Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Under the Hood
Notices
Under the Hood Ford Explorer and Ranger, Engine, troubleshooting, modifications, performance and accessories.
black smoke
Reply
Thread Tools
Old 03-10-2010, 11:36 PM   #1
mrwackmbuck
martinsburg pa
89 bronco ll
Vehicle Specs
(Original Poster)
black smoke
help..i have an 89 b2 2.9.i replace the fuel pump,regulator,coil,and ecm..all my plugs are black and it will not run if i pull the fude for the pump it will run ok till the fuel runs out
thanks
mrwackmbuck is offline   Reply With Quote
Old 03-11-2010, 09:53 AM   #2
MrShorty
Spanish Fork, UT
92 XLT and '87 Bronco II
Vehicle Specs
I hate to be a jerk, but this really needs some punctuation. I can't tell if this should be "all my plugs are black and it will not run if I pull the fu[s]e for the pump. It will run ok till the fuel runs out." or if you mean "all my plugs are black and it will not run. If I pull the fuse for the pump, it will run ok till the fuel runs out." I'm having a hard time picturing what it is actually doing in either case.
Black smoke and black plugs suggest to me that it is running rich when it does run. You say that you've replaced the regulator, but have you ever put a fuel pressure gauge on it? That's probably the first thing I'd do.
__________________
Mr. Shorty
92 XLT 4x4
87 Bronco II XLT 4x4
'98 Chev K1500 Suburban SLT 4x4
MrShorty is offline   Reply With Quote
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
