| EF Swag Store | 2013 Ford Explorer | Forums | Elite Membership | Chat Room | My Posts | Reviews | Explorer Photo Gallery |
| Stock 2006 -2010 Explorers Stock 2006 -2010 Ford Explorer Forum. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. |
Thread Tools |
#1 |
Wannabe Elite Explorer
PA
2007 FORD EXPLORER
2007 radiator removal
Can someone tell me how the he!! to remove a radiator from a 2007 Ford explorer 4.0 V6. Removed the overflow, shrowd, tranny lines, hoses, splash guard, etc. The radiator was loose... loose I tell you!!! I could lift it about 3/4" out of the support but it hits a support bracket for the AC condensor at the bottom of the radistor support. Seems that the AC bracket projects over the radiator tank. The AC bracket and rad support are one integral cast plastic unit. I had this sucker loose and had to put it all back together. Have you ever seen a grown man cry? Seems that Ford, in all their infinite wisdom, couldn't make a radiator that was 1/2" skinnier so that it would just slide right out! NOOOOOOOOOOOOOOOO. That would be too freak'n easy. I'd like to strangle the engineer that designed this. Anybody have the answer? By the way...YES it's leaking.
#2 | |
West Friendship, MD
2006 Explorer XLT
Quote:
The two plastic tracks it runs on, make sure u loosen those bolts so they can shit back and forth... And then just keep playing with it. I think it took me a good 2 hours after everything was loose to finally manevure the radiator out. Just be patient, it does come out. haha __________________ 06 Explorer XLT 4.0 Chrome Bull Bar, Ironman Headlights w/ 10000k HID's, Flowmaster 40, K&N filter, Off-road lights 5% rear tint, 15% front. Viper 5701 Remote Start / Alarm, KKM Intake http://www.cardomain.com/ride/3251387 |
#3 | |
Johnstown, PA
2006 E.B.
Quote:
__________________ 2006 Eddie Bauer - 4.0L - Rear Seat DVD - Navigation |
#4 |
West Friendship, MD
2006 Explorer XLT
nope. condenser stayed in, but working around it in a pain. took me about 3 hours total to do the replacement, the transmission lines were the worst because my new radiator had different "hookups"
#5 |
Johnstown, PA
2006 E.B.
Did you have to add tranny fluid when you were done?
#6 |
West Friendship, MD
2006 Explorer XLT
I probably should have but didnt, since adding transmission fluid involves having a special piece of equipment since its a closed system. I probably lost 1/2-1 cup of transmission fluid doing the exchange, just have to be quick about it.
#7 |
Johnstown, PA
2006 E.B.
Did mine over the weekend. What a PITA. Ford could have made things much easier for a simple radiator. Where did you get your rad from?
#8 | |
West Friendship, MD
2006 Explorer XLT
Quote:
And I got my rad from napa, have an account their so everything is at cost...paid less than 200 I think....it was a while ago. __________________ 06 Explorer XLT 4.0 Chrome Bull Bar, Ironman Headlights w/ 10000k HID's, Flowmaster 40, K&N filter, Off-road lights 5% rear tint, 15% front. Viper 5701 Remote Start / Alarm, KKM Intake http://www.cardomain.com/ride/3251387 |
#9 | |
Johnstown, PA
2006 E.B.
Quote:
I got my rad off of proradiators.com. It was $105 with shipping with a lifetime warranty. Seemed awfully cheap, so we'll see! __________________ 2006 Eddie Bauer - 4.0L - Rear Seat DVD - Navigation |
#10 | |
West Friendship, MD
2006 Explorer XLT
Quote:
I got rid of my X though...burning oil at 90,000 miles, like a 1/2 quart a week, EVAP canister went bad twice...it was rough. __________________ 06 Explorer XLT 4.0 Chrome Bull Bar, Ironman Headlights w/ 10000k HID's, Flowmaster 40, K&N filter, Off-road lights 5% rear tint, 15% front. Viper 5701 Remote Start / Alarm, KKM Intake http://www.cardomain.com/ride/3251387 |
#11 |
2007 Ford Explorer EB
How did you get around the different "hook up" problem? I've run into the same issue and my 2007 Explorer is dead in the water until I find the correct adapters. Stops at the local plumbing supply and hardware store have been no help.
