Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2006 - 2010 Explorer Mountaineer 4th Generation > Modified 2006 - 2010 Explorers
Notices
Modified 2006 - 2010 Explorers Modified 2006 - 2010 Ford Explorer Forum. Aftermarket accessories and modifications. Bullbar, running boards, floor mats, cargo mat, DVD headrest, wheels, tires, stereo upgrade, headlights, mud flaps, lift kits, engine swap, transmission swap.
4wd conversion on a 07
Reply
Thread Tools
Old 04-27-2010, 10:39 AM   #1
diamond
Bullard, Texas
2007 xlt
Vehicle Specs
(Original Poster)
Just wanted to know if a 07 ford explorer can be converted to 4wd and if so does anyone have the drive train break down, or has done it. I had heard that every thing is the same between the two, the 2wd and 4wd, just the 4wd parts like transfer case front dif and controlls are not installed.
diamond is offline   Reply With Quote
Old 04-27-2010, 10:51 AM   #2
hoss_hanna
ft. smith, ar
91 4x4, 93 XL, 01 mountie
Vehicle Specs
of course it can, but its not gonna be as easy as u are makin it sound. both trucks start out the same but get very different treatments at the factory, so there will be MANY things that will have to be changed in the process, and will take some skill and at least a bachelor degree in southern engineering not sayin dont go for it if u can get all the parts together, just sayin be forewarned its not a "bolt in" procedure.
__________________
---Mud is 4 play----
hoss_hanna is offline   Reply With Quote
Old 04-27-2010, 11:41 AM   #3
diamond
Bullard, Texas
2007 xlt
Vehicle Specs
(Original Poster)
My biggest thing is the trans, do i need a diffrent one or can the output shaft be changed? I have looked at buying a older model 4wd but the wife doesn't really want an extra car and we will be moving in two to three years and wont take it with us.
Old 04-27-2010, 01:22 PM   #4
kkreit01
Olathe, KS
'08 Sport Trac V8 2wd XLT
Vehicle Specs
I think it would be cheaper and easier to trade -- unless you have the know-how to DIY.
kkreit01 is offline   Reply With Quote
Old 04-27-2010, 04:12 PM   #5
bamnq6
Ridgecrest, CA
'04 V8 4WD
Vehicle Specs
much, much simpler (and cheaper) so sell your truck and buy a 4wd / AWD.
You need:
-transfer case
-front differential
-front hubs
-front halfshafts
-Reflash your PCM to control T case
-dash control switches
...I'm sure i'm forgetting some things
__________________
2004 4.6 XLS - 4WD 120k miles: The first X lifted with BTF-fabrication spacers (2.25F/1.75R)
265/75/R16 BFG All-terrain's, Rancho RSX's, roaming the Sierra's...
1996 Mazda Miata - the track-car for cheapskates
1996 Kawi Vulcan 1500 BUBF- "When life throws you curves, Aim for the apex."
bamnq6 is offline   Reply With Quote
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
