| EF Swag Store | 2013 Ford Explorer | Forums | Elite Membership | Chat Room | My Posts | Reviews | Explorer Photo Gallery |
| Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. |
Thread Tools |
#1 |
Wannabe Elite Explorer
West Warwick,RI
97 XLT SOHC
Door won't open
My son just picked up a 98 sport and the passanger door will not open no matter what I do.
I have tryed the inside handle/outside handle, remote/door buttons, key. We have the seat out and the door panel off and I have tryed pushing/pulling on the rods wirh my fingers inside the door wile doing all of the above still can't get IT to open. Anyone have any ideas? HELP PLEASE!!!!!!!!! |
#2 |
West Warwick,RI
97 XLT SOHC
Help......anyone have any ideas on how I can get the door open?
TIA |
#3 |
Waterloo Ontario
2000 XLT 4.0 SOHC 4X4
likely the plastic clip is broken inside the door; Have you tried using a slim jim?
__________________ 2000 Ford Explorer SOHC 4X4 249,000KM 2003 Ford Escape 101,000KM |
#4 |
Sunnyvale, California
01 Limited 5.0
#5 |
south carolina
1998 5.0 V8 AWD XLT
I have had the same problem for quite sometime. I have a 98 4 door Explorer and the front passenger door would not open when I got the vehicle. The outside inside handle did not seem to be connected to the rod and the outside handle did not work either. Today I finally took the time to try and fix it with a knowledgeable friend. My wife was tired of jumping across the drivers seat. Well it was a huge hassle. I was not able to get the door panel completely off, so we tried to locate the problem while one of us pulled the panel back. Nothing I did seemed to work. It seemed as if the locking mechanism was stuck. I finally found the problem. There is a rod that connects to the key mechanism that goes up/down when you turn the key. Somehow that particular rod was getting behind all the mechanical parts (sorry I don't know the correct terms, I'm no mechanic). So I had to reach my hand behind everything and pull on that rod. It was stuck behind something inside the door towards the rear. Well amazingly after over an hour of trying everything else when I pulled on that rod and got it unstuck from behind the other parts, I felt it release and the door opened using the outside handle. The rod had somehow fell out of the hole on the key locking mechanism and fell behind other parts. After getting the door to open I reconnected it and it immediately fell behind the other parts again and the door wouldn't open again. For the time being I cut it off and now the door works fine but it will not lock until I get new parts. The inside handle had a plastic part broken off also. It maybe worth a try to see if this is the same problem you have.
| Thread Tools | |
