Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Ranger - Mazda B-Series Forum > Ford Ranger - Mazda B-Series Forum
Notices
Ford Ranger - Mazda B-Series Forum Ford Ranger and Mazda B Series forums. The Mazda B2300 B3000 and B4000 are clones of the Ford Ranger, with all systems the same. The only differences are trim and a few body parts. This forum discusses Ford Ranger and Mazda B series specific issues. Owners of the older Mazda B2000 B2200 and B2600 are welcome as well.
95-97 2.3L Ranger P0340 = Timing Belt...
Reply
Thread Tools
Old 04-14-2010, 02:17 AM   #1
Tbars4
Offroad Moderator
anaheim hills,california
Tbars4's Avatar
95 ranger 4x4/ 91 X 4x4
Vehicle Specs
(Original Poster)
...I lost my cam position sensor tonight...
P0340 Camshaft Position Sensor Circuit Malfunction
.....Well, I lost all power on the freeway and a check gauge lite came on..Pulled out my scanner and got a P0340 code...
...Early 95 Ranger 2.3L but it is ODBII...Haynes says how to for all 2.3 except it has a small note on 95-97 only, something about the sensor on the oil pump behind the inner timing cover but can't find any useful info here or at TRS...How hard is this as I may have to pull the timing cover, timing chain, and an inner cover?
...Any help and diagrams asap am would be much appreciated...
_________________________________________________________________________________________
...Update: From all the information I have researched and checking with the parts houses, you can buy a cam sensor and no one knows where they go on a 95-97 Ranger 2.3L as they are special..In Fact, I have also been told they do not have a cam sensor and I could not find one which leads me to believe there is none for these years...
...If you have pics on the truck and info showing the 95-97 2.3L Ranger in fact has a cam position sensor, please post them here...
__________________________________________________________________________________________
...I found the belt broken after reaching in to the top of the timing belt cover and finding the belt loose on the cam gear...
...This was a fairly easy process once you figure out how to remove the plastic timing cover....The most important thing when putting this all back together is finding and aligning all 3 "<>" diamond marks on the Cam, Crankshaft, and oil pump gears, as they are very fine marks and not easily seen...
...My gas mileage since I've owned the Ranger has never been better and it smogged the best it ever has since I've owned it after swapping this timing belt...These belts last about 60,000 miles but IMHO should be changed at leas every 3 years if not just for the maintenance and the fuel economy..
...I thought I would include these pics for future reference of all the parts in this area...
...The plastic timing cover removed..
...You can see the broken belt and how it has no tension in this pic...
...And I found it broke on the bottom at the crankshaft pulley/gear...
...The new and old belt..The new belt was 1/4" wider but the old one had many miles and suffered damage due to rocks and sand getting in the bottom of the plastic cover..
...There are 2 hidden bolts beneath the A/C that I had to loosen...Do not remove all the way as they are a booger to get started...Also, be careful of your power steering hoses at all times while doing this repair..
...The crank gear and pully...
...Misc. pics of this area...
..This is a good shot of the belt tensioner with the broken belt shown..
...These show the crank position sensor...
___________________________________________________________________________________________
...Edit: Thanks to Rwenzing for sharing the diagrahms in post #8, the cam position sensor has been located..
...It is located behind the inner timing belt cover and the oil pump gear as marked by the arrow here...(View is looking from the ground up)...You do not need to remove anything to access this sensor as it is on the outside of the motor, drivers side, just above the oil pan...
__________________
I have Rocks in my head. What's in yours?
'95 ranger xl 4x4 2.3L std cab, 2 sticks Ranger RegistryThe Squirrel
'91 4x4=To much to list, much more to add.. Project "X" and more Pics & Mod's List
How to: Wheels,Tires, & Lifts...
Buy Explorerforum.com Items here
Tbars4 is offline   Reply With Quote
Old 04-14-2010, 02:13 PM   #2
Tbars4
Offroad Moderator
Tbars4's Avatar
Vehicle Specs
(Original Poster)
...So far it's not the cam position sensor...Thanks SVO for taking the time and giving me some very useful information that can't be found on the net..
...Update tonight...
__________________
Old 04-14-2010, 03:41 PM   #3
Stic-o
Elite Movie Star
Tujunga, CA
Stic-o's Avatar
'99 XL 4x4 & '06 XLT 4x2
Vehicle Specs
If you have oil presure then it not CPS, or at least not the mechanical part. The truck went into fail safe if it shut down. could be the sensor it self on top.
