Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Under the Hood
Notices
Under the Hood Ford Explorer and Ranger, Engine, troubleshooting, modifications, performance and accessories.
Camshaft Synchronizer ?
Reply
Thread Tools
Old 03-20-2010, 11:21 AM   #1
ErnieX
Melrose, FL
96 XLT
Vehicle Specs
(Original Poster)
96 4L OHV - I'm replacing my CMP to get rid of the squeal. Set engine at TDC and removed the sensor from the drive unit and installed the synchronizer tool on the existing CMP to check the alignment before removing the old CMP. The alignment tool is pointing in the right direction and is rotated approximately 30 degrees clockwise from the engine centerline. My Haynes manual says to install the new drive unit with the alignment tool pointing 60 degrees clockwise from the engine centerline.
My question is do I reintall it as it came out or do I rotate the new one to match what the manual says? Truck was running fine with no codes. CMP has not previously been removed or adjusted.
Don't want to put it all back together and it not be right. What do ya'll think?
Thanks
ErnieX is offline   Reply With Quote
Old 03-20-2010, 12:18 PM   #2
Turdle
Old and in the way
Humboldt, Kansas
Turdle's Avatar
2000 Mounty
Vehicle Specs
From what I understand it is sort of like an old school distributor. It doesn't matter how the distributor is rotated as long as the #1 ( and all other wires) are located in the correct position relative to the rotor under the cap.
So, if the tool fits with #1 at TDC when you removed it, then installing a new one with the tool on will work, provided the engine has been locked in the same position, and not rotated while the drive unit is removed.
I really do not think it matters which way the connector faces. If it bugs you just move the whole unit back a tooth and check again.
__________________
Jon
2000 Mountaineer
Turdle-gone
Vitamin D Wagon Sold also
Turdle is online now   Reply With Quote
Old 03-20-2010, 01:29 PM   #3
ErnieX
Melrose, FL
96 XLT
Vehicle Specs
(Original Poster)
Thanks for the reply - That's pretty much what I thought. Think I'll put the new one in the way the old one comes out - it was running fine the way it was except for the squeal.
I'll post back when completed to verify.
Thanks
Old 03-23-2010, 01:10 PM   #4
ErnieX
Melrose, FL
96 XLT
Vehicle Specs
(Original Poster)
Just posting to close out this thread. When I went to install the CMP, it was tough to get it seated all the way down. Had to tap it a little bit to get it down. Anyway, once it seated it was rotated 60* clockwise from the centerline as shown in the manual. Fired right up and ran fine - apparently, as Turdle said, it doesn't matter as long as the tool aligns properly at TDC.
Thanks for the help.
Old 04-03-2013, 05:50 PM   #5
Triple5s
Tacoma, WA.
1996 Ford Explorer V8 XLT
Vehicle Specs
5.0 camshaft synchronizer position installed
I am trying to replace the synchronizer on my 96 5.0 after getting obd code p0340. thought it was the sensor at first but after removing the sensor I found that not only was the sensor completely shredded but the "half moon" piece on the synchronizer was also completely ripped off so I am not able to tell what position it is in. I'm aware of the whole TDC thing and have the new synchronizer and tool to install it correctly but want to know if anybody has photos of what the synchronizer looks like when installed, with the tool off, on a 96 5.0 explorer and any other helpful tips will be appreciated too.
Triple5s is offline   Reply With Quote
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
