#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer - Sport thru '03 - 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
Power windows don't work.
Reply
Thread Tools
Old 05-19-2010, 02:40 PM   #1
99ExplorerRed
Tempe AZ
99 XLT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
US Power windows don't work.
Ok, this is my first post on here so go easy on me lol! I have a 1999 Ford Explorer XLT. The lift gate latch was slipping when I went to open it. So I thought I would take the trim off and take a look. I found that the latch was slipping and not pulling on the rods to the latches on either side. Put that one aside, I decided to take off the driver’s side and rear drivers side trim off cause I m having problems with those locks too. Now, none of my window controls will not work. I checked the 30 amp maxi fuse under the hood, the battery saver #26 in the fuse panel, there all fine. The switch light's up when the lights are turned on, but I cannot get any of the window switches to work. I did not mess with any wiring while removing the trim panels.
99ExplorerRed is offline   Reply With Quote
( Join the Elite Explorers )
Old 05-22-2010, 10:53 PM   #2
BrooklynBay
Brooklyn, NY
BrooklynBay's Avatar
88 89 93 95 96 Aerostars
Vehicle Specs
Quoted: 380 Post(s)
Welcome to this forum! I've moved your thread into the stock 95-01 section.
BrooklynBay is online now   Reply With Quote
Old 06-05-2010, 09:17 PM   #3
99ExplorerRed
Tempe AZ
99 XLT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Windows Work Now!
Ok, so I figured it out! With the help of the this thread (http://www.explorerforum.com/forums/...d.php?t=193675). It was discussed in this thread that the control module on the door for the power windows gets power on a blue with a black stripped wire. First since my windows were stuck down i ran a piece of 20g wire from the positive terminal on the battery to that wire on the module. Hit the button, the windows came up! So that eliminated the module as a suspect for the problem. So I located the wire on the module and traced it back through the door. Right where the rubber boot in the door jam, just below the top hinge was the break. So i soldered a piece of wire on both ends, wrapped up each end and then to the wire, and put it all back together. Now on work on my lock problems. Tailgate latch slips, drivers side door will not unlock en less i press the 6th combo button and pull up on the handle at the same time, and rear drivers side door will not release inside the car. Fun Fun. But i still love my baby!
Old 06-06-2010, 12:08 AM   #4
BrooklynBay
Brooklyn, NY
Vehicle Specs
Quoted: 380 Post(s)
Thanks for the update!
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
