Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Under the Hood
Notices
Under the Hood Ford Explorer and Ranger, Engine, troubleshooting, modifications, performance and accessories.
Tick or Tap? video included.
Reply
Thread Tools
Old 04-19-2010, 09:20 AM   #1
syn-
orlando, fl
96 xlt - wip
Vehicle Specs
(Original Poster)
orange Tick or Tap? video included.
YouTube Video
If you are able to see this message it means that you don't have flash installed or that the video server is down.
So in short I got this motor off a 96 ranger that had 96K on the clock. Yet the block and one of the heads has reman. stamp. The head that has the stamp is actually the one I hear this noise coming from. It does not do it when I start the truck it comes after about 3-4mins after the truck has been started. The guy who first started the motor said it had a bad lifter tap, but they got it to quiet down to this. Somethings its not as loud and I have to go to the passenger wheel well to hear it or under the passenger side to hear it better. Also I did rev the motor this morning and it seems to speed up with the truck but I can barely hear it till the rev comes back down. My thoughts, its bad lifter, oil sending unit is going, or maybe oil pump? With all that said, the truck drives much better than my last motor (cracked heads) and pulls harder from a stop. Though depending on outside temp. depends on how peppy it feels.
Motor has all new ford gaskets and was cleaned, except for the head gaskets.
__________________
Signature modified by Moderator
syn- is offline   Reply With Quote
Old 04-19-2010, 01:44 PM   #2
jd4242
va beach
jd4242's Avatar
92 SC
Vehicle Specs
its your rockers and pushrods,they wear very bad in these motors.delta cams makes a rocker and pushrod set for it.it takes like 30mins to replace
__________________
92 xl 5.5"duff arms,3"BL,PJ 36x14.50,wrapped headers,side dump exhaust,.20 over,HF oil pump,422cam,45cc 95tm p+p 10.67:1 heads,p+p lower manifold,75mm TB,90mm maf,36lbs injectors,P+P GM M90 Supercharged & intercooled!!SCT tuned!!electric fan,4.88s aussie locked front & back!!next NOS&W/M
http://www.explorerforum.com/forums/...=double+vision
jd4242 is online now   Reply With Quote
Old 04-19-2010, 03:32 PM   #3
syn-
orlando, fl
96 xlt - wip
Vehicle Specs
(Original Poster)
wow glad someone responded and the word lifters wasn't mentioned. what would you say the cost is to replace them? noticed in another thread you replaced yours.
__________________
Old 04-19-2010, 03:51 PM   #4
jd4242
va beach
jd4242's Avatar
92 SC
Vehicle Specs
these motor have very low oil pressure and bad oiling for the rockers area.you can replace your oil pump with a melling high flow pump but you have to pull the motor.the rockers and pushrods wear very bad in these motors.you can pull your drivers side valve cover and pull you rockers off to check before ordering,about a 15min job,driver side is easier.also might want to sea foam it first could just be a build up in there.the rocker run $181.50 plus a $42 core deposit.and yes they are what i run.
http://www.deltacam.com/
__________________
Old 04-19-2010, 03:56 PM   #5
jd4242
va beach
jd4242's Avatar
92 SC
Vehicle Specs
o and if you think that was loud listen to mine before the pump and rockers
http://www.youtube.com/watch?v=WfXNheSOKJc
__________________
Old 04-20-2010, 10:22 AM   #6
syn-
orlando, fl
96 xlt - wip
Vehicle Specs
(Original Poster)
mm.. you know I watched both of your vids and noticed that there is slight ticking still after the replacing of the pump, did you also replace the rockers? Only reason I ask is I still here some tapping in the second vid where the "big box" has gone missing.
__________________
Old 04-20-2010, 11:47 AM   #7
jd4242
va beach
jd4242's Avatar
92 SC
Vehicle Specs
Yea both was replaced.I got pretty large clearances so my oil pressure is still a little low also I'm running 10.5:1 compression and the 422 cam so its going to be alittle louder than stock.
__________________
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
