| Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. |
Thread Tools |
#1 |
Wannabe Elite Explorer
md
1999 mercury mountaineer
engine won't turn over--new battery
I have a 1999 mercury mountaineer. It is an automatic with 5.0l eng. 150,000 miles. It has been sitting for 3 months. it ran fine b4 that. I tried to start it but it would not turn over. so I got a new battery. Now, The starter clicks and tries to turn the motor but it sounds like something is keeping the motor from turning over.Seems like I can hear a sound of metal to metal hitting. I banged on the starter with a hammer a few times. I was able to turn the motor with a large ratchet. Any suggestions???
thanks |
#2 |
Anchorage, Alaska
98 5.0L V8 AWD XLT
Put some heet in the gas tank (preferably put in fresh fuel, getting rid of the old), make sure you're getting spark. Maybe the starter has lost most of it's power also?
Can you also tell us what your voltage is looking like while the truck is sitting there, and what does it do when you try to start? __________________ Lifted 98 302 Ford: Fixed Or Repaired Daily. But still going, kicking and screaming all the way. =D Yeaaah. |
#3 |
md
Thanks for your reply. The engine won't crank at all. It s almost like the engine is locked up, but i can turn it with a wrench. Never a problem b4 it sat for 3 months. Could the starter be locked up??
#4 |
Anchorage, Alaska
98 5.0L V8 AWD XLT
That's a possibility. Swap in a new starter and see what happens, but not before you do some maintenance ... fluids might need to be changed after 3 months of sitting. And do something about that gas in the tank.
#5 |
Greenville, SC
2000 Sport SOHC 2WD
Sitting for 3 months
If, as you said, it ran fine three months ago then the only problem now should be battery charge/connection related. You've installed a new battery and I assume cleaned the connections. You can rotate the engine by hand but not with the starter. The starter gear may be stuck against the ring gear. I would disconnect the battery, remove the starter and have it tested. If it passes then clean the electrical connections to the starter before reinstalling it.
__________________ My Helpful Threads, Registry, 16.4/23 mpg, 3900 lbs, 5R55E, 3.73:1, 175 rwhp, Henson custom tune, CAI, Spectre air filter, Lightning 90mm MAF, 75mm throttle body, A/F ratio meter, synthetic oils, Accusump, 2 row radiator, 3+1 leaf springs, .75 inch drop, Edelbrock IAS lowering shocks, engine oil & ATF temp gauge & remote filters & coolers, remote crank |
#6 |
Perth Western Australia
98 Explorer
Make sure your battery clamps are connected tight. I jump started my friends car the other day then mine wouldn't crank next day. I tightened the clamps and fired fist kick.
If you can turn by hand it has to be charge related. The starter is high drain and with bad connections it will start to engage then stop that is the click sound |
#7 |
Tallahassee, FL
1997 Mountaineer 5.0L
+1 on checking the terminal clamps. Been there, done that.
Also, I had a similar problem awhile ago - disconnected, cleaned and reconnected both + and - cables at the battery and starter/grounds. The main cable connection to the starter was so corroded, I'm surprised it ever started. No problems since a good cleaning and tightly reconnected. You've checked all the fuses, right? Just to make sure you didn't short something while removing the old or putting the new one in? I've (on occasion) been less then dilligent about manhandling the battery/cables, and seen some sparks fly. |
#8 |
Tallahassee, FL
Also, I had a similar problem awhile ago - disconnected, cleaned and reconnected both + and - cables at the battery and starter/grounds. The main cable connection to the starter was so corroded, I'm surprised it ever started. No problems since a good cleaning and tightly reconnected. You've checked all the fuses, right? Just to make sure you didn't short something while removing the old or putting the new one in? I've (on occasion) been less then dilligent about manhandling the battery/cables, and seen some sparks fly. And, you're sure the new battery has a charge, yes? I've gotten some from wallyworld before that had a bad cell and/or wouldn't hold a charge. That is frusterating. |
#9 |
Birmingham AL
'97 XLT
i had same problem try starting in neutral or i would check your gears behind the dash make sure its not slipping out of park
do any of the electronics start? the 2nd gen explorers have an electronic fuel cut off so try it in neutral and see waht happens __________________ Patrick Markey 1997 Explorer XLT SOHC V6 205K miles. Stock....But not for long |
| Thread Tools | |
