#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2006 - 2010 Explorer Mountaineer 4th Generation > Stock 2006 -2010 Explorers
Notices
Stock 2006 -2010 Explorers Stock 2006 -2010 Ford Explorer Forum. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
Tune up?
Reply
Thread Tools
Old 04-14-2010, 03:52 PM   #1
ahent
Johnston, IA
'07 XLT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Tune up?
OK, Ford dealer says I am do for tune up (68,000 on 2007 Explorer XLT 4.0). Other than spark plugs, what is involved with this $250 process. I am fine paying it, I have heard some horror stories involving the plugs on these Explorers, I just want to know what else they might be doing. Thanks for any help, I did search for this, but do you know how many times "Tune" comes up on this website, holy crap.
__________________
Do or do not, there is no try
--Yoda
ahent is offline   Reply With Quote
( Join the Elite Explorers )
Old 04-14-2010, 03:56 PM   #2
Carguy3J
North East New Jersey
'99 4dr. XLT SOHC A4WD
Vehicle Specs
Quoted: 118 Post(s)
Quote:
It should also include new plug wires, and perhaps a new air filter. That's about it for a tuneup these days. Check with the dealer, as some include things like checking/topping off various fluids, as well as "safety inspections" of various systems.
For the most part, the only plugs people seem to have problems with are the Bosch. For some reason, Explorers, and Fords in general, just seem to not like the Bosch plugs. Motorcraft and Autolite should be fine though. I imagine the dealer will use Motorcraft.
__________________
1999 Explorer XLT 4dr, 4.0L-SOHC, 5R55E Auto, A4WD
K&N FIPK Cold Air--XCAL3 w/ custom tunes from Henson Performance
On The Way: Gibson Cat-Back,U/D pulley,Professional Products Polished 70mm Throttle Body **Planned soon:80mm MAFS,Removal of the Cats,Electric Fan
Best Time 15.87 e/t @ 86.6MPH in the 1/4
Carguy3J is offline   Reply With Quote
Old 04-15-2010, 04:20 AM   #3
shaker1
Algonquin, IL
2006 Explorer XLT 4X4 4.0
Vehicle Specs
Quoted: 0 Post(s)
Have the dealer tell you what they are doing for the $250.
I would do Motorcraft/Autolite plugs (and inspect wires).
Replace fuel filter.
Replace Air filter.
Change Transfer case fluid.
Check serpentine belt for wear/cracking.
Check antifreeze level in expansion tank.
Change Oil/Filter if necessary.
Check your owner's manual for the 60K maintenance schedule.
shaker1 is offline   Reply With Quote
Old 04-15-2010, 10:05 AM   #4
kkreit01
Olathe, KS
'08 Sport Trac V8 2wd XLT
Vehicle Specs
Quoted: 0 Post(s)
^ If you can get all that for $250, I think we should all drive to your dealer. Your lucky to get plugs, wires, air filter, and oil change for $250.
But yeah, follow the manual like shaker1 says. It's all outlined in there. You may need nothing?
kkreit01 is offline   Reply With Quote
Old 04-15-2010, 11:53 AM   #5
Maniak
Moderator-Stock 91-94
Vail, Arizona
Maniak's Avatar
1992 XLT 4x4
Vehicle Specs
Quoted: 205 Post(s)
I know its not an explorer, but its an 06 ford with the same 4.0 sohc ( our mustang).
at 70k I did the following for its tune up..
Oil/filter
Plugs/wires
Trans fluid (manual trans)
fuel filter
Diff fluid (rear, since its only 2wd)
air filter (that gets changed every 6 months anyway)
Checked brakes (Changed rears since they needed it).
checked all fluid
We are coming on on its 140k miles tune up..
I'll do all the same things And change the coolant
I "might" do the brake fluid and clutch fluid flush. I'm looking for that test paper to tell me if it has water in it.