__________________
The JP Mobile ~'99 Explorer XL
The Mall Crawler ~'06 Explorer XLT
The Tow Rig ~ '05 F-150 SuperCrew
The Commuter ~ '10 Focus SES
Stic-o is offline   Reply With Quote
Old 04-15-2010, 09:46 PM   #4
Tbars4
Offroad Moderator
Tbars4's Avatar
Vehicle Specs
(Original Poster)
...It turned out to be a timing belt...
...I got it fixed and will post r and r pics and clean up this thread later, as I needed to hurry up and get to the Post Office...
__________________
Old 04-15-2010, 09:56 PM   #5
RangerX
Moderator
Elite Ranger
Omao, Kauai
RangerX's Avatar
'93 Ranger XLT 4X4
Vehicle Specs
Quote:
Originally Posted by Tbars4 View Post
..., as I needed to hurry up and get to the Post Office
Haha, to mail your tax returns? I got to my PO today right as they were closing!
__________________
Bill Collins
93 Ranger XLT 4X4
"Beauty is only sheet metal deep."
RangerX is online now   Reply With Quote
Old 04-15-2010, 09:59 PM   #6
Tbars4
Offroad Moderator
Tbars4's Avatar
Vehicle Specs
(Original Poster)
....It's a long story but, I ran into another member near Kingman while doing a test drive of my new timing belt...
http://www.explorerforum.com/forums/...d.php?t=277347
__________________
Old 05-22-2010, 04:31 PM   #7
Tbars4
Offroad Moderator
Tbars4's Avatar
Vehicle Specs
(Original Poster)
...Finally updated with info and pics...
__________________
Old 05-22-2010, 06:26 PM   #8
rwenzing
Michigan
03 Ranger FX4 LII 5.0 S/C
Vehicle Specs
It mounts to the oil pump housing and looks like it should be easy to change.
__________________
Bob
2003 Ranger FX4 Level II, 5.0L V8, 4R70W, BW4406 T/C, Aussie Locker front, Torsen rear
Torque Monsters, Magnaflow, duals; Explorer EATC, steering wheel controls, consoles
Bilstein 7100 reservoir shocks, Cadillac/Mustang SVO rear discs, Duff traction bars
CarDomain
Ford owners' manuals ONLINE, then click on "Glovebox"
rwenzing is offline   Reply With Quote
Old 05-22-2010, 07:22 PM   #9
Tbars4
Offroad Moderator
Tbars4's Avatar
Vehicle Specs
(Original Poster)
...Thanks for those great illustrations which have lead me to find that I do indeed have a camshaft position sensor which I have now located and I've updated the first post...
...Mine wasn't bad as it was a timing belt failure but now I got the info when that thing finally decides to go..
...You do not know how many real tech books and online reference I had gone thru to only get words all speaking of different locations or none at all for the 95-97 models only..
...One did reference behind the inner timing cover and when I was replacing the belt, I actually thought that I had to pull a gear to find and get to it...This info is invaluable as I have found out...
__________________
Old 12-04-2010, 04:16 PM   #10
ihaveasuit
Denver, Co
1996 Ford Ranger 2.3L
Vehicle Specs
I realize this is an old post, but hopefully you're still digging around the forums and might be able to help me out. First off, thanks for the only information about the dang camshaft location -- but I still can't find the thing. I'm, er, moderately mechanically capable, so, I'm not scared to get my hands dirty but I'm not a mechanic whiz. That said, I've crawled under the truck, peered through the wheel base, looked and dug around from the top, but I cannot find the camshaft sensor! I know I must just be missing some stupid easy step, but, well, I can't figure it out.
Oh, error code at Autozone and a rough idle is what lead me to the camshaft to begin with.
ihaveasuit is offline   Reply With Quote
Old 12-04-2010, 08:09 PM   #11
Tbars4
Offroad Moderator
Tbars4's Avatar
Vehicle Specs
(Original Poster)
...What was the code # AZ gave you???
...If you look at the bottom diagrahm and picture at the bottom of the first post of this thread, The picture was shot from under the drivers side headlight with the front timing belt cover off..
