Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2002 - 2005 Explorer Mountaineer 3rd Generation > Stock 2002 - 2005 Explorers
Notices
Stock 2002 - 2005 Explorers Questions related to non-modified 2002 - 2005 Explorers and Mountaineers. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. Sport Trac and Sport use the 1995-2001 forum.
2005 Ford Explorer cabin air filter location?
Reply
Thread Tools
Old 02-27-2010, 12:39 AM   #1
RMG1999
danbury, ct
2005 xlt
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Hi
Where is the cabin air filter for 2005 ford explorer located and how do i change it ?
what is the best recommended replacement unit (cost & performance)
RMG1999 is offline   Reply With Quote
( Join the Elite Explorers )
Old 02-27-2010, 07:42 PM   #2
BrooklynBay
Brooklyn, NY
BrooklynBay's Avatar
88 89 93 95 96 Aerostars
Vehicle Specs
Quoted: 411 Post(s)
Welcome to this forum! I've renamed your thread, and moved it into the stock 2002-2005 section.
BrooklynBay is offline   Reply With Quote
Old 02-28-2010, 07:59 AM   #3
thepotroast
Asheville, NC
3rd Gen EB 4x4 V8
Vehicle Specs
Quoted: 29 Post(s)
There isn't a cabin air filter in an 05 Explorer
thepotroast is offline   Reply With Quote
Old 02-28-2010, 08:55 AM   #4
badloser
Port St Lucie,FL
2015 Explorer XLT
Vehicle Specs
Quoted: 3 Post(s)
lol
badloser is offline   Reply With Quote
Old 02-28-2010, 06:27 PM   #5
blue_goose
WY
'02 4x4 4.0 200K
Vehicle Specs
Quoted: 5 Post(s)
Quote:
Huh? Hows that work? Please explain to those of us used to older cars the process of getting the dust and junk from going in the vents from outside.
blue_goose is offline   Reply With Quote
Old 03-09-2010, 09:24 PM   #6
Teaney
Tampa, FL
04 XLT
Vehicle Specs
Quoted: 0 Post(s)
I could use help with my 2004 Explorer. My dash vents seem to have very little air coming out. I can hear the fan speed up but no more air. Dropped the fan motor behind the Glove Box and put my hand up the tube and was able to bounce what looked like a filter and leaves started falling down. Got out as many as I could but there has to be an easier way to get the leaves out.
How do they get in there in the first place.
Any help would be appreciated.
Thanks,
Gary
Teaney is offline   Reply With Quote
Old 03-09-2010, 10:42 PM   #7
thepotroast
Asheville, NC
3rd Gen EB 4x4 V8
Vehicle Specs
Quoted: 29 Post(s)
Quote:
What does any of that have to do with a 2005 Explorer and that fact that it doesn't have a cabin air filter?
Old 03-09-2010, 11:15 PM   #8
BobWiersema
Chicago Burbs, Illinois
98 xlt 4.0L SOHC 4x4
Vehicle Specs
Quoted: 13 Post(s)
Just stick the garden hose in the defrost vents and let it run for an hour or so. Just dont forget to open a door so it can drain. I think this procedure applies to every year Explorer.
BobWiersema is offline   Reply With Quote
Old 03-10-2010, 05:52 AM   #9
Teaney
Tampa, FL
04 XLT
Vehicle Specs
Quoted: 0 Post(s)
Help with leaves in the air filter 2004 Explorer XLT
I'm new to the stuff and I could use help with my 2004 Explorer. My dash vents seem to have very little air coming out. I can hear the fan speed up but no more air. Dropped the fan motor behind the Glove Box and put my hand up the tube and was able to bounce what looked like a filter and leaves started falling down. Got out as many as I could but there has to be an easier way to get the leaves out. Does anyone know a solution? I can't see how to get to the filter to pull it out and clean it.
Thanks,
Gary
Old 06-05-2010, 12:08 PM   #10
WoodsGuy
Medina, Ohio
1999 Ford Explorer Sport
Vehicle Specs
Quoted: 0 Post(s)
Me too
I've got the same problem. I wish someone on this forum could answer you. You're not alone.
WoodsGuy is offline   Reply With Quote
Old 06-05-2010, 03:17 PM   #11
Teaney
Tampa, FL
04 XLT
Vehicle Specs
Quoted: 0 Post(s)
I'm working on a solution. I might try to open the glove box to get to the black plastic the filter is in, then cut a small rectangle flap out and vacume out the leaves.