~Mark
__________________
Click HERE to see our Explorer Specs
Maniak is offline   Reply With Quote
Old 05-06-2010, 01:13 PM   #6
Rngrs3910
Boston, MA
06' Explorer V8EB Edition
Vehicle Specs
Quoted: 0 Post(s)
You're getting all your plugs and wires replaced for $250? I've been having mis-firing problems with my v8 over the past few months, and the dealership has been charging me a little over $100 to do 1 plug with coil and wires. Sounds like I'm getting ripped off...
Rngrs3910 is offline   Reply With Quote
Old 05-06-2010, 02:35 PM   #7
jupiterak
2006 Explorer EB V8 4x4
Vehicle Specs
Quoted: 0 Post(s)
It doesn't sound right all that at $250 from a dealer. Plugs alone cost about $8 a piece. The belt will prolly cost $40-$50, fuel filter $10, and air filter $15-$25.
jupiterak is offline   Reply With Quote
Old 05-07-2010, 09:09 AM   #8
bojans
McHenry, Il
2006 Explorer Limited
Vehicle Specs
Quoted: 0 Post(s)
Quote:
If they are replacing the coil pack $100 is very fair. The V8's do not have plug wires. An aftermarket coil assembly is $50 to $75 plus labor... FYI if you know which cylinder is mis-firing you can replace the coil pack yourself in 5 minutes, all you need is an 8mm wrench or socket.
bojans is offline   Reply With Quote
Old 01-26-2011, 12:38 AM   #9
jordan101
versailles,mo
97 xlt
Vehicle Specs
Quoted: 0 Post(s)
My dealer told me just for labor for plugs and wires is like 2.5 hrs which turns out to 180 dollars.
jordan101 is offline   Reply With Quote
Old 01-26-2011, 09:51 AM   #10
thebrakeman
Canton, Michigan
2006 Mercury Mountaineer
Vehicle Specs
Quoted: 80 Post(s)
OP has a 4.0L V6.
The major headache with plugs is on the 4.6L V8 (3-valve Triton family). For spark plug replacement on any of the Triton V8's (4.6L or 5.4L in the bigger trucks), Ford will quote you extra labor in case the break a plug. This requires more time and special extractor tools to finish the job. On average, I guess they break 1/3-1/2 of the plugs, so they quote accordingly. The extractor tool is only good for some many uses before it's worn out, so that adds to the cost, too.
Ask the dealer to be sure they are quoting correct labor for the V6, not the V8. And yes, you should always ask the dealer what they are doing. We can't tell you if it's a good deal if you don't know what's included.
For anyone considering letting the dealer change the plugs on your V8, you may consider asking the dealer if they will reduce the cost if it takes less than their standard time. Probably not, but you can ask.
__________________
thebrakeman ('70)
DW ('71), DD ('99), DD ('01), DD ('05)
2006 Mountaineer Premier V8 AWD w/Tow Package, ScangaugeII
Cashmere/Camel Interior, navigation, power 3rd row
2004 Surveyor 261T Hybrid Travel Trailer (27 ft)
Equal-i-zer 10,000 lb 4-pt Sway Control WDH
thebrakeman is offline   Reply With Quote
Old 01-27-2011, 11:37 PM   #11
willied
Columbus, GA
2006 XLT V8
Vehicle Specs
Quoted: 23 Post(s)
I got my plugs changed at around 73,000 miles with none broken. And it only cost $140.
willied is offline   Reply With Quote
Old 10-14-2014, 07:51 PM   #12
GJMiata
2006 Ford Explorer
Vehicle Specs
Quoted: 0 Post(s)
My Explorer has 124K on it and the original plugs/wires. Was considering getting them replaced along with other servicing recommended in the manual for 120K miles. Haven't had any engine problems, wheel bearings .... another issue entirely.
GJMiata is offline   Reply With Quote
Old 10-15-2014, 10:32 AM   #13
Tech By Trade
Your mom's house
07 Sport Trac
Vehicle Specs
Quoted: 164 Post(s)
Do you have a 4.0L or a 4.6?
P.S., nice resurrection. first post too I see. Well done sir.
