jayton
- October 26, 2006
- Jefferson, GA
- 02 XLT V8
Got a weird one here. The truck is a 2002 Explorer XLT 2wd, and it has 170,000 miles. At around or about 130,000 miles or so, we had a bad bearing on the Right Front. We drove on it for about a year and the noise got worse slowly over time, mostly on any left turns at any speed above 20mph. Eventually, the grinding was just too much to bear and I replaced the wheel hub with one by Timkin. Problem fixed.
Now fast forward to this year, we have the grinding noise again from the same area of the truck. Just like before, the grinding has gotten worse over time, and it is now at the point where I have to do something, because the "Wife Acceptance Factor" has already been surpassed. Again, the noise is much louder on left turns and almost vanishes on right turns.
- I already replaced the Right Front bearing again, and it did not change the grinding noise one bit. I think I may have replaced a perfectly good bearing with a new one, but that is ok with me, as I am sure I will need the other one sometime in the future.
- The inner Brake Pad on the Right front is worn completely out, while the outer pad looks fine. The noise sounds like it could be a dragging rotor, but the noise is not any worse at all if I apply the brakes.
- The noise correlates to vehicle speed, and not driveline speed (tried it in neutral), and is not related to braking (noise only present when braking and turning slightly to the left simultaneously)
The upper ball joints on both sides have busted boots, and I plan on changing them this weekend. However, I do not believe they are the source of the grinding noise.
What else could it be? A bent spindle? Terrible alignment? Wheel bearing on the left front (even though there is no noise while making right turns at speed)?
I am a DIYer, and I will be the only one doing work on the truck, but I am open to taking it to the local tire store here in Athens, GA to have them check alignment and maybe a little diagnosis work.