I also discovered my outside air flap is stuck open. In Florida in 95 degree heat it makes my AC work way less effective so for $50 I'm going to have a buddy of my make it stick in the closed position so it only recycles air.
Hope we both get a better answer.
Gary
Old 06-05-2010, 11:35 PM   #12
BobWiersema
Vehicle Specs
Quoted: 13 Post(s)
Air Flow
Gary
There is no cabin filter in your Explorer. If you cut the plenum open you will find the evap. coil. If your outside air duct is not working you should check the pneumatic control valve that works that. As far as I know if you just pull the vacuum line off it it will close.
If your evap. coil is plugged up with dirt and stuff, that's a big deal to get it out and clean it.
I have a couple of ideas on cleaning the coil. If you want Ill post some pictures on how I cut mine open to repair the blend door. I think once you have the access opening cut in you can clean it up...
The problem is, there is no filter so everything will stick to the coil. Not good.
Not sure on your truck but I would pull the blower motor first from under the hood and take a look inside. Easy to do and you may find a lot of crap you can clean out. The blower wheel may also have a bunch of dirt in it.
I would just start there. Post back what you find. And trust me, cutting that plenum apart is not easy so start with the blower motor.
Good Luck and Go Hawks,
Bob
Old 06-06-2010, 11:30 AM   #13
thepotroast
Asheville, NC
3rd Gen EB 4x4 V8
Vehicle Specs
Quoted: 29 Post(s)
I'm not sure what part of the first reply to this I made back in February is confusing, when I said "there is no air cabin filter in an 05 Explorer"...or for that matter, an 02, 03, 04, etc
Old 06-13-2010, 05:39 AM   #14
RMG1999
danbury, ct
2005 xlt
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Bob
Thanks for your response Bob
I would really appreciate if you could post some photos as promised. Or just email them to me at rmg1999@hotmail.com if not possible to post.
Your help is much appreciated..
Old 06-13-2010, 08:15 AM   #15
dndsam
Arlington, Texas
2008 Explorer Limited
Vehicle Specs
Quoted: 0 Post(s)
There is no cabin air filter in the 02-05 Explorers.
As far as the fan blowing but no air moving, it sounds like your fresh air door is broken and has dropped down t the bottom restricting the air flow through the fan, happend to a friend of mine. Open your glove box all the way to look into the black grated area behind the glove box to see if it is present. If not then you will need to repair/replace it and there are numberous posts on this issue. If you do a search in this forum, you should find your answers.
dndsam is offline   Reply With Quote
Old 06-17-2010, 09:13 AM   #16
swalt
Toronto
2005 Sport Trac XLT
Vehicle Specs
Quoted: 0 Post(s)
I have not checked my 05 Sport Trac, but the air is flowing fine, so I have not been concerned. I had a similar problem on a 93 Grand Am GT. I ended up removing the blower motor under the hood, and removed the blower resistor so it did not get damaged. I then sprayed orange degreaser down the tube directly at the evaporator (I could just see it). I let is soak for a bit, then used the garden hose to flush the evaporator in spurts. You cannot use too much water at one time as it will fill up and run out your lower vents in the cabin, so I suggest putting some towels down if you get too much water in. The first time I did it, the water drained very slowly out the evaporator drain, so I shoved my shop vac down the tunnel and it sucked out a bunch of crap and cleared the blockage. I repeated this three times and then let it dry. My flow came back as good as new.
I'm not sure if this would work on the Sport Trac, but it is a bigger and costly job to try and remove the evaporator so for the bit of water mess it might be worth a shot.
swalt is offline   Reply With Quote
Old 09-12-2011, 04:06 PM   #17
nestor60
ford explorer 2005
Vehicle Specs
Quoted: 0 Post(s)
thanks for all advices.
nestor60 is offline   Reply With Quote
Old 09-14-2011, 03:35 PM   #18
BigRondo
USMC 1371
Worcester, MA
BigRondo's Avatar
2002 XLT V6 4x4
Vehicle Specs
Quoted: 94 Post(s)
You can add a cabin air filter yourself. Click here to go to the thread!
__________________
Rondo - USMC, Combat Engineer, 1983-1996
Click here for a list of my write-ups!
Quote:
Originally Posted by FIND on 4-22-13
Don't mess with Boston. They will drop everything, hunt you down, and then go on like you never existed once they are done cleaning up the mess.
BigRondo is offline   Reply With Quote
Reply
Tags
2005, air, cabin, explorer, filter
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
