#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Ford Explorer Sport Trac Forums > 2007 - 2010 Explorer Sport Trac
Notices
2007 - 2010 Explorer Sport Trac All questions about the stock 2006- 2010 Ford Explorer Sport Trac.
Tech Tip: Fuel filter change 07up Sport Trac
Reply
Thread Tools
Old 02-22-2010, 09:05 AM   #1
stylin99
Gastonia, NC
'08 5.0 Coyote Adrenalin
Vehicle Specs
Quoted: 4 Post(s)
(Original Poster)
I just changed my fuel filter on the STA at 23000 miles for added safety with all the changes I'm about to make. I thought I'd mention it here for others who want to do it themselves.
There are literally no special tools needed. Just make sure to wear safety glasses and have lots of rags available for the fuel that will come out.
It's located on the front of the gas tank. Remove the 2 10mm nuts holding the black plastic cover over the fuel filter to get to it. There are 2 quick disconnect clips to figure out, so there's no more need for a special fuel line tool. (Thank you Ford!)
The fuel line is under pressure, so either release your fuel pressure (you can pull the fuse for your fuel pump, start the car, and let it run till it dies), or just be ready for the little short pressurized squirt of fuel when you disconnect.
The white clip , simply press in on the 2 tabs until it pushes to the other side. Pull the fuel line off. The clip doesn't come all the way off the line, just moves out of the way so the fuel line can come loose.
The red clip was a bit trickier to understand. So I pulled out my Ford technical manuals so I didn't break it. See posted photo below for a diagram. Once you have the clip pushed back per the diagram, pull the fuel line off.
Replace the fuel filter.
Put the clips back on.
Replace the plastic cover with the 2 nuts.
You're done!
__________________
'08 Adrenalin, red
5.0L Coyote engine swap with manual 6spd trans
414 rwhp / 414 rwtq
'99 Mustang GT, Supercharged w/nitrous, 907 rwhp
stylin99 is offline   Reply With Quote
( Join the Elite Explorers )
Old 02-22-2010, 03:38 PM   #2
YeloPony
Central PA
07 Sport Trac Limited 4x4
Vehicle Specs
Quoted: 0 Post(s)
Thanks.. I'm at 56k now so I'm about to change it, I did my mustang a few weeks ago with no problems, but needed to buy that stupid tool, I was hoping I had another use for it (this truck) but I guess not! LOL
So are you saying you can change it without releaing the pressure? Is the a cut off switch or something to unplug? or just that fuse?
__________________
2007 Sport Trac 4x4 Limited 4.6L 3V V8 - ORANGE
2001 Mustang GT Vert 4.6L 2V V8 - YELLOW
YeloPony is offline   Reply With Quote
Old 02-23-2010, 11:56 AM   #3
eppd00
Sparta,Ga
08 Sport Trac Adrenalin
Vehicle Specs
Quoted: 20 Post(s)
eppd00
you should be able to use the inertia switch under the right kick panel to shut off the fuel pump.Run the engine for a few seconds to use up the fuel in the line
eppd00 is offline   Reply With Quote
Old 02-23-2010, 01:20 PM   #4
BigV
Dirty Jerzey
2008 Adrenalin
Vehicle Specs
Quoted: 5 Post(s)
I don't know this system but my cobra if you let it sit over night the pressure in the fuel line drops and you don't get a spurt of gas.
BigV is offline   Reply With Quote
Old 02-23-2010, 04:03 PM   #5
YeloPony
Central PA
Vehicle Specs
Quoted: 0 Post(s)
yeah my mustang has an inertia switch in the truck, you unplug it, run it till it dies then change the filter..
__________________
Old 02-23-2010, 04:24 PM   #6
stylin99
Gastonia, NC
Vehicle Specs
Quoted: 4 Post(s)
(Original Poster)
Yep inertia switch is another way that works.
__________________
'08 Adrenalin, red
414 rwhp / 414 rwtq
Old 02-24-2010, 10:38 AM   #7
GSUhooligan
Temple, GA
2007 Sport Trac
Vehicle Specs
Quoted: 0 Post(s)
Quote:
I was always told not to run an engine out of gas b/c is will f up the fuel injection. How is it kosher to kill the flow and run it till it dies?
GSUhooligan is offline   Reply With Quote
Old 02-24-2010, 10:43 AM   #8
stylin99
Gastonia, NC
Vehicle Specs
Quoted: 4 Post(s)
(Original Poster)
Quote:
It's actually in the technical manual to use that procedure by Ford techs directly.
Maybe the older fuel injection systems were a problem, but today's systems are designed for it. It's the same thing as switching fuel injectors, or changing a fuel filter. Gas runs out... air gets in the line. The system purges it thru the engine on the first couple revolutions and you're good to go.
Basically at idle, if the engine runs out of fuel, it has nothing to burn, and therefore can't ignite. Pistons stop moving, and it shuts off. Nothing bad happens. If you run out of fuel at wide open throttle, that's a different story.
__________________
'08 Adrenalin, red
414 rwhp / 414 rwtq
Old 02-24-2010, 10:44 AM   #9
GSUhooligan
Temple, GA
2007 Sport Trac
Vehicle Specs
Quoted: 0 Post(s)
Nice. Thanks for the info!
Old 02-24-2010, 10:50 AM   #10
eppd00
Sparta,Ga
Vehicle Specs
Quoted: 20 Post(s)
eppd00
With the engine cold and idling, all you are doing is relieving the pressure. What they are referring to is running out while driving and the engine hot and under a load....causes it to lean out
Old 03-11-2010, 02:54 PM   #11
GSUhooligan
Temple, GA
2007 Sport Trac
Vehicle Specs
Quoted: 0 Post(s)
You're done!
