#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2002 - 2005 Explorer Mountaineer 3rd Generation > Stock 2002 - 2005 Explorers
Notices
Stock 2002 - 2005 Explorers Questions related to non-modified 2002 - 2005 Explorers and Mountaineers. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. Sport Trac and Sport use the 1995-2001 forum.
2002 Ford Explorer XLT with a PATS system failure.
Reply
Thread Tools
Old 05-14-2010, 02:10 PM   #1
davidalanonline
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
I realize I am new here and I am posting in the wrong category, but
I have thoroughly exhausted myself trying to figure out this problem, and for some reason I'm not allowed to post in the Ford Explorer "Assitance" forum.
I have a '02 Ford Explorer, I just bought it.
It's going to be a winter vehicle, so I bought it, drove it home, and parked it.
It's probably sat for 6 or 7 days without me starting it.
Yesterday I went to start the vehicle, and my anti-theft light it going crazy.
It bleaks. My doors lock. My dashboard lights up. My vehicle won't start.
It also appears my battery is dead which may have contributed to this ..
I attempted to jump the vehicle, but it still won't start. My anti-theft light blinks.
I tried to turn my "key switch" to 3, right before start, and leave it there, for my theft light to go out, but it still won't.
I've ran out of ideas, and I'm pretty frustated.
If you any of you would be so kind as to help me, I would be very thankful!
Is there a way to reset the theft system?
I keep reading about a override button under the dash, but I can't seem to find it.
If you could post specific detailed instructions explaining how to reset the sysystem and / or what my problem is it would be great!
Best,
David
davidalanonline is offline   Reply With Quote
( Join the Elite Explorers )
Old 05-14-2010, 02:11 PM   #2
davidalanonline
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Note: If the moderators would be kind enough to look over my posting in the wrong forum and allow my post to stay up long enough to assistance offered that would be great ..
Thanks.
Old 05-14-2010, 02:48 PM   #3
BrooklynBay
Brooklyn, NY
BrooklynBay's Avatar
88 89 93 95 96 Aerostars
Vehicle Specs
Quoted: 380 Post(s)
Welcome to this forum! I've renamed your thread, and moved it into the stock 2002-2005 section.
BrooklynBay is offline   Reply With Quote
Old 06-14-2010, 07:45 PM   #4
fusseli
2002 4.6L
Vehicle Specs
Quoted: 4 Post(s)
I'm having a very similar problem, no start followed by theft light blinking. I can't post in the 911 section either... My 02 mountaineer is stranded at work. Plan on trying a new battery later as I know some vehicles to have crazy electrical side effects when the battery is too dead to operate everything properly.
Any other ideas electrical and/or theft system related would be appreciated.
fusseli is offline   Reply With Quote
Old 06-14-2010, 10:10 PM   #5
jakedrew
wisconsin
04 xlt
Vehicle Specs
Quoted: 3 Post(s)
I would say put a new battery in there for starters. I know when my 04's battery got weak the gauges did some goofy stuff.
good luck
jakedrew is offline   Reply With Quote
Old 06-22-2010, 12:22 AM   #6
leapyear
dallas
2002 XLT
Vehicle Specs
Quoted: 0 Post(s)
i had the same issue today. i had both the battery and starter tested, both of which are working properly. everything electric powered works fine. the engine won't turn over. i can only hear the faint click of a relay.
when turning the key to the start position, my pats light stays on for 3 secs, then flashes non-stop for about 60 secs, then it changes to a patterned flash (on, pause, on, long pause - repeat) for another 60 secs, then it goes off. is this a good thing?
leapyear is offline   Reply With Quote
Old 06-22-2010, 09:46 PM   #7
fusseli
2002 4.6L
Vehicle Specs
Quoted: 4 Post(s)
sounds like PATS isn't recognizing your key. i read somewhere on the forum that the patterned flashes are codes that will tell you what part of PATS is failing.
Old 06-25-2010, 01:53 AM   #8
leapyear
dallas
2002 XLT
Vehicle Specs
Quoted: 0 Post(s)
Quote:
36 hours and $250 later, it turns out that my suspicions and your guess was right. they replaced the pats transceiver and reprogrammed the keys. no reason why it failed other than "they just sometimes do". at least i can start the car again.
Old 06-27-2010, 12:33 AM   #9
BrooklynBay
Brooklyn, NY
Vehicle Specs
Quoted: 380 Post(s)
Thanks for the update!
Old 04-02-2013, 12:27 AM   #10
seeborn
cambridge.maryland
2002 ford explorer
Vehicle Specs
Quoted: 0 Post(s)
I have a 2002 ford explorer 4.0 that gets gas and fuel but just wont start. I got some codes which is p0300,p0301,p0302,p0303,p1131,p0137 please if anyone can help me .
seeborn is offline   Reply With Quote
Old 04-02-2013, 01:55 AM   #11
Dwelves02XLT
NORCAL
05 Eddie Bauer 4WD
Vehicle Specs
Quoted: 2 Post(s)
For those who "might" have their spare key, recommend using it. The situation has happened to me before and I used the spare and it fired right up. Seeing its a issue with the vehicle, I now keep he spare key on the key ring with a sticker on it just incase it happens again. The sad part is once I turn it off and use the main, it fires right up as well.
Dwelves02XLT is offline   Reply With Quote
Old 04-07-2013, 05:18 PM   #12
BigRondo
USMC 1371
Worcester, MA
BigRondo's Avatar
2002 XLT V6 4x4
Vehicle Specs
Quoted: 94 Post(s)
Quote:
I recommend starting a new thread in the Stock 2002 - 2005 Explorers Sub Forum.
This thread is about something completely different.
Here is the link to the Stock 2002 - 2005 Explorers Sub Forum:
http://www.explorerforum.com/forums/...play.php?f=101
Good luck & Happy Exploring!
__________________
Rondo - USMC, Combat Engineer, 1983-1996
Click here for a list of my write-ups!
Quote:
Originally Posted by FIND on 4-22-13
Don't mess with Boston. They will drop everything, hunt you down, and then go on like you never existed once they are done cleaning up the mess.
BigRondo is offline   Reply With Quote
Old 06-08-2013, 01:54 PM   #13
One eyed willy
2001 sport trac
Vehicle Specs
Quoted: 0 Post(s)
I know this is a old thread, but I have some info to help. Just went thru this this morning!
Both keys would not start, no click and the theft light would just rapidly flash. I checked all fuses first, disconnected the battery for 30 minutes...still nothing. Used my code scanner and got B1681. Pulled apart the column, unplugged the transceiver harness and 3 wires metered 12volts and 1wire was a ground, so I knew it had power. Went to ford, $48 later I had a new transceiver. Plug and play, no programming and was back in action. From my reading it appears some pre 01 models needs to have the keys re-programmed...but I got lucky and didn't need it.
One eyed willy is offline   Reply With Quote
Reply
Tags
2002, explorer, theft system, xlt
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
