reply With Quote
Old 02-20-2010, 06:43 PM   #4
Allmost 50
Auburn Alabama
04 Explorer XLS
Vehicle Specs
Quoted: 0 Post(s)
With that many miles I guessing "head gasket". The compression leaking into the cooling system will block water flow allowing the radiator to get cooler then when the water does flow the temp gage will drop out. When it's up to operating temp. look inside the plastic coolant jug for 3 minutes while it's ideling. Do you see air bubbles? Bubbles not good.
__________________
04 Explorer XLS. 2x4. Purchased from a little old lady I knew. 67k
Allmost 50 is offline   Reply With Quote
Old 02-20-2010, 08:24 PM   #5
migar95gt
Georgia
1999 Eddie Bauer V8
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Thanks guys.
I can see where any of these 3 could cause one or the other of my problems, but do you think the problems are related, or just coincidence.
And I think I replaced the water pump about 100000 miles ago.
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
