#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer - Sport thru '03 - 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
2001 Explorer vacuum hose leak.
Reply
Thread Tools
Old 03-06-2010, 07:17 PM   #1
donaldwells
2001 explorer
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Have a 2001 Explorer and a few months ago the check engine light came on. I replaced the fuel cap, disconnected the battery to clear the code and things seemed ok. After a couple months the it came back on. I brought it to Auto-Zone and the tested it and said I have leak in one of the vacuum hoses. Does anyone know where I can find out which hoses to check and the best way to figure out if its leaking. Thanks.
donaldwells is offline   Reply With Quote
( Join the Elite Explorers )
Old 03-07-2010, 12:58 AM   #2
Rteas48192
Downriver, MI
2001 Explorer Sport 4X4
Vehicle Specs
Quoted: 0 Post(s)
US How to find a vaccum leak
Hello, I was just under the hood of the explorer doing this today. My source is Automotive forums. com. V6 4.0 SOHC This is best to do when the engine is first fired up (cold). Start it up, pop the hood (of Course) Spray starting fluid along the various vaccum hoses coming from the Air intake box. theres at least 2 there see if the idle increses at all. keep spraying you can go along the Fuel injectors, but kinda hard to get to some of them. also clean the MAF mass Airflow Sensor (right next to air box) with throttle body cleaner. I thought i had an upper intake gasket leak untill today. But we will see if the check engine light comes back on. It was running pretty smooth after this. I had the P1074 P1071? or something like that. It was Right bank lean, Left bank lean. Hope this helps good luck!!
Rteas48192 is offline   Reply With Quote
Old 03-08-2010, 08:51 PM   #3
BrooklynBay
Brooklyn, NY
BrooklynBay's Avatar
88 89 93 95 96 Aerostars
Vehicle Specs
Quoted: 380 Post(s)
Welcome to this forum! I've moved your thread into the stock 95-01 section. What are the code numbers?
BrooklynBay is online now   Reply With Quote
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
