Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2002 - 2005 Explorer Mountaineer 3rd Generation > Stock 2002 - 2005 Explorers
Notices
Stock 2002 - 2005 Explorers Questions related to non-modified 2002 - 2005 Explorers and Mountaineers. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. Sport Trac and Sport use the 1995-2001 forum.
How To: Replace Multifunction Switch
Reply
Thread Tools
Old 05-09-2010, 04:12 PM   #1
BigRondo
USMC 1371
Worcester, MA
BigRondo's Avatar
2002 XLT V6 4x4
Vehicle Specs
Quoted: 94 Post(s)
(Original Poster)
I replaced my Multifunction recently and searched the forum for instructions but didn't find any. Maybe I didn't look in the right place. Hey, I'm not that bright to begin with. I thought I'd do a write up on this procedure.
Be sure to check out my other write-ups:
How To: Replace Blend Door Actuator in 3rd Gen Ex
How To: Remove/Replace 3rd Gen Door Panel
How To: Install Signal Mirrors On 3rd Gen Ex
How To: Restore Faded, Yellowing Headlights
How To: Paint Rear Pillar Trim
How To: Replace 3rd Gen Ambient Air Temperature Sensor
How To: Test a Relay
How To: Remove/Replace 3rd Gen Center Console
It's not that difficult. If I can do it, anyone can. This is my first write up so go easy on me. Here we go:
Installation is reverse of removal.
I took my time with this as I was enjoying some adult beverages. I guess it could be done in about a half hour. Hope this helps out. The forum has been good to me and I hope this gives a little back.
Thanks, Rondo
__________________
Rondo - USMC, Combat Engineer, 1983-1996
Click here for a list of my write-ups!
Quote:
Originally Posted by FIND on 4-22-13
Don't mess with Boston. They will drop everything, hunt you down, and then go on like you never existed once they are done cleaning up the mess.
BigRondo is offline   Reply With Quote
( Join the Elite Explorers )
Old 12-18-2010, 01:41 AM   #2
forcemac
Vehicle Specs
Quoted: 0 Post(s)
Rondo-
How did the replacement go? Looks like you meant to post the explanation, but forgot to put it in? I find myself with a bad multifunction Switch on a 2002 Mountaineer, and would apperciate any info you might have....
I can't figure out to get it apart....
forcemac is offline   Reply With Quote
Old 12-18-2010, 08:43 AM   #3
BigRondo
USMC 1371
Worcester, MA
BigRondo's Avatar
2002 XLT V6 4x4
Vehicle Specs
Quoted: 94 Post(s)
(Original Poster)
Quote:
Originally Posted by forcemac View Post
Rondo-
Welcome aboard!
The replacement went well. I guess your right I didn't mention anything. Installation is the reverse of removal. So you just perform the steps from the last one to the first one.
Good luck with the fix. :
__________________
Old 12-18-2010, 11:30 AM   #4
forcemac
Vehicle Specs
Quoted: 0 Post(s)
Quote:
Originally Posted by BigRondo View Post
Welcome aboard!
How does it come apart? I am little apprehensive tearing apart my steering column, I really wanted to take the stem out and see if I can pop off the cap at the end and clean the contacts...but it looks like I have to remove the plastic housing around the steering column, and then it appears there a couple of screws that hold the stem in? is that correct?
Old 12-18-2010, 02:25 PM   #5
BigRondo
USMC 1371
Worcester, MA
BigRondo's Avatar
2002 XLT V6 4x4
Vehicle Specs
Quoted: 94 Post(s)
(Original Poster)
Are the pictures not showing up? If not, let me know and I'll fix that. If the pictures are showing up, then just follow the instructions and you should be all set.
If you have a 3rd Gen Explorer, 2002 - 2005, then popping the cap off will do no good. That is the first thing I tried. There are no contacts under the cap to clean.
__________________
Old 12-18-2010, 04:41 PM   #6
forcemac
Vehicle Specs
Quoted: 0 Post(s)
No pics showing up here....a lot of space though....
I had read about the older models and saw the pics for those....but sadly not the same. We'll if the thing doesn't come apart, then I'll just order a whole new switch instead of trying to fix/clean the one.
I am living in the UK, with my US spec Mountaineer....try to avoid ordering when I have to....
Old 12-18-2010, 07:22 PM   #7
D Hook
Omaha, NE
06 Explorer Limited V-8
Vehicle Specs
Quoted: 68 Post(s)
Pix show up fine here. Great write up BTW. Thanks!
