Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer - Sport thru '03 - 2nd Generation > Modified 1995-2001 Explorers
Notices
Modified 1995-2001 Explorers Questions related to modified 1995-2001 Explorer, Mountaineer, Ranger and 2002+ Sports (2dr). Aftermarket accessories and modifications. Bullbar, running boards, floor mats, cargo mat, DVD headrest, wheels, tires, stereo upgrade, headlights, mud flaps, torsion twist, lift kits, engine swap, transmission swap.
whats the easiest way to remove the stock muffler off a '98 XLT 4.0 SOHC?
Reply
Thread Tools
Old 04-20-2010, 10:12 PM   #1
jcwaters1
'98 XLT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
i havent messed with it much, seeing as how my new muffler wont be here till thursday, but it looks to be a bit of a b**ch to get the muffler out of those rubber hangers. whats the easiest way to get it outta there?
__________________
'98 4.0 SOHC. brand new tires, shocks, K&N CAI. double platinum plugs, flowmaster super 40 muffler, JBA headers, and custom 2.5 inch pipe from headers to tailpipe. pioneer 250 watt 6x9 speakers, Xplod Head unit and 800 watt Amp. 2 600 watt subs.
jcwaters1 is offline   Reply With Quote
( Join the Elite Explorers )
Old 04-20-2010, 10:22 PM   #2
Explorer Junky
Grand Rapids, Mi
1997 XLT 4 dr 5.0
Vehicle Specs
Quoted: 0 Post(s)
Saws all! Thats the easiest way i have done it. Cut the hangers and then cut the muffler off with it also!
Explorer Junky is offline   Reply With Quote
Old 04-20-2010, 10:27 PM   #3
IZwack
Moderator Emeritus
Germantown, MD
IZwack's Avatar
1998 Ford Explorer
Vehicle Specs
Quoted: 2 Post(s)
Quote:
The rubber hangers arent too bad - just spray some lubricant (WD-40 works) and rotate from one side to the other as you pull.
__________________
...how'd the moon get there, how'd the moon get there?
IZwack is offline   Reply With Quote
Old 04-20-2010, 10:32 PM   #4
jcwaters1
'98 XLT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Quote:
but i will need the hangers to weld onto the new muffler so i cant cut them.
__________________
Old 04-20-2010, 10:33 PM   #5
jcwaters1
'98 XLT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Quote:
while the muffler is still under the truck? or is there a trick to get the whole assembly out of there and onto the garage floor for more room? then i want to weld the hangers to the new muffler, and throw the whole thing back up in there
__________________
Old 04-20-2010, 10:37 PM   #6
IZwack
Moderator Emeritus
Germantown, MD
IZwack's Avatar
1998 Ford Explorer
Vehicle Specs
Quoted: 2 Post(s)
Yeah you first have to disconnect/cut the muffler from the catalytic converters and then you can slide the rest of the exhaust backwards and remove it from the vehicle (after which you can cut and re-weld the hangers onto the new muffler).
__________________
Old 04-20-2010, 11:14 PM   #7
Explorer Junky
Grand Rapids, Mi
1997 XLT 4 dr 5.0
Vehicle Specs
Quoted: 0 Post(s)
OHH you have access to a welder!????
Did not know that! you can prolly buy hangers from a muffler shop fairly cheap. But some of the other ideas given should work also!
http://cgi.ebay.com/ebaymotors/ws/eB...d=200369927859
Old 04-21-2010, 02:12 PM   #8
scottnh1970
Maryland
1998 XLT V8
Vehicle Specs
Quoted: 0 Post(s)
+1.
I just did this but on a V8.
scottnh1970 is offline   Reply With Quote
Old 04-21-2010, 02:23 PM   #9
Carguy3J
North East New Jersey
'99 4dr. XLT SOHC A4WD
Vehicle Specs
Quoted: 120 Post(s)
I think they mean to cut the RUBBER part of the hangers, not the metal attached to the chassis. The rubber "biscuits" should replaced with the exhaust anyway, as they wear and strecth over time.
Yes, you'll also need to cut the muffler off the rest if the exhaust to slide it back. Just be careful to cut "downstream" of the flange that connect the muffler to the cat. If you bought a stock style replacement exhaust, or a "bolt-in" performance setup, you'll need that stock flange intact.
__________________
1999 Explorer XLT 4dr, 4.0L-SOHC, 5R55E Auto, A4WD
K&N FIPK Cold Air--XCAL3 w/ custom tunes from Henson Performance
On The Way: Gibson Cat-Back,U/D pulley,Professional Products Polished 70mm Throttle Body **Planned soon:80mm MAFS,Removal of the Cats,Electric Fan
Best Time 15.87 e/t @ 86.6MPH in the 1/4
Carguy3J is offline   Reply With Quote
Old 04-21-2010, 03:20 PM   #10
scottnh1970
Maryland
1998 XLT V8
Vehicle Specs
Quoted: 0 Post(s)
The biscuits also can be reused if they are in good condition. Reused mine with my MAC back and they hold great.
Old 04-21-2010, 03:21 PM   #11
Explorer Junky
Grand Rapids, Mi
1997 XLT 4 dr 5.0
Vehicle Specs
Quoted: 0 Post(s)
I was actually referring to the steel part that comes off the muffler or pipe itself. The part the goes INTO the rubber part of the hanger that is attached to the frame. They weld steel hangers onto mufflers and pipes, then they slide them into the rubbers that are hanging from the frame. I cut the part that comes off of the muffler and pipe itself.
Old 06-19-2010, 03:17 PM   #12
BuckeyeSlim
cleveland ohio, indianapolis, in
97 xlt 97 5.0 EB 99 xls
Vehicle Specs
Quoted: 0 Post(s)
sawzall and silicone spray lubricant cut pipe as close as possible to muffler and soak the rubber hangers in silicone spray. a big pair of channel type pliers aid in getting the steel part out of the rubber. pry bars also help.
BuckeyeSlim is offline   Reply With Quote
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
