#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Under the Hood
Notices
Under the Hood Ford Explorer and Ranger, Engine, troubleshooting, modifications, performance and accessories.
Ford Explorer Died while driving. Has spark. Turned over, then battery died
Reply
Thread Tools
Old 05-16-2010, 09:23 PM   #1
452films
Southern Maine
'99 XLT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
So in the past 4 weeks I've put 3500 miles on my 99' Explorer 4.0 SOHC. Today the first series of unexplainable problems have happened.
I have been throwing codes for an o2 sensor and MAF since I got it, but it runs fine, and I just clear the codes every so often ( comes back on after about 45 minutes of driving )
Driving normally, and look down, the battery light flickered once. Figured it was coincidence or something. Didnt happen again.
I'm driving along. 30mph, 1200rpms. All gauges look good. Battery level centered. Heat centered. Oil pressure centered. And I just put $15 of 87 octane in about 10 minutes prior to this. I go to accelerate ( lightly. Planned on pushing no more than 2000 rpms and 40mph ). The car dies. I pull onto the road before mine ( Yeah, made it a couple hundred feet from home. Just great, and it's all uphill so I had to get a tow. Try to restart, turns over fast, and wont start. Got the occasional acting like it will start, but doesn't. I have a slight smell of fuel, but figured I just flooded the motor because the fuel pump still works, and I turned the key on and off a few times to get the pump to turn on.
Now, after I check for spark ( and have spark ), I turn it over and it turns over nice and fast. Then let off, and try again. clickclickclickclick. Batterys dead. The needle for the battery just dropped.
Any ideas would be great. Unplugged the MAF and it didnt even go into limp mode or anything.
Possibly a clogged fuel filter? Bad MAF? Alternator?
Could a bad or shorted out o2 sensor cause it?
__________________
1999 Ford Explorer
Fully loaded w/ leather
Magnaflow Exhaust
Brush Guard
235 All Terrains
452films is offline   Reply With Quote
( Join the Elite Explorers )
Old 05-16-2010, 10:22 PM   #2
n2epv
Pittsfield, MA
04 XLT 4.6, 01 Jetta VR6
Vehicle Specs
Quoted: 1 Post(s)
I don't believe that an O2 or MAF problem would ever cause it not to start. It also sounds like your battery is on the way out or there's a charging system problem. But that only limited the cranking ability after it stalled.
So put a battery charger on it for a hour or swap the battery so that you can get it to turn over again. I think there is a schrader valve on the fuel rail (under a plastic cap - looks like a tire valve). After you have tried cranking it again, carefully push this valve open and fuel should spray out. If the filter isn't clogged, there will be about 40 PSI of pressure, so stand off to the side!
10 minutes of slow driving sure sounds like the time it would take for bad or dirty gas to disable your truck.
n2epv is offline   Reply With Quote
Old 05-16-2010, 10:36 PM   #3
ranger7ltr
Great State of Texas
1999 Sport
Vehicle Specs
Quoted: 31 Post(s)
Quote:
Actually, if your fuel system is working properly, you should have 65-72 psi of fuel pressure at the schrader valve...I would recommend getting the battery charged and/or check the battery connections then testing the fuel pressure to see if the pump or the filter are causing you issues...
__________________
When in doubt, use a bigger hammer!
2014 Jeep Compass Limited [Company Vehicle]
2003 Ford F-150 XLT Supercab
1999 Ford Explorer Sport [new playtoy]
1983 Ford Ranger V8 [soon to be gone]
ranger7ltr is online now   Reply With Quote
Old 05-17-2010, 04:14 PM   #4
452films
Southern Maine
'99 XLT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Fuel pressure was over 60lbs. Put a new o2 sensor on it. Tried to start it with ether through the intake, not even a putt from it.
__________________
1999 Ford Explorer
Magnaflow Exhaust
Brush Guard
235 All Terrains
Old 05-17-2010, 04:34 PM   #5
Joe Dirt
Joe Dirt's Avatar
07 Camry
Vehicle Specs
Quoted: 6 Post(s)
Could it be a bad battery cable or bad ground?
__________________
If we confess our sins, He is faithful and just and will forgive us our sins and purify us from all unrighteousness. 1 John 1:9
Joe Dirt is offline   Reply With Quote
Old 05-18-2010, 08:40 PM   #6
452films
Southern Maine
'99 XLT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Im assuming I snapped a timing chain. Man this is gonna be a long fix if it is
__________________
1999 Ford Explorer
Magnaflow Exhaust
Brush Guard
235 All Terrains
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
