Ford Explorer Sport Trac Ford Ranger Mazda Navajo Mercury Mountaineer, Ford Aerostar Message Board®
Ford Explorer, Sport Trac, Mercury Mountaineer, Mazda Navajo, Ford Ranger, Ford Aerostar SUV Enthusiast Forums
Join the "Elite Explorers Today!"
Explorer4x4 Sportrucks 2011 Explorer Forums Elite Membership Product Reviews Explorer Photo Gallery
Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Repair - Troubleshooting - Modifications & Detailing Forums > 2006 - 2010 Explorer Mountaineer > Stock 2006+ Explorers
Notices
Reply
Thread Tools
Old 03-17-2010, 04:35 PM   #1
praveen
Qatar, Qatar
2006
Vehicle Specs
Exclamation Braking issues.
i have Ford Explorer 2006 model. It has done 35000 KM. The issue is that while applying brake, the steering tilts to right and the vehicle turns slightly to the right. What might be the cause? Is it a common problem with the Explorer?
praveen is offline   Reply With Quote
Sponsored Links (Less Ads)
Old 03-17-2010, 04:39 PM   #2
BrooklynBay
Aerostar Forum Moderator
Brooklyn, NY
BrooklynBay's Avatar
88 89 93 95 96 Aerostars
Vehicle Specs
Welcome to this forum! I've moved your thread into the stock 2006-2010 section. Check your alignment, brake caliper bolts, ball joints, and tie rods. Are all of the tires the same number?
BrooklynBay is online now   Reply With Quote
Old 03-17-2010, 04:50 PM   #3
FIND
Vermillion, SD
92 XLT 4wd
Vehicle Specs
check your brakes and balljoints.
FIND is offline   Reply With Quote
Old 03-17-2010, 04:50 PM   #4
praveen
Qatar, Qatar
2006
Vehicle Specs
Thanks for your immediate reply.
Yes, all tyres are of the same number and I got the wheel alignment done just two weeks back. Still the issue exists.
Old 03-17-2010, 04:53 PM   #5
BrooklynBay
Brooklyn, NY
Vehicle Specs
Maybe the alignment was done incorrectly? Have the shop double check their work.
Old 03-18-2010, 04:54 PM   #6
2006_MM_FYRE41
South Elgin, Illinois
2006 Mountaineer Premier
Vehicle Specs
US
Your right front brake caliper may be hanging up causing the pull to the right.
2006_MM_FYRE41 is offline   Reply With Quote
Old 03-18-2010, 05:02 PM   #7
jupiterak
2006 Explorer EB V8 4x4
Vehicle Specs
Quote:
I agree. Most likely a seized or sticking caliper.
jupiterak is online now   Reply With Quote
Old 03-25-2010, 08:03 PM   #8
praveen
Qatar, Qatar
2006
Vehicle Specs
orange Braking issue
I got all the brake pads replaced with new ones and realigned. Now it is much better than before.
Old 03-25-2010, 08:05 PM   #9
BrooklynBay
Brooklyn, NY
Vehicle Specs
Thanks for the update!
Old 03-30-2010, 01:08 PM   #10
praveen
Qatar, Qatar
2006
Vehicle Specs
Wink Alignment issue
Yes, I am confirming that this is due to wheel alignment problem. When I took it for wheel alignment, one mechanic showed me how the right hand side tyre was not vertical at 90° angle. There was an issue with the suspension at right hand side. When he made the wheel suspend freely, the wheel was shaking as if it was hanging. He tightened the nuts and aligned properly. After a test drive, presently I feel that the problem is resolved. I will drive some more miles and confirm in this forum whether the issue has been resolved completely.
Thanks once again for all your advises.
Reply
Tags
brake, ford explorer, steering tilts to right, turns to right
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
Copyright 2010 - 1996 Rick Horwitz Photography
Modifying the suspension on any vehicle will cause changes to it's handling characteristics.
