jarhead_615
- April 21, 2010
- Smyrna, TN
- 2004 Mercury Mountaineer
P2135 Throttle/Pedal Position Sensor/Switch "A" / "B" Voltage Correlation
P2111 Throttle Actuator Control System - Stuck Open
P2106 Throttle Actuator Control System - Forced Limited Power
P2104 Throttle Actuator Control System - Forced Idle
P2105 Throttle Actuator Control System - Forced Engine Shutdown
Does this mean the TAC on the trottle body is bad? Been having a hard time finding the whole trottle body assembly (guess the TAC is not a serviceable item, so you have to buy the whole thing). 04 Mountaineer 4.0L AWD. Truck won't start unless you prop open the butterfly with your hand and then the gas pedal won't do anything when you push it.
