Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
Front upper & lower ball joint boots
Reply
Thread Tools
Old 04-10-2010, 11:17 AM   #1
audioholic
Virginia
`99 XLT V8 AWD
Vehicle Specs
(Original Poster)
Question Front upper & lower ball joint boots
Hello all,
Is there any source out there for buying ball joint boots - just the boots vs. a control arm or ball joint assembly? Or has someone cross-referenced boots from another vehicle that can be utilized? I have a 98 Sport 2WD and a 99 XLT V8 AWD that the ball joint boots have split on. I have been keeping them cleaned/lubed regularly so there's no slop present in the ball joints and any wear is minimal. By the way, if anyone else is nursing ball joints with split boots I have had success in using motorcycle chain lube - it's good quality lube and it stays on since it's designed to not be flung off.
I've searched online for boots without success, also searched this site and found nothing conclusive. It seems strange to me to have to spend $2-300 per vehicle in parts on upper arms and lower joints plus realignment when boots are all that's really required. I have the tools and the time but can't source the boots. Thanks in advance for any suggestions.
__________________
“The nine most terrifying words in the English language are: “I’m from the government and I'm here to help.”
Ronald Reagan
audioholic is offline   Reply With Quote
Old 04-10-2010, 12:04 PM   #2
alohamonte
Glendale, AZ
1998 Explorer 4.0 4x4
Vehicle Specs
Boots arent sold seperately. Once the boots are torn, the grease inside pours out, dirt/water gets in, and the damage is done.
The balljoints need to be replaced. Putting new boots over it will do nothing to save those joints.
Sorry.
__________________
1998 Xplorer 4.0 OHV 4x4, 3.73 L/S, 31x10.5 Good Year Silent Armor A/T, All Synthetic Fluids, Sony Audio System, Yakima Roof Rack w/ 3rd Crossbar, Bilstein Shocks, Silverstar Ultras, Clifford Alarm & Keyless Entry, Throttle Cable Mod, Moog Front End
alohamonte is offline   Reply With Quote
Old 04-12-2010, 12:38 PM   #3
gijoecam
Village Idiot
Trenton, MI
98 ExSport, '00 F-150
Vehicle Specs
If you really only want the boot, buy a $30 replacement ball joint of the same make as the one you have installed, and install just the boot on it. Personally I wouldn't do all the work and NOT replace the joint too...
Also, if you're splitting boots, you could be over-greasing them. One shot every oil change (or every other as you see fit) is all that's necessary. More is not necessarily better in this case.
__________________
-98 Explorer Sport, 4.0 SOHC, K&N drop-in, LEMON in progress!
-'00 F-150, mucho mods
"We need to allow Darwinism take it's course and let the idiots weed themselves out of existance." ~ Rick Horwitz
We must believe in free will — we have no choice.
~ Isaac Bashevis Singer
I'm not smart, just a resourceful idiot. ~ Me
gijoecam is offline   Reply With Quote
Old 04-12-2010, 04:47 PM   #4
theSpoon
Plantsville, Connecticut
97 Sport
Vehicle Specs
I have some boots that may work for you I bought them for the same reason but was too late and just replaced my ball joints. They would only fit your lower ones though and I'm not home right now or I would get the brand/part number for you.
theSpoon is offline   Reply With Quote
Old 04-12-2010, 05:30 PM   #5
RickOTR
CA
1997 Explorer Sport 4X4
Vehicle Specs
I had the same problem as you. My solution... aftermarket balljoint boots from Energy Suspension part #9.13130R. The are for a Mustang GT, but they share the same dimensions as the Explorer. So far, I've had no problem with them.
__________________
1997 Ford Explorer Sport: Over 500,000 miles and still going
See my CarDomian for details on my Explorer
http://www.cardomain.com/ride/666173
2007 Ford GT40:
2007 Lincoln MKX
RickOTR is offline   Reply With Quote
Old 04-13-2010, 06:27 AM   #6
theSpoon
97 Sport
Vehicle Specs
daystar part no. KU13027BK also fits
Old 04-13-2010, 06:53 AM   #7
audioholic
Virginia
`99 XLT V8 AWD
Vehicle Specs
(Original Poster)
Thanks for the suggestion and part numbers. I figured something out there had to work but no catalogs showed a listing. Both vehicles have the original Ford ball joints and pass inspection, neither have any play in them, just deteriorated boots. A new set of boots should keep them from self-destructing and will keep me from having to climb under there so often.
__________________
Ronald Reagan
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