__________________
2010 Expedition Limited LE --wife's DD & boat hauler
2006 Explorer Limited V8--Replaces the '02
1998 Mark VIII LSC--AKA Barca lounger on wheels. For Sale!
*Registered Smart Ass in all 57 states
D Hook is online now   Reply With Quote
Old 12-18-2010, 11:47 PM   #8
BigRondo
USMC 1371
Worcester, MA
BigRondo's Avatar
2002 XLT V6 4x4
Vehicle Specs
Quoted: 94 Post(s)
(Original Poster)
Quote:
Thanks! I don't know why forcemac can't see the pictures? Maybe there are some restrictions on his computer?
__________________
Old 12-19-2010, 01:22 AM   #9
forcemac
Vehicle Specs
Quoted: 0 Post(s)
well...it's a bummer that the pics aren't showing up. Don't know why...I don't have any special security software running or anything. I tried with IE and Firefox.....just space....not even little red x's.....
ok..bizzare...had to click on "turn Img code" on....it was already on....but clicked it anyways...now I can see the photos...
Old 12-19-2010, 02:34 AM   #10
Spdrcer34
Bremerton, WA
1992 Explorer XL
Vehicle Specs
Quoted: 10 Post(s)
I have pics here too....Great write-up...and a little entertaining. Thanks!
Ryan
__________________
1992 Ford Explorer XL - with a few bolt ons...
Spdrcer34 is offline   Reply With Quote
Old 12-19-2010, 09:58 AM   #11
BigRondo
USMC 1371
Worcester, MA
BigRondo's Avatar
2002 XLT V6 4x4
Vehicle Specs
Quoted: 94 Post(s)
(Original Poster)
Good deal. I'm glad you can now see the photos.
Quote:
Ryan
Thanks.
__________________
Old 12-19-2010, 10:37 AM   #12
BrooklynBay
Brooklyn, NY
BrooklynBay's Avatar
88 89 93 95 96 Aerostars
Vehicle Specs
Quoted: 411 Post(s)
I didn't see this write up until now. Thanks for taking the time to make this thread. It's now a sticky on the top of this section. Keep up the good work!
BrooklynBay is offline   Reply With Quote
Old 12-19-2010, 10:41 AM   #13
BigRondo
USMC 1371
Worcester, MA
BigRondo's Avatar
2002 XLT V6 4x4
Vehicle Specs
Quoted: 94 Post(s)
(Original Poster)
Quote:
Thank you sir!
__________________
Old 12-19-2010, 11:39 AM   #14
Joe Dirt
Joe Dirt's Avatar
07 Camry
Vehicle Specs
Quoted: 6 Post(s)
Very well done! I like the text bubbles...
__________________
If we confess our sins, He is faithful and just and will forgive us our sins and purify us from all unrighteousness. 1 John 1:9
Joe Dirt is offline   Reply With Quote
Old 12-19-2010, 02:33 PM   #15
BrooklynBay
Brooklyn, NY
Vehicle Specs
Quoted: 411 Post(s)
I like those bubbles too. Which program did you use to make them? MS Paint only has square boxes for text.
Old 12-19-2010, 05:28 PM   #16
BigRondo
USMC 1371
Worcester, MA
BigRondo's Avatar
2002 XLT V6 4x4
Vehicle Specs
Quoted: 94 Post(s)
(Original Poster)
Thanks guys. The program I use is PhotoScape. It is available as a free download.
__________________
Old 12-19-2010, 05:59 PM   #17
Joe Dirt
Joe Dirt's Avatar
07 Camry
Vehicle Specs
Quoted: 6 Post(s)
Downloading PhotoScape. Opting OUT of the Google Toolbar. Why? Why does EVERY program think I need the Google Toolbar!!!!
BB- Paint can do ovals and stuff...
Here is a quick summary pic- box, rounded box, oval, and dinosaur type thingy saying "roar!" (yes, I drew that myself, btw...)
__________________
Old 12-19-2010, 06:01 PM   #18
BigRondo
USMC 1371
Worcester, MA
BigRondo's Avatar
2002 XLT V6 4x4
Vehicle Specs
Quoted: 94 Post(s)
(Original Poster)
Joe, you are a man of many talents.
__________________
Old 12-19-2010, 06:05 PM   #19
Joe Dirt
Joe Dirt's Avatar
07 Camry
Vehicle Specs
Quoted: 6 Post(s)
Hardly any of them are actually useful though...
__________________
Old 12-19-2010, 07:58 PM   #20
BrooklynBay
Brooklyn, NY
Vehicle Specs
Quoted: 411 Post(s)
That's nice artwork Joe. I saw the option in MS Paint to make a circle, but I wasn't able to add text into it. I would like to know how you filled it in. It has an option to spray paint, but it's hard to get it inside of the shape. Maybe you could make a tutorial in the photoshop section of this site. I'll even make it a sticky for you. I don't want to clutter up this thread by getting off of the subject.
Reply
Tags
mfs, multifunction switch, turn signal switch
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
