Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer - Sport thru '03 - 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
Rear Main Seal Leak on 96 Explorer XLT
Reply
Thread Tools
Old 03-13-2010, 05:01 PM   #1
96
South Jersey
1996 XLT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Hi Folks,
Been noticing oil on the driveway in the morning, Had the truck to my mechanic and today he advised me the leak is coming from the rear main seal. HE said the only way to fix it is to take the engine and transmission out . Im a little upset because I just had it in the shop as I had 2 new cylender heads installed, head gasket and water pump.
Mechanic advised me its perfectly safe to run however but i would just have to keep check oil levels etc. Has anyone had similar issues? Id so, what did you guys do?
Thanks for your help....
96 is offline   Reply With Quote
( Join the Elite Explorers )
Old 03-13-2010, 05:11 PM   #2
yellow coupe
East Tn.
1997 Mountaineer 5.0 AWD
Vehicle Specs
Quoted: 0 Post(s)
I have dealt with a lot of rear main seal leaks. To put a new seal in you either have to pull the engine or the transmission to get to it. I have a rear main seal leak on my Mountaineer also. Just keep a check on the oil level. It would have to be leaking pretty bad before I would put a new seal in.
yellow coupe is offline   Reply With Quote
Old 03-13-2010, 06:47 PM   #3
96
South Jersey
1996 XLT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
thanks,
Old 03-14-2010, 08:16 AM   #4
bluestream1
Waterloo Ontario
2000 XLT 4.0 SOHC 4X4
Vehicle Specs
Quoted: 77 Post(s)
Try some of the high mileage 10w30 oils. They have seal swell additives that may help the leak. These oil are made from a high quality base oil and have a more robust addative package so they are acyuallt better oils
__________________
2000 Ford Explorer SOHC 4X4 310,000KM
2000 VW Beetle 1.8
1991 BMW 735iL
bluestream1 is offline   Reply With Quote
Old 03-14-2010, 10:30 AM   #5
2000StreetRod
Greenville, SC
2000StreetRod's Avatar
00 Sport FI,03 Limited V8
Vehicle Specs
Quoted: 45 Post(s)
Rear mail sealer
I had a very slow rear main seal leak when I purchased my Sport last year with 150,000 miles on the odometer. There are a few manufacturers of engine oil additives that are supposed to reduce/eliminate main seal leaks. I tried one of the them for several months before switching to synthetic oil and it seemed to reduce the leak. However, the leak resumed with the synthetic. When my rear timing chain guide failed I decided to pull the engine and fix it and the rear main. When I removed the valve covers I found an excessive amount of sludge. I don't know the maintenance history of my vehicle but I can't help but wonder if some of the sludge was due to the leak reducer.
2000StreetRod is online now   Reply With Quote
Old 03-14-2010, 10:52 AM   #6
bluestream1
Waterloo Ontario
Vehicle Specs
Quoted: 77 Post(s)
StreetRod, not likely the seal swell additive caused the sludge, and if you only used it for a few months, it would not have done a thing. There is too little of it in the oil to make a difference. More likley the sludge is from using conventional oil and long OCI. Poor mantainence practices in other words...
__________________
2000 VW Beetle 1.8
1991 BMW 735iL
Old 03-28-2010, 09:39 PM   #7
cruz38
HEB. Texas area
1996 ford explorer
Vehicle Specs
Quoted: 0 Post(s)
Oci?
I think its incorrect to say that the leak is could be caused by poor or irregular maintenance.. I changed my oil every 3000 miles from the day I bought it and I have this same leak..
Just wear and tear and mileage....is my opinion.
Cruz
cruz38 is offline   Reply With Quote
Old 03-29-2010, 08:41 AM   #8
marragtop
balt, md
91, 92, 95, and 2000 xlts
Vehicle Specs
Quoted: 4 Post(s)
Made sure the PCV valve isn't stuck. That can cause the oil to seep at the rear seal. It's worth a shot.
__________________
'88 F150 4x4
'91 Explorer XLT 4x4
'92 Explorer XLT 4x4
'95 Explorer XLT 4x4
If it don't = 16 (4x4), it ain't worth driving...
marragtop is offline   Reply With Quote
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
