Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Under the Hood
Notices
Under the Hood Ford Explorer and Ranger, Engine, troubleshooting, modifications, performance and accessories.
4.0 compression
Reply
Thread Tools
Old 05-23-2010, 05:18 PM   #1
copter14
Vehicle Specs
(Original Poster)
4.0 compression
are theese good numbers, this is 4.0 litre out of 1991 i wanna use for my swap into 88bII.
cyl 1@165
cyl 2@175
cyl 3@190
cyl 4@175
cyl 5@185
cyl 6@175
top end has tick so i will prob have it redone.
copter14 is offline   Reply With Quote
Old 05-23-2010, 08:34 PM   #2
bluestream1
Waterloo Ontario
2000 XLT 4.0 SOHC 4X4
Vehicle Specs
There should be no more than 10% variance between cylinder readings.
__________________
2000 Ford Explorer SOHC 4X4 249,000KM
2003 Ford Escape 101,000KM
bluestream1 is offline   Reply With Quote
Old 05-23-2010, 10:15 PM   #3
Maniak
Moderator-Stock 91-94
Vail, Arizona
Maniak's Avatar
1992 XLT 4x4
Vehicle Specs
Your just outside the range of what is considered "good"...
Lowest of 165 meaning the highest should be 181.5. How exact were those numbers? I found many people just round the # to the closest 5.
Also, did you try a wet test after the compression test? If the #'s go up with a little oil in the cylinders then you know its rings.
~Mark
__________________
Click HERE to see our Explorer Specs
Maniak is online now   Reply With Quote
Old 05-24-2010, 08:37 AM   #4
copter14
Vehicle Specs
(Original Poster)
thoose were exact numbers i didn't round them off.
i'll try another dry test to confirm #1 cyl is that low.
then i will do a wet test and post.
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