#12 |
Crooklyn NY!
there are 2 10mm bolts bolting the sides of the radiator bracket to the condenser take them out.
#13 | |
Quote:
![]() Removal of the lines requires the use of a removal tool. The tool slips around the line and is then pushed into the fitting which in turn releases the line. Most all auto parts stores have the tool for sale or rent. Last edited by mdfdm; 11-16-2011 at 09:51 PM. |
#14 |
Denver
2007 Ford Explorer
Just finished this job, thought I would post my experience. Remove all of the obvious bolts, 2 10mm hold the rails to the rad, 2 14mm hold the rails to the body, 4 10mm for the fan shroud, air dam on the bottom with plastic push fasteners. Also, remove the overflow tank, unbolt the PS tank and move it out of the way and the clamp from the condenser line on the right side. Here is the trick, the condenser is held to the rails with 2 10mm bolts. Tilt the rad assembly forward and use a flashlight to look down between the rad and condenser. Loosen (no need to remove) these bolts and the rails will slide out away from the condenser. Make sure it is completely free of the rails at the top. The condenser is held in place at the bottom with metal pins that sit into rubber grommets, just lift it out. Once the condenser is free you are pretty much there. The next trick is to completely remove the air cleaner box. This gives you enough room to maneuver the radiator and the two rails away from the AC plumbing on the right side. You have to take out the rails with the rad, they slide on from the side and there isn't enough room to do it in the truck. If you can avoid it, don't remove the lower hose from the engine, getting it re-installed back behind the fan is a pain. Finally wound up removing the compression clamp and replacing it with a screw clamp. After removing transmission lines, quickly moved them up and wedged them behind some other lower engine/suspension parts. This get's them high enough so gravity is not an issue, only lost about 1/2 cup + what was inside the old coil, of trans fluid this way. Fittings were the right size so screwing them back into place was no problem. Still taking it into the dealer to top off the trans fluid. Much cheaper than letting them do the whole job.
#15 |
2006 Explorer XLS
Wow, wish I saw this earlier today. I just did this job, and just as I was praising ford for the two piece fan shroud, I happened on the the whole condenser blocking the removal of the radiator problem. I just loosened the side brackets for the radiator and pryed them apart to get the radiator in and out, and eventually I got it out and new one in. Took way longer than I thought it should have. Oh well, toughest radiator job I've done yet. I still appreciate the two piece fan shroud, though.
#16 | |
Quote:
I followed beermans instructions to the letter for my 2007 Mountaineer. Radiator leaking pretty good at 50K miles. I almost strayed a couple times as it was tough to get the rails out with the radiator due to the A/C lines, but finally got it. I also had a tough time pulling the Transmission lines out with the tool, but it just took a little more force pulling the lines out than I thought. Thank you so much for the detailed walkthrough. |
#17 | |
Ojai, CA
2007 Explorer
Thanks and question
Quote:
Is there a special tool for removing the transmission lines that is referenced in motoviper's post? Thanks, John |
#18 | |
Quote:
I used the lisle 39960 as it was $6 but you can use any that are 1/2" (which is mine but I read some are 3/8") |
#19 | |
Peatland, Texas
2007 ford sport trac
Quote:
#20 | |
Monroe Township, New Jersey
2007 Explorer Limited V8
Quote:
Thanks for the advice. PS- I did loose about a half of a pint when removing the tranny lines so I just forced the same amount back in the line and quickly installed it with no loss of fluid. Man I wish they added a dip tick to this tranny. __________________ 2007 Ford Explorer 4.6 3 Valve V8 |
| Thread Tools | |
