| EF Swag Store | 2013 Ford Explorer | Forums | Elite Membership | Chat Room | My Posts | Reviews | Explorer Photo Gallery |
| Modified 2002 - 2005 Explorers Questions related to modified 2002 - 2005 Explorers and Mountaineers. For Sport Trac and Sport models use the 1995-2001 forum. Aftermarket accessories and modifications. Bullbar, running boards, floor mats, cargo mat, DVD headrest, wheels, tires, stereo upgrade, headlights, mud flaps, lift kits, engine swap, transmission swap. |
Thread Tools |
#1 |
Wannabe Elite Explorer
2005
LED turn signals, quick blinking
I am putting in LED turn signals, and I know they are going to hyperblink. My question is, where the heck is the flasher? I am getting an electronic flasher and I removed the driver kickpanel but I can't find the flasher. I heard from someone it is under there. Any ideas how to install electronic flashers?
#2 |
OP KS
92 xlt 5.0
this will solve your problem http://www.putco.com/products.cfm?ac...c-b9c2f6222048
#3 |
2005
Thanks, thatll do the trick!
#4 |
Richlands, VA
2002 Mercury Mountaineer
__________________ Mountianeer family I have a 2002 and she has a 2008. Both AWD V6. |
#5 |
Mineral Wells, WV
'04 XLT Sport
The flasher is on the back of the fuse panel up under the dash on the driver's side. I changed mine out for an electronic unit. LED's work fine.
__________________ '04 Explorer XLT Sport 4x4 V8 Lowered w/ GF springs on 20" Boss 335's, Eibach front & rear sway bars, Powerslot Cryo's with Hawk pads, FX-R projector retrofit/5000K HIDs/LED tails, stainless grills & step bars, K&N intake/JBA headers/Magnaflow hi-flow cats and Magnapack muffler/ASP UD Pulleys/GMS Hot Street coil packs/E-fan/X3 Tuned by Henson |
#6 |
Richlands, VA
Ok now how the heck did you get to the back of that panel there 1bad04? I tried like heck to get to mine with no luck. Also I have a set of LEDs 3157 to put in the front of my 02 Mounty for park/signal lights and they will work as the signal "blink fast but i understand that" but won't light as the parks. Why? The regular bulbs work great, not sure what the issue is. I put the same bulbs in the rear of her 08 mounty in the clear taillights "factory" they look killer BTW. I put the load resistors I linked on them and work great. Would I need the reisistors on the front to even make the parks light?
STU __________________ Mountianeer family I have a 2002 and she has a 2008. Both AWD V6. |
#7 |
Saginaw, MI
2002 4.0 FX4
old thread, but i bought some led bulbs for my front turn signals a while back, tried hooking them up with resistors and still got hyperblink. there are three wires going to the turn signal socket, which of those two get spliced into the resistor? i tried all possible combinations but the lights still blinked fast. help please?
__________________ -Steve- Mustang GT's 17x8 +24 Offset, 245/65r17 Hankook Dynapro ATM RF10 BTF 2.25" front, 1.75" rear, 1.5" bodylift, Spartan Locker The Mounds 2002-2005 Explorer Facebook Page |
#8 |
OP KS
92 xlt 5.0
Resistors can be installed backwards...
#9 |
Saginaw, MI
2002 4.0 FX4
![]() never knew that. guess i'll have to try again. __________________ -Steve- Mustang GT's 17x8 +24 Offset, 245/65r17 Hankook Dynapro ATM RF10 BTF 2.25" front, 1.75" rear, 1.5" bodylift, Spartan Locker The Mounds 2002-2005 Explorer Facebook Page |
#10 |
Stockton, CA
'04 XLT
#11 |
NYC
2002 FoRd Explorer
I know this is a really old thread but I was having the same problem with my 02 Explorer. I purchased front amber LEDs and red tail light LEDs and I knew I was gonna have a prob wit hyper flashing! But I did not wanna install glow plugs under my hood! I haven't seen anything on here for a real fix. I have seen a lot of flasher relays online but not in a local auto parts store! I figured it couldn't hurt to check. So off to autozone and sure enough I found one EP27 fits a wide range of Ford vehicles! It's a 5 terminal relay. Novita Electrionic Flasher! On the back it also tells you it's compatible with LEDs! Sorry this is my very first posting so I hope it helps! It's def better than installing Resisters that just get burning hot and melt everything in reach! http://www.novitatech.com/tridonflashers.html
| Thread Tools | |
