Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2002 - 2005 Explorer Mountaineer 3rd Generation > Modified 2002 - 2005 Explorers
Notices
Modified 2002 - 2005 Explorers Questions related to modified 2002 - 2005 Explorers and Mountaineers. For Sport Trac and Sport models use the 1995-2001 forum. Aftermarket accessories and modifications. Bullbar, running boards, floor mats, cargo mat, DVD headrest, wheels, tires, stereo upgrade, headlights, mud flaps, lift kits, engine swap, transmission swap.
About my exhaust
Reply
Thread Tools
Old 04-12-2010, 06:27 PM   #1
02EBEX
VA
02 Eddie Bauer V6 4x4
Vehicle Specs
(Original Poster)
About my exhaust
all i have done is a 50 series delta flow muffler. Is there any thing else i can do that'll help my gas mileage.
its just a flow master muffler with everything else stock
any ideas would be great!!!!
__________________
RB spacer lift (2in.). Flowmaster 50 series delta flow (muffler only). 265/75/16 Maxxis Bighorns M/T. 16x8 Cragar Soft 8- Black Steel Rims. Black Westin bull bar. HIDs lows and fogs.
02EBEX is offline   Reply With Quote
Old 04-12-2010, 07:43 PM   #2
NENC Explorer
North East North Carolina (NENC)
2000 Limited 4x4
Vehicle Specs
Tune Up, Keep your oil changed on the dot every 3k, KN filter, keep your RPM's to less than 2600 at all times (4.0), I switched to mid grade from regular and got a decent bump in mileage (.5 miles to the gallon) according to my math and the truck.
I would say a better flowing exhaust and headers would be another good way to get better mileage, but for the money it wont show you the improvements you want.
Do what I did, buy a car.... (Trucks a toy now)
-Jeff
NENC Explorer is offline   Reply With Quote
Old 04-13-2010, 02:10 PM   #3
CALDWELL
Philadelphia Airport, PA
2005 V6 Silver XLT
Vehicle Specs
1. I would suggest looking into a K&N Intake or KKM or similar, this will allow the engine to inhale more air, which will give you a bump in HP/TQ as well as better MPG ( est. 1 to 2 miles increase ). also it will make the muffler sound better...
* the K&N intake on an 03 X dyno'd ( + 7.5 HP ) on K&N's website...
2. Another suggestion would be remove the exhaust resonator just before the muffler, this will free the exhaust up some more, if you havent already removed it...
* may sound silly but, cut off the tail pipe where it makes the final turn to run straight out the back. then have a 45 degree exhaust exit. It's just one less bend in the exhaust which means better flow...
3. Run Synthetic oil, promotes smoother running engine...
4. bottle of fuel system cleaner once a month doesnt hurt...
5. try running 89 octane over 87, i am and it make a hell of a difference...
6. run larger exhaust piping ( 2.5'' pipe )...
7. proper tire pressure...
8. Change your transmission and center diff fluid...
9. tune from james to adjust for the larger tires...
** I have done everything on this list with the exception of # 9. And it has made a difference in performance, as well as MPG's
__________________
DANNY#2
SILVER 05 XLT
Stage 2 Intake ~ Exhaust ~ Henson Performance Tunes ~ Luminic's Bulbs ~ Sound System ~ Bull Bar ~ Black Headlight Housings ~ 20% Tint ~ FD Lights/Siren ~ Remote Start
CALDWELL is offline   Reply With Quote
Old 04-13-2010, 06:10 PM   #4
fr0st m0nkey
Stockton, CA
'04 XLT
Vehicle Specs
What kind of mileage are you pulling with all that Caldwell? I drive relatively aggressively city/freeway mixed and pull 16-17.
fr0st m0nkey is offline   Reply With Quote
Old 04-13-2010, 06:24 PM   #5
BajaXplorer
San Marcos, CA
2002 XLT 2WD
Vehicle Specs
I found with my MAC exhaust (2.5") its killed all my low end ( which is where all the power is on a 4L Explorer is) Im wishing for my old stock exhaust back...
__________________
Doug M.
2002 Ford Explorer 4L, 2WD
I love the smell of race gas in the morning, smells like Baja...
BajaXplorer is offline   Reply With Quote
Old 04-13-2010, 09:32 PM   #6
CALDWELL
2005 V6 Silver XLT
Vehicle Specs
I do 90% of my driving in stop and go traffic...
when i had My Red X I was getting roughly 15 to 16 MPG ( in town )
I had the following done to it...
K&N Intake / 2.5'' FlowMaster CBE / trans fluid change / fuel system cleaner / 87 Octane / Non Synthetic Oil
now with my Silver X im getting about 15 MPG ( in town )
I have the following done to it...
K&N Airbox Mod / Magnaflow Muffler / fuel system cleaner / 89 octane / Non Synthetic Oil
* i havent made the switch to Synthetic yet with my new X, but will on the next oil change. Im hoping to see a small gain by making the switch. also i would see more mpg gains if i run 2.5'' pipe instead of the factory 2.25''. i wanted to see how well the muffler would perform on its own. i may upgrade to 2.5'' pipe later on, but im happy for the time being. Also prob ably in the middle of the summer i will have the transmission and diff flushed with fresh fluids
BAJAXPLORER - yes you lost low end TQ, but i bet your X pulls like a mofo even well into the top end ? with the K&N INTAKE, and 2.5'' EXHAUST my X pulled pretty hard thru the top end
__________________
DANNY#2
SILVER 05 XLT
Old 04-14-2010, 12:59 PM   #7
BajaXplorer
San Marcos, CA
2002 XLT 2WD
Vehicle Specs
CALDWELL,
you are correct- top end is great pulls well but I dont usually drive in the 38-4800 rpm range, most driving is at 22-2400 rpm in 5th gear on the freeway. so even though yes I technically get better freeway mileage, I do 90% of my driving in town, and thats where id like to have the mileage. Its a give/take situation with the exhasut. It probably would have been better for me to cut out the bulky stock muffler and weld in a replacement one, live and learn I guess..the wallet is lighter about $250- but it works decent, fit sucks on the MAC- someday I will get a replacement.
__________________
Doug M.
Old 04-14-2010, 01:03 PM   #8
CALDWELL
2005 V6 Silver XLT
Vehicle Specs
thats what its all about fella, trial and error...
__________________
DANNY#2
SILVER 05 XLT
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
