#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1991 - 1994 Explorer Ranger Navajo 1st Generation > Stock 1991 - 1994 Explorers
Notices
Stock 1991 - 1994 Explorers For questions related to the base Ford Explorer. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. No modification questions.
Clutch Master Cylinder Pushrod Removal
Reply
Thread Tools
Old 03-20-2010, 09:38 PM   #1
tvance
Lynnwood WA
1993 XLT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
How do I remove the pushrod from the clutch pedal? I'm needing to remove the clutch hydraulics to bench bleed the system.
'93 XLT
Trevor
tvance is offline   Reply With Quote
( Join the Elite Explorers )
Old 03-20-2010, 10:29 PM   #2
RangerX
Moderator
Elite Ranger
Omao, Kauai
RangerX's Avatar
'93 Ranger XLT 4X4
Vehicle Specs
Quoted: 184 Post(s)
It should have a small plastic cap-like clip that holds it on. Get down there with a flashlight and you'll see it.
__________________
Bill Collins
93 Ranger XLT 4X4
"Beauty is only sheet metal deep."
RangerX is online now   Reply With Quote
Old 03-21-2010, 09:09 PM   #3
tvance
Lynnwood WA
1993 XLT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
thanks Bill. I did see that plastic cap/retainer & managed to break one of the tabs off before I posted. My next challenge was getting that snap ring removed.
I got the whole system out & vertical & purged of the old blackish DOT3. The pushrod is still connected to the MC plunger though. hmmmm
Old 03-22-2010, 06:05 PM   #4
jwv3
Delaware
92 xlt
Vehicle Specs
Quoted: 0 Post(s)
I just left the push rod attached to the master cyl when I bled mine. It snaps in and I'm not sure if you can remove it properly without breaking something.
I just wrapped a rag around the end of the pushrod and used it to push the m/c plunger to bench bleed.
jwv3 is offline   Reply With Quote
Old 03-22-2010, 06:27 PM   #5
tvance
Lynnwood WA
1993 XLT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Turns out that snap ring holds the piston/seal for the MC. the pushrod does come out-- it has two retaining clips inside the piston to hold it. (I saw a new one).
I got the whole thing back in, and now I've got absolutely no firmness in the clutch pedal. I must've got some air trapped into the system somehow. not a fun day
Old 03-23-2010, 10:33 PM   #6
tvance
Lynnwood WA
1993 XLT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
I got 'er done! These videos & info from Perfection Clutch were...well...clutch! Along with Ford bulletin #93-12-19.
I ended up buying a hand vacuum pump (Mityvac) which made bleeding the system quite easy, to the point I was able to do it all without an assistant. It was the best $40 I spent this week!
http://perfectionusa.blogspot.com/20...hydraulic.html
http://perfectionusa.blogspot.com/20...er-clutch.html
http://perfectionusa.blogspot.com/20...es-pickup.html
http://perfectionusa.blogspot.com/20...ch-master.html
Trevor
Old 01-11-2011, 11:25 AM   #7
moonkyu
corona, ca
97 xl
Vehicle Specs
Quoted: 1 Post(s)
hi
i am in the middle of replacing the clutch master cylinder, too.
how did you manage to disconnect the pushrod of the master cylinder from the clutch
pedal? i had to break the plastic cap off already. do i need to go to a ford dealer
to buy it? i would really appreciate your reply.
moonkyu is offline   Reply With Quote
Old 01-11-2011, 02:28 PM   #8
Tony H
New York, Wading River (that's on Long Island)
'91 Eddie Bauer
Vehicle Specs
Quoted: 0 Post(s)
You could have Bench Bleed by leaving the Master on the Firewall and running the hose that goes to the Slave up and into the reservioir. Hold it below the Fluid level so it acts like a check valve. Just pump the pedal until the bubbles stop, hold the pedal down and have someone connect it to the Slave.
__________________
1975 CJ5 with fiberglass body and 350/345Hp chevy power:bought it in '79
1985 chevy stepside pickup, 300K on the clock: Original Owner
1989 Volvo 240 300K on the clock: Original Owner
the 1991 X is my newbie with 331K on the clock: bought OCT.'03 with 183K
http://home.lyse.net/brox/TonyPage4.html
Tony H is offline   Reply With Quote
Old 01-11-2011, 08:14 PM   #9
moonkyu
corona, ca
97 xl
Vehicle Specs
Quoted: 1 Post(s)
i figured it out by myself.
it is okay or inevitable to break the plastic cap between the pushrod of the master
cylinder and the clutch pedal because it will come with the master cylinder when
you buy a new one.
i finally detached the master cylinder and the connecting pipe between the master
cylinder and the slave cylinder with the help of the special clutch tool.
this tool was 5 dollars and tax at the local store of autozone.
now i need to bench bleed the master cylinder.
thank you for your reply, tony.
Old 01-11-2011, 08:17 PM   #10
RangerX
Moderator
Elite Ranger
Omao, Kauai
RangerX's Avatar
'93 Ranger XLT 4X4
Vehicle Specs
Quoted: 184 Post(s)
That tool sounds interesting, do you have the part number or name?
Also, I bought just the plastic clip at the dealership before, in case you ever need another. It was about $2.
__________________
Bill Collins
93 Ranger XLT 4X4
Old 01-11-2011, 10:49 PM   #11
moonkyu
corona, ca
97 xl
Vehicle Specs
Quoted: 1 Post(s)
the tool is named ford clutch tool or something. it is well explained in
the chilton manual and is used to disconnect quick-connect line.
it is also mentioned in the video above.
Old 01-12-2011, 03:05 AM   #12
Anime
EF YEAH!!
Anime's Avatar
2016 EX Sport Concept
Vehicle Specs
Quoted: 181 Post(s)
Ford Clutch line Removal tool.
http://www.amazon.com/KD-Clutch-Tool.../dp/B000GTOYRU
They're usually included when you buy a new clutch kit.
You can make your own with some flat bar and a grinder, torch, or plasma cutter if you have one.
__________________
"I think man has always gone where he has been able to go, and I think that when man stops going where he can go, he will have lost a lot. Man has always been an explorer. To me, there's a fascination in thrusting out and going to new places. It's like going through a door because you find the door in front of you." - Michael Collins
Anime is offline   Reply With Quote
Old 01-12-2011, 12:29 PM   #13
RangerX
Moderator
Elite Ranger
Omao, Kauai
RangerX's Avatar
'93 Ranger XLT 4X4
Vehicle Specs
Quoted: 184 Post(s)
Oh yeah. I didn't read closely and thought it was something for the master cylinder.
__________________
Bill Collins
93 Ranger XLT 4X4
Old 01-12-2011, 06:35 PM   #14
moonkyu
corona, ca
97 xl
Vehicle Specs
Quoted: 1 Post(s)
i finally finished replacing the clutch master cylinder for my 97 explorer and i want
to encourage others to do it. it was time consuming and not that difficult.
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
