| Modified 2006 - 2010 Explorers Modified 2006 - 2010 Ford Explorer Forum. Aftermarket accessories and modifications. Bullbar, running boards, floor mats, cargo mat, DVD headrest, wheels, tires, stereo upgrade, headlights, mud flaps, lift kits, engine swap, transmission swap. |
Thread Tools |
#1 |
Wannabe Elite Explorer
08 EB 4x4 V6
2008 Explorer HID Error Canceler
Hi there can any of you guys please tell me what one of these or if all of these HID Error Cancelers will work for my 2008 Explorer and also if they are universal with any hid kit if anybody knows. Thanks in advance
http://hidcanada.com/store/index.php...products_id=19 http://www.hidspeed.com/H13_HID_Bi_X...wire-shh13.htm http://www.carhidkits.com/xenon-hid-...plugs-275.html http://www.hidny.com/product.sc;jses...&categoryId=21 |
#2 |
hawaii
2007 xlt v8 ironman
first one and last one looks like they will work. the second one MAY work.
#3 |
08 EB 4x4 V6
just curious I have a bi-xenon kit so i thought i need 4 resistors so do i need to order two of these special harnesses. thanks
#4 |
hawaii
2007 xlt v8 ironman
i dont think you can wire two seperate harnesses to one HID kit. since there is one wire from the ballast that goes to a wiring harness
#5 |
thanks for the info...
#6 |
08 EB 4x4 V6
i just found out that these error kits will not work for our explorer because we need a special harness with 4 resistors.
#7 |
Pensacola, Florida
2009 Eddie Bauer
I'm about to get my bi-xenon kit in the mail this week. If I do have the error code (which I expect) what exactly do I need to get to remedy it? What special harness / resistors do I need to get?
Thanks for the info |
#8 |
Pensacola, Florida
2009 Eddie Bauer
I just finished my HID bi-xenon install. Very straight forward install. Everything is good to go but I do get the "check headlight" message on the dash. I hit the reset button and it goes away until you turn the truck off and then back on. I still don't know if I need to wire in a resistor (sounds like a pain) or get the error canceler kits sold on eBay. Anyone know for sure that the kits don't work?
#9 |
Pensacola, Florida
2009 Eddie Bauer
![]() Here's a pic after the install |
#10 |
Puerto Rico
2010 XLT
2010 explorer HID error
Hi Guys:
did you found a solution for this? I have a 2010 explorer with the same error in the dash after installing a bi-xenon kit. I already installed the canceler and a resistor to the plug left disconnected. Thanks |
#11 |
Pensacola, Florida
2009 Eddie Bauer
I'm told that the canceler kit does not work on the Ex. A 50w resistor wired in-line with the high and low beam wires on each side should do the trick. Check out this thread,
http://www.explorerforum.com/forums/...d.php?t=307120 |
#12 |
2006
got the same problem. I got a hi/low HID with 2 ballast.the HID wires are connected to my left headlight oem harness for both left/right HID, so the right headlight oem harness was left disconnected(unplug).
The error message (check headlamp left/right) comes out when I hit the flasher/highbeam stick.. I think the canceller/capasitor will work for the left oem harness, but the right unplug (disconnected) harness will not work since the other end of the canceller cannot be attached to any ballast/lamp |
#13 |
2006 Explorer EB V8 4x4
The cancellor won't work on our rigs. I tried two different types and several different scenarios and no go. Dont waste the extra $ when you can get a set of resistors for $10.
#14 |
Alberta
2008 Limited
Anyone knows if you will get the "check headlights message" after HID's install on a 08 EX that has the factory daytime running lights?
__________________ 2008 Limited, front tint 35 %, K n' N intake, Magnaflow cat-back, Hypertech programmer, 265/50/20 Nitto Terra Grappler's |
#15 |
okc,oklahoma
2008 xlt
#16 |
Alberta
2008 Limited
which cancellor did you try jupiterak? i'm looking to get the DDM one.
#17 | |
Quote:
http://cgi.ebay.com/ebaymotors/ws/eB...0562&viewitem= if anyone wants them, just pay shipping and it's yours. |
#18 |
Niles, Mi
2007 Ironman Explorer
you can get way cheaper resistor/ hid error code canceling kits that are only 17 bucks no spicing or nothing
#19 |
Pensacola, Florida
2009 Eddie Bauer
Do those work? I was under the impression they didn't work on Explorers. If they do can you post a link...
Thanks |
#20 |
Blackstone, MA
2006 Eddie Bauer
I just installed these in my 06 Explorer and they work like a charm. No hot resistors to worry about and no relays to mount either. These are plug and play between factory harness and ballast for each headlight. http://www.theretrofitsource.com/pro...roducts_id=238
| Thread Tools | |
