Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Explorer & Ranger Transmissions, Transfer Cases, & Differentials
Notices
Explorer & Ranger Transmissions, Transfer Cases, & Differentials Transmissions, Transfer Cases. A4LD, 4R70W, 4R44E, 4R55E, 5R44E, 5R55E, M5OD, BW 1354, Control Trac, GEM, AWD. Ford 8.8", Dana 35
1994 Ford Explorer transmission removal.
Reply
Thread Tools
Old 05-04-2010, 02:25 PM   #1
wgullion6
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
i need to find out step by step info on the removal of this tranny and transfer if anyone can help
wgullion6 is offline   Reply With Quote
( Join the Elite Explorers )
Old 05-04-2010, 02:40 PM   #2
BrooklynBay
Brooklyn, NY
BrooklynBay's Avatar
88 89 93 95 96 Aerostars
Vehicle Specs
Quoted: 415 Post(s)
Welcome to this forum! I've moved your thread into the transmissions section. There is a sticky thread on the top of this section with detailed step by step information on removing the transmission.
BrooklynBay is online now   Reply With Quote
Old 05-04-2010, 02:45 PM   #3
Doomie17
harford county, md
04 limited, 93 xlt
Vehicle Specs
Quoted: 0 Post(s)
its very easy
1.disconect battey
2.take off the drive shafts
3.remove the starter
4.disconnect the plugs and speed sensor. remove the 13mm bolts that connct the transfer case to transmission
5.slide the transfer case off
6.put a jack under the trans and take the trans crossmember off
7.lower the jack down and remove the bolts that connect the trans to block.
8.have a buddy help you slide the trans off
if its a manual trans its bout the same except you need to disconnect the hose that goes to the clutch thing
__________________
1993 explorer -----3" body lift, 5" suspension lift and soa on 35's
Doomie17 is offline   Reply With Quote
Old 05-04-2010, 11:41 PM   #4
MayJan
Gibsonville, NC
MayJan's Avatar
'94 XLT 5-speed
Vehicle Specs
Quoted: 55 Post(s)
It's not too big of an undertaking. I've done it four times in my driveway by myself, so if you have somebody to help you muscle it out and down to the ground, you should be ok. Just make sure that you have the vehicle high enough to allow the tranny to slide out from underneath after you get it loose! I found this out the hard way the first time I did this, and had to raise the ex up in order to get it out!
__________________
If the world didn't suck, then we'd all fall off!
Gathering parts for 5.0 swap!
How to: Wheel, Lift, and Tire sizes
1st gen balljoint/spindle/u-joint replacement
Lifting your Explorer to clear bigger tires
MayJan is offline   Reply With Quote
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
