| Explorer & Ranger Transmissions, Transfer Cases, & Differentials Transmissions, Transfer Cases. A4LD, 4R70W, 4R44E, 4R55E, 5R44E, 5R55E, M5OD, BW 1354, Control Trac, GEM, AWD. Ford 8.8", Dana 35 |
Thread Tools |
#1 |
Wannabe Elite Explorer
1996 sport
I have lost reverse and foredward high speed. I adjusted bands as per your post instructions. still, no foreward or reverse. The vehicle is a 96 ford explorer. need help.
#2 |
Aerostar Forum Moderator
Brooklyn, NY
88 89 93 95 96 Aerostars
Welcome to this forum! I've moved your thread into the transmission section. Check the pressure on your transmission with a 0 - 300 PSI gauge. It's possible that the pump broke or the EPC solenoid failed. A blown valve body gasket could cause a similar issue.
#3 |
1996 sport
I appreciate your response. Ithink you're right. A BLOWN PUMP. I'm taking it out and tearing it down. THANKS AGAIN.....
#4 |
Brooklyn, NY
You should test it with a pressure gauge before you tear it apart.
#5 |
Saint Paul, Minnesota
1995 Ford Explorer XLT
where is this pump located at? I also have the same issue, no drive/reverse... i have a 95 ford explorer with the 4r55e, i also have a small blow out in the valve body gasket, i have to let off the gas in order to let the transmission shift into 2nd gear... i have the new filter and gasket but now i need to know if i should also replace the pump , what do i do here? maybe its the same issue your having? idk...
#6 |
Brooklyn, NY
The pump is bolted to the rear of the bell housing.
| Tags |
| help me |
| Thread Tools | |