...Where the arrow is pointing at the gear in that picture, look behind the rear plastic timing belt cover (nothing to remove) and you will see the wires running to it just like in the diagrahm on the right...It is easily accessible once you find it...
...I hope that helps...
__________________
Old 12-07-2010, 10:21 AM   #12
ihaveasuit
Denver, Co
Vehicle Specs
They didn't actually give me a code number, just said it's the camshaft sensor, Bank 1 (?). Then when I went in to buy the part they needed to know if it was 3-pin or 2, which I've yet to determine. I think I can probably find it now, but my wife's car has been out of order with a busted fuel pump and she's been using mine so I haven't had a chance to look at in the daylight. I've been leaking a little oil, so I suspect it might just be covered in engine grime and that's why I've been missing it. I did find the big cable latch (4 in the diagram), so it must be the thing I can't quite get to underneath it. Do you have to remove anything at all to get to it, or should I be able to peer down and see it with a flashlight?
Old 12-07-2010, 11:14 AM   #13
Tbars4
Offroad Moderator
Tbars4's Avatar
Vehicle Specs
(Original Poster)
....That don't sound right...
...Rule #1...Never buy parts suggested from an auto parts store that reads your codes...They sell parts...Bring the code here and we can better help...
...2 or 3 pin would represent how many wires you have to it..Before you buy the part, see if you can get your codes again...
...If you kneel down by your drivers side front tire, you would have to crawl under and look up to see it..Nothing to remove, just above the oil pan, behind the timing belt cover, and easily accessible from underneath...
__________________
Old 12-07-2010, 12:12 PM   #14
DB_1
Elite Ranger
La Quinta, Ca.
DB_1's Avatar
97 SC Ranger xlt
Vehicle Specs
You 2.3 guys got it easy, OHV 4.0's have the sensor by the firewall behind the intake plenum...pretty much buried
__________________
97 Ranger...what's left of it
DB_1 is offline   Reply With Quote
Old 12-07-2010, 03:39 PM   #15
Tbars4
Offroad Moderator
Tbars4's Avatar
Vehicle Specs
(Original Poster)
.... ...shhh, now everyone is going to want a 2.3L...
__________________
Old 10-15-2011, 05:13 PM   #16
bad*dawg
Clarkston Mi.
1998 sport
Vehicle Specs
Rough day between a thermostat and water pump BUT spent far to much time trying to get the timing belt cover off to replace the timing belt. Have the single bolt behind the compressor loose but cannot get at the two behind the power steering pump. Have to rent a puller in order to remove the pulley / remove the bolts / pump so I can et at the two remaining bolts holding the pump / compressor bracket in place. Should be a mmuch easier way to remove the front cover.
bad*dawg is offline   Reply With Quote
Old 10-15-2011, 07:26 PM   #17
Tbars4
Offroad Moderator
Tbars4's Avatar
Vehicle Specs
(Original Poster)
..I only had to pull the a/c..
..You might want to check the first post again..
__________________
Old 10-16-2011, 06:22 AM   #18
bad*dawg
Clarkston Mi.
1998 sport
Vehicle Specs
Read all the posts / pictures again but my problem appears to be no clearance between the aluminum A/C - power steering bracket and the T Belt front cover. All the pictures show the crank pulley removed which I have not done and can't see a reason to do so. Seems if I can get the bracket away from the block the cover will come off. In the pictures my issue is with the serpentine idler pulley to the right of the water pump. No room to pull the T belt cover off.
Old 10-16-2011, 08:55 AM   #19
bad*dawg
Clarkston Mi.
1998 sport
Vehicle Specs
96 Ranger T belt replacement
Another Ford link dealing with the bracket interference problem. So far am having trouble seeing all four bolts and planning on renting a pulley puller for the PS pump so I can remove it for better access to bracket bolts.http://http://www.therangerstation.c...d.php?t=104480
Old 10-16-2011, 11:24 AM   #20
Tbars4
Offroad Moderator
Tbars4's Avatar
Vehicle Specs
(Original Poster)
...Looking at this picture (from the ground looking up) It appears i didn't have to pull the p/s...
...It's been a couple years since I had to do this and I was under the gun for time when it happened but I don't remember it being that difficult using only hand tools in a parking lot.
..But keep us up to date and if you can take a couple pictures to share for others would help too..
__________________
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