Tech By Trade is offline   Reply With Quote
Old 06-14-2015, 09:04 PM   #14
Explorerthis
2006 Explorer V6 4.0
Vehicle Specs
Quoted: 1 Post(s)
Hello,
2006 explorer XLT V6, 4.0
I am also considering changing the plugs myself. If I remember I can see 5 plus and are easy to get to from above. Have to find the 6th.
I have heard about the plugs breaking, but I do not think that applies to my model, can some just confirm that for me.
Also, how do I know if I have 2 valve or 3 valve.
Thank you.
Explorerthis is offline   Reply With Quote
Old 06-14-2015, 10:59 PM   #15
MotorCityFats13
Flatrock MI
2007 Explorer XLT
Vehicle Specs
Quoted: 79 Post(s)
the 3v is only the 4.6l and 5.4l after something like 2005 all the 4.0's "sohc and ohv" were 2v per cylinder.... so if you have a 2006 4.6l explorer then it is a 3v engine... but you said 4.0l so its not... I did not look too much into my 2007 plugs but on my 2nd gen all the drivers side can be done from top and all the passenger plugs were done from bottom after you removed the wheel well splash guard it was so easy I also did a 1997 ranger just for fun after doing my explorer.... I would think 3rd and 4th gen would be the same... but plugs last pretty long these days... pull the back passenger plug and if this one is fouled or worn change them all because this plug is the one that takes the worst beating because of the slant and tilt of the engine under load if this plug looks pristine you will be commonly wasting your time... and dont forget anti-seize on the plugs.... the ones I did on the 1997 ranger were stock plugs at 120k miles and they were perfect but I found the double plat autolites on clearance for something like $2 a pair so I said ill do it anyway for my brother... the ones on my explorer couldn't tell if they were stock but at 150k miles the one kept fouling out every 5k miles so I swapped out all 6 and the one that kept going bad died 3 more times and problem didn't come back but now that engine died so I bought the 2007... plugs have been know to take 200k these days with all the computer controls
MotorCityFats13 is offline   Reply With Quote
Old 06-15-2015, 12:31 AM   #16
shaker1
Algonquin, IL
Vehicle Specs
Quoted: 0 Post(s)
Quote:
Originally Posted by Explorerthis View Post
Hello,
Thank you.
Just did the plugs on my 06 4.0 at 70K miles. The passenger bank is accessible via the wheel well with the wheel removed. The drivers side from above (gap is .052 - .056). A little anti-seize on the threads make the new ones thread in much easier. a couple different size extensions and a universal helps.
The OEM plugs are platinum. The drivers side on mine were pretty worn, with the electrodes rounded and the gap quite wide. I never wait until 100K to change plugs. My OEM plugs had paint marks on top (white on pass side, red on drivers side FWIW).
I'd like to add that when I posted (post #2 ) what I would do at 60K, it was not what I expected the dealer to do for $250, rather the tasks and inspections I would have done or do myself. I do my own maintenance and repairs.
Old 06-17-2015, 11:20 AM   #17
Explorerthis
Vehicle Specs
Quoted: 1 Post(s)
Thank you! I will take your suggestions
Old 06-27-2015, 10:01 AM   #18
Explorerthis
Vehicle Specs
Quoted: 1 Post(s)
Also my radiator fan is always on, is this right or should it only kick on when the engine gets hot?
Thanks again changed 1 plug, having a hard time removing the wire on the passengers side back one.
Thank you.
Old 06-29-2015, 04:42 PM   #19
Explorerthis
Vehicle Specs
Quoted: 1 Post(s)
Thank you.
as soon as I turn the truck on the radiator fan goes on, is this right? I was thinking there is a sensor and it should go on after the car gets hot?
Any feed back would be greatly appreciated
Old 06-29-2015, 06:23 PM   #20
MotorCityFats13
Flatrock MI
2007 Explorer XLT
Vehicle Specs
Quoted: 79 Post(s)
the fan is always on.... the clutch engages when the temps get high but i think it always engages during start up as a check of some sort well mine does but then spins down until it is hot.... with the price of a replacement if mine ever dies I am adding an electric fan because it would be way cheaper
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
