#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Explorer & Ranger Transmissions, Transfer Cases, & Differentials
Notices
Explorer & Ranger Transmissions, Transfer Cases, & Differentials Transmissions, Transfer Cases. A4LD, 4R70W, 4R44E, 4R55E, 5R44E, 5R55E, M5OD, BW 1354, Control Trac, GEM, AWD. Ford 8.8", Dana 35
1996 Ford Explorer Transmission Question
Reply
Thread Tools
Old 05-22-2010, 12:47 AM   #1
CamDJClimited
Southampton, MA
1996 Ford Explorer Limite
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Question 1996 Ford Explorer Transmission Question
So I just found out by our mechanic that the Transmission Torque Converter is bad, and needs to be replaced. Would I be better off replacing the whole transmission? Or just the torque converter. We have our own mechanic we go to, so no way am I going to the dealer, and I could always buy the parts used. What do you think? The transmission seems fine other than the torque converter.
CamDJClimited is offline   Reply With Quote
( Join the Elite Explorers )
Old 05-22-2010, 01:16 AM   #2
rhauf
Ca
'93 and '91 explorer
Vehicle Specs
Quoted: 0 Post(s)
Well, if it seems fine then no reason to replace it...
i suppose you're thinking is, while it's out, might as well rebuild/replace the whole thing, right? and that makes sense.. i suppose it really comes do to price difference.. decide if it would be cost effective to replace/rebuild the trans over just replacing the torque converter..
personally, if the trans has say, 150k or more on it, and replacing the trans vs. just the TC isn't more than double the price, i'd do it.
rhauf is offline   Reply With Quote
Old 05-22-2010, 01:47 AM   #3
CamDJClimited
Southampton, MA
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Hmmm, okay. My mechanic said he'd charge me $400 to install the Torque Converter. Does that sound like a good deal? I wonder how much he would charge me to re-build the whole thing.
Old 05-23-2010, 01:20 AM   #4
rhauf
Ca
Vehicle Specs
Quoted: 0 Post(s)
400 sounds like a fair price to replace the torque converter, especially if it's a 4x4. remember to change the torque converter, the whole transmission has to be removed. it will also need new fluid. the torque converter itself probably costs around $120.
a whole rebuild would cost between $1000 and $2500, depending on what trans you have, and who's doing the rebuild. if you have the 4r70w that thing lasts pretty good and i wouldn't bother rebuilding it, if you have one of the weaker ones liek 5r55e or 4r55e or whatever, then maybe it would be more worthwhile.. i dunno
how many miles are on the trans? you're probably best off just replacing the TC for 400 bux and being on you're way.
Old 05-23-2010, 10:54 PM   #5
CamDJClimited
Southampton, MA
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
How can I identify the tranny I have? And im not sure if the previous owner put a new transmission in or not, but if it's factory, then it has as many miles as the car- 135,000
Old 12-17-2011, 09:31 AM   #6
grubby21
1996 ford explorer 4x4
Vehicle Specs
Quoted: 0 Post(s)
How do i know what transmission is in my explorer
grubby21 is offline   Reply With Quote
Old 12-18-2011, 07:56 AM   #7
PopRichie77
Quakertown, PA
2001 Explorer Sport 4X4
Vehicle Specs
Quoted: 24 Post(s)
Why does your mechanic say the torque converter is bad? Many things inside the trans can cause a lockup torque converter to not work properly.
PopRichie77 is offline   Reply With Quote
Old 03-04-2012, 05:00 PM   #8
MANUELSSB
seattle
ford explorer 1966
Vehicle Specs
Quoted: 1 Post(s)
I have a problem with mi ford explorer and i am desperated first start on not going it all on drive just in second and while get speed i can move it to d but now is worse not going it all the mechanic told me is the selenoids i check them they are good to the test i did i am don't have way to go what can be wrong with my transmission and is just tree months rebuild
MANUELSSB is offline   Reply With Quote
Old 10-15-2012, 12:38 PM   #9
mick7531
1996 Ford Explorer
Vehicle Specs
Quoted: 0 Post(s)
Type transmission
How do i identify which type of transmission i have in a 1996 ford explorer
mick7531 is offline   Reply With Quote
Old 10-15-2012, 04:13 PM   #10
JK080
Transmission Moderator
North Ga
JK080's Avatar
05 F250 6.0
Vehicle Specs
Quoted: 93 Post(s)
95-96 - 4.0 - 4r55e
96-01 - 4.9 & 5.0 - 4r70w
97-04 - 4.0 - 5r55e
__________________
~~ James ~~
Certified Transmission Rebuilder of 28 years of all Makes and Models
JK080 is offline   Reply With Quote
Old 10-24-2012, 06:28 PM   #11
Justme63
South Central Wisconsin
1996 Explorer 4.0 4x4 2dr
Vehicle Specs
Quoted: 6 Post(s)
Quote:
There is a sticker on the drivers door. Look for the code TR on the bottom right.
Justme63 is offline   Reply With Quote
Old 10-24-2012, 06:30 PM   #12
Justme63
Vehicle Specs
Quoted: 6 Post(s)
Quote:
Originally Posted by JK080 View Post
95-96 - 4.0 - 4r55e
97-04 - 4.0 - 5r55e
The 95-96 4.0 has the 4R44E
Old 10-24-2012, 10:44 PM   #13
JK080
North Ga
JK080's Avatar
05 F250 6.0
Vehicle Specs
Quoted: 93 Post(s)
I don't know of the 4r44e behind the 4.0 they only came behind the 2.3, 2.5 and 3.0 liter engines. The 44 is a for 440 foot pound rating and the 55 is for a 550 foot pound rating.
__________________
~~ James ~~
Old 10-25-2012, 06:02 PM   #14
Justme63
Vehicle Specs
Quoted: 6 Post(s)
After all my research, which was alot of reading and visiting many websites, I have found that Ford used a 4R44E in 95 and early 96 behind the 4.0 in the explorers. The TR (transmission) code on my door sticker says this with a T code. I am in the process of replacing my trans and have had to do a lot of searching to find one that will match up without changing anything. I found a 95 that has the same code, engine, trans, etc, etc. Now someone told me the 95 has OBD I system so I need to make sure this doesn't affect this swap.
Old 11-18-2012, 07:12 PM   #15
N1265
Fremont Oh
'04 explorer
Vehicle Specs
Quoted: 2 Post(s)
I have a 96 sitting in the driveway with 272k miles on the trans, That being said I have put TWO torque converters in it. One had a broken fin causing a noise similar to a playing card in bike spokes. The other I spun the hub out when doing a neutral drop.
It is my opinion that $400. to drop and install a trans is a good price...
N1265 is offline   Reply With Quote
Reply
Tags
converter, mechanic, replace, torque, transmission
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