Your walk through helped alot! I just changed the filter with no problems, except I smelled like gas for 2 days. Thanks!
Old 03-11-2010, 03:02 PM   #12
stylin99
Gastonia, NC
Vehicle Specs
Quoted: 4 Post(s)
(Original Poster)
Awesome! Glad it helped. Just explain to people that you were born with gasoline in your blood. They'll understand the smell immediately if they are car nuts.
__________________
'08 Adrenalin, red
414 rwhp / 414 rwtq
Old 03-20-2010, 07:34 PM   #13
JoeExplorer2
Unregistered
Posts: n/a
Vehicle Specs
Quoted: Post(s)
Thank you for posting that tech tip stylin99.
Mine will be due to be changed soon.
Old 03-21-2010, 01:38 AM   #14
John_Rock
Elite In Memoriam
Houston, TX
John_Rock's Avatar
2001 Sexy Sport Trac 4x4
Vehicle Specs
Quoted: 0 Post(s)
Thanks for the info Stylin99. I just stickied the thread for preservation.
__________________
John_Rock - Mugshot - Click Here For info on my 2001 Sport Trac 4x4
- 2000 Explorer Limited AWD, 5.0L v8; 4.10 gears, KKM True Rev filter, B&M Tranny Super Cooler, Aux. Tranny Filter, Autometer Tranny & Water temp gauges.
Demon4x4.com
John_Rock is offline   Reply With Quote
Old 08-11-2010, 11:14 AM   #15
kingman109
Miramichi, NB, Canada
2007 XLT
Vehicle Specs
Quoted: 0 Post(s)
How much is a gas filter and how often should it be changed?
kingman109 is offline   Reply With Quote
Old 08-11-2010, 12:21 PM   #16
stylin99
Gastonia, NC
Vehicle Specs
Quoted: 4 Post(s)
(Original Poster)
Maybe $10-12. Ideally, every 30k miles or so, but most cars don't see problems with fuel filters until over 50k. It's a cheap part, so I try to change mine every 30k to ensure it's not clogged with fuel deposits.
__________________
'08 Adrenalin, red
414 rwhp / 414 rwtq
Old 08-14-2010, 05:52 PM   #17
NotATruckGuy
Madison, WI
'07 Sport Trac V-8 AWD
Vehicle Specs
Quoted: 0 Post(s)
I Wonder
Thanks for the tip. Mine's due for a change, and now I know where to look.
Regarding residual fuel pressure. The new returnless fuel systems rely on a tight seal on the gas cap and evaporative fuel recovery canister. Could opening the gas cap and/or the evap hose under the hood help?
__________________
-1997 Thunderbird LX V-8 (2V, pre-PI) w/ Torsen, 3.73 gears and Michelin X-Ice winter tires.
-2000 Mustang GT w/ C&L intake elbow, FRPP 75mm throttle body, Granatelli flash tune, Falken 452 UHP summer tires.
-2007 Explorer Sport Trac LTD, V-8 4x4, Falken ZE-912 all weather tires.
NotATruckGuy is offline   Reply With Quote
Old 03-06-2011, 12:45 PM   #18
BanGBloW
FL
'08 Sport Trac XLT
Vehicle Specs
Quoted: 0 Post(s)
i just changed my filter and it was easier than i thought. i pulled the fuse and started the truck but it wouldnt ignite fully. so i just pulled the filter and a small amount of fuel came out but i had my oil drip pan to catch it all. replaced the filter with a purolator and it fit right in. started the truck to check for leaks, no leaks, good to go.
thanks for the guide, that red clip was a little bit of a hassle but got it off nicely
__________________
'08 Sport Trac XLT 4.0L V6
MODS: K/N Filter // Zabteck throttle body //...
BanGBloW is offline   Reply With Quote
Old 03-07-2011, 05:07 PM   #19
Fredness
Sasquatch Country!
'05 Sport Trac Adrenalin
Vehicle Specs
Quoted: 1 Post(s)
Red clip is tough the first time, but your directions helped a lot!
Here are some pix for those having problems finding it, or looking for more info...
Where? Here!
Overview:
Cover: 10mm Deep Well Socket works best...
Once the output connection is released, the filter can be moved inboard to give you more room in dealing with the red clip.
__________________
'05 Explorer Sport Trac Adrenalin, 4.0L SOHC, 5R55E, 4.10 open, 265/70R17's on Unique Matte 297's (TT, no lift, slight rub turning), Volant Intake, X3 tuner, CVB with Sonnax Mods, External Trans filter and B&M SuperCooler. 16 city/19 Hwy/14 E85 baseline.
My Garage
"Like" me on facebook
Fredness is offline   Reply With Quote
Old 04-19-2012, 05:20 PM   #20
illwill31
toronto ontario canada
2004 ford explorer
Vehicle Specs
Quoted: 0 Post(s)
I bought a after market fuel filter that replaces Ford's (GKI fuel filter part number FG1011).
I took it to Midas to instal the mechanic did not know how to take the retaining clip off the fuel line broke it, now it is Ty-wrapped, pissed off but lesson learned, i also had the maintenance manual which i totally forgot about, should have done this job myself. MAJOR LESSON get the proper/special tool to pop open the retaining clip.
Cheers .
illwill31 is offline   Reply With Quote
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
