Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2006 - 2010 Explorer Mountaineer 4th Generation > Modified 2006 - 2010 Explorers
Notices
Modified 2006 - 2010 Explorers Modified 2006 - 2010 Ford Explorer Forum. Aftermarket accessories and modifications. Bullbar, running boards, floor mats, cargo mat, DVD headrest, wheels, tires, stereo upgrade, headlights, mud flaps, lift kits, engine swap, transmission swap.
Factory Nav Unlock
Reply
Thread Tools
Old 03-22-2010, 02:19 PM   #1
seannydeez
Braintree, MA
2006 Limited
Vehicle Specs
(Original Poster)
Factory Nav Unlock
I apologize of this is a repeat. I was searching lock pick devices for the pioneer factory nav head units and came across a way to unlock the factory units so you can change the colors, type in destinations while driving, and some other funky settings that I didn't want to mess with. I don't know what years this works with other than 06.
Here's how:
Turn unit on (obviously)
Press hard Nav button and agree to the legal BS
hopefully you have some saved addresses...choose a saved address from your address book.
press the edit button and clear out the address
typ: F-DEVELOP ON (make sure there is a space between develop and on)
In the top left of the screen after you enter this should be the word "ADDRESS"
Press under the A in address until the map appears.
Now, press the hard "Menu" button on the left side of the unit.
Now press the soft "security" button
Once you're in the security screen, press the screen in the bottom right corner just as you did for under the "A" in Address.
This should bring you to a new screen with all sort of settings. You can change color schemes from Ford to Lincoln and Mercury, you can pull up a cool screen that looks like the speedo from knight rider, and best of all you can turn off the security lock which prevents you from not being able to enter destinations while the vehicle is in motion.
The steps above are from memory so if they don't work for you let me know and i'll see if I missed a step.
The settings will reset everytime you turn the car on and off, but all you'll have to do is go to the security screen and press the bottom right off the screen again to access the menu, you won't have to go through the first few steps.
seannydeez is offline   Reply With Quote
Old 03-23-2010, 10:51 AM   #2
short1
Kenosha, Wi
2006 Limited
Vehicle Specs
sweet, i'm gonna have to try this
short1 is offline   Reply With Quote
Old 03-24-2010, 12:52 PM   #3
short1
Kenosha, Wi
2006 Limited
Vehicle Specs
Hey, I was trying this but when i choose an address and hit view/edit, if i clear it to type in f-develop on it doesnt let me, it will decide what starts with an F if that makes any sense. Is there something i'm missing?
Old 03-24-2010, 01:00 PM   #4
seannydeez
Braintree, MA
2006 Limited
Vehicle Specs
(Original Poster)
I can't run out to my car right now, but if I recall I chose an address I had saved and on the screen there was a button that said edit. I just hit the backspace button and typed in "f-develop on" and it didn't suggest anything. I did try entering "f-develop on" as a new address and that didn't work, I had to edit an existing one. I'll check it out when I leave work tonight and i'll update you when I get home if you're still having trouble.
Old 03-29-2010, 11:48 AM   #5
dpxtwo
'06 EB V8- FM50, Ram Air
Vehicle Specs
-Just one correction in the instructions, you don't clear the address, you clear the name and type F-DEVELOP_On.
Thanks for the instructions though,
This worked for me to get into the edit mode but the changes I make do not stick and so whenever I turn the truck off and back on the changes are gone. Anyone know how to make them stick?
dpxtwo is offline   Reply With Quote
Old 03-29-2010, 11:51 AM   #6
seannydeez
Braintree, MA
2006 Limited
Vehicle Specs
(Original Poster)
I knew I probably messed up somewhere, thanks for correcting it! It does suck that the changes don't stick, but at least you dont have to go through all the steps the next time, you can just go right to the security screen. I was afraid to mess with some of the settings because I'm not sure what they do or if there is anyway to undo it. I do particularly like the lincoln color scheme over the ford one and of course the ability to type on the screen while driving.
Old 03-29-2010, 12:01 PM   #7
dpxtwo
Vehicle Specs
Yes, true, once you have the F-DEVELOP ON address entered, you can easily enter the edit mode through the Security screen hidden button. But surely there is someway to make the changes stick.
Old 05-17-2010, 08:49 AM   #8
WWasem
Lehigh Valley, PA
'07 Explorer EB '01 Sport
Vehicle Specs
Man, I wish I had this when I had my '07!
Screen shots & more information: http://www.offshoreonly.com/forums/t...-oem-unit.html
__________________
Daily: 2001 Explorer Sport 4x4 - Silver
Wife Daily: 2010 Ford Fusion Sport - Tuxedo Black
Fun: 2000 Pontiac Trans Am Firehawk #62 - Arctic White
Sold: 2007 Explorer Eddie Bauer 4x4 - Dark Blue Pearl
WWasem is offline   Reply With Quote
Old 05-17-2010, 12:39 PM   #9
JamesBond
Everett, WA
2006 Explorer EB
Vehicle Specs
Quote:
Here's how:
Could this be how the dealer programs NAV units for a particular vehicle?
I.E. wouldn't have to go to the dealer or pay someone to reprogram a NAV unit for particular features of a vehicle?
JamesBond is offline   Reply With Quote
Old 05-17-2010, 12:47 PM   #10
WWasem
Lehigh Valley, PA
Vehicle Specs
It's possible but there must be an additional step to "burn in" your settings which we do not have here...
__________________
Old 05-17-2010, 05:21 PM   #11
08 Mountaineer
Mesa, AZ.
2008 Mountaineer
Vehicle Specs
I did this earlier and got it to work, but has anybody else not been able to get the "Sensor Information" to work properly? It pulls up fine, but most of the gauges don't work at all. For me, I get nothing from Voltage, Acceleration, Slope Angle, and the clock is off. Wasn't sure if it's just lacking the necessary sensors or if it's something I'm doing wrong.
08 Mountaineer is offline   Reply With Quote
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
